сergey 172 1 Тракты Опубликовано 9 января, 2016 Manley Labs has unveiled the company’s latest product for the Hifi market at CES 2016, The Manley Headphone Amplifier which they say has been built to meet the demand of audiophiles turning to personal headphone listening. Information from Manley’s website says “There are twelve independent controls designed for maximum performance and customizable handling of sonic adjustments for a wide variety of audio experience. Of special import are the custom hand-wound air-gapped dual-mode MANLEY IRONⓇ output transformers, designed and manufactured at the Manley Labs factory in Chino, California. With a push of the button, these transformers are easily user-configured to drive three ranges of headphone loads, from 12 to 600 Ohms or greater”.The output stage of the Manley Headphone Amplifier can be switched on-the-fly between all-triode Push-Pull and Single-Ended topology.The Volume Control is performed by a Precision Stepped Relay ladder matrix whilst left-right Balance control is provided to trim out uneven recordings. The Manley Headphone Amplifier operates fully symmetrically, enabling it to drive balanced headphones through its XLR outputs but of course non-balanced ¼” jacks are also present. A direct preamplifier output which routes your first line input through the system to feed an external power amplifier or powered loudspeakers is also available when the headphone amp is powered down.The Manley Headphone Amplifier also, and somewhat unusually in this day and age, incorporates bass and treble tone control to allow listeners to adjust the flavour of the sound to their preference… but you can totally bypass of the EQ circuits also.The Manley Headphone Amplifier is available in three different colours fu: Champagne & White, Titanium & Bronze, or Copper & Black.DetailsVacuum Tube design, 2 x 12AT7A Drivers, 4 x 6AQ5 Triode Strapped output tubesSingle-Ended or Push-Pull amplifier operationPrecision Stepped Relay Volume Control with Thumb WheelSelectable headphone load settings: 12-50 Ohms, 50-200 Ohms, 200-600 OhmsVariable Feedback Control: 0–10dB of negative feedbackBalance, Treble and Bass Controls use silent conductive plastic potentiometersTone Bypass for purist signal pathAll switching via high-grade gold-contact relays3 x Stereo Outputs: Balanced XLR headphone outs, Unbalanced standard ¼” TRS headphone jack, RCA Preamplifier Outputs2 x Analog line-level RCA inputsMono / Stereo functionMute SwitchUser adjustable Headphone Overload Protection SystemMANLEY IRONⓇhand-wound wide bandwidth air-gapped output transformersPreamplifier Direct output routes Input 1 direct to output when unit is in standbySoft Start, mute-controlled power-up sequenceHigh Speed, Low Impedance, Low Noise custom switching PSUOperating Mains Voltage: 90~250VAC universal works worldwideMains Voltage Frequency: 50~ 60HzSolid Aluminum Billet ChassisReal Wood Walnut Burl TrimMaximum Output Power: 1WUnit Dimensions: 11.5 x 5.5 x 8.2” (LxWxH)Unit Weight: 12 lbs.MSRP: $2950 3 Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
gray50 483 1 Тракты Опубликовано 9 января, 2016 А, ну вот и монстры лампостроения подтянулись, дизайн конечно спорный, лично мне Омский муз. театр напоминает (трамплин), 1w максималки пожалуй маловато будет, вряд ли тугие топы потянет. Esoteric k-07 . Audio valve rkv mark-2 . audio valve impedanser . sennheiser hd-800 ( Alo audio reference-8) sennheiser hd-265 (leineer) . Stax sr-007 mk-2 усил. для электростатов (victorvvo) . atlas mavros .Stereovox Colibri-X.. Shunyata Research . Black mamba . Kubala-Sosna Emotion, Systems and Magic Slim3, 2 Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
Александр Карелин 3 721 Опубликовано 9 января, 2016 (изменено) Даже до американских старперш уже дошел аймаковский дизайн конца девяностых начала нулевых..... "Самые отсталые слои населения оделись в джинсы"(с)Использование однотактного транса на сердечнике с зазором для работы в двухтакте (а так же лишние обмотки и их коммутация -это ничего не улучшает, а наоборот) - какое-то дурноватое решение, мягко говоря. И уж о хай-энде говорить после этого не приходится. Радует что Мэнли не страдает хоть кенотронной дурью.... Изменено 9 января, 2016 пользователем Александр Карелин "...сочинение магистра Алькофрибаса, извлекателя квинтэссенции " Наушники: Beyerdynamic T1 2nd Generation, Sony MDR-Z1R, Audio-Technica ATH-CKR9Ltd, кастомные Westone ES60 Усилители: только собственного производства транзисторные и ламповые "Ратша" Плеер: Luxury & Precision L3 Pro (!balanced output!) наушники Audio-Technica: ATH-W5000, ATH-ESW9, ES10(было), A2000x(было), W5000, R70x (было), CK100Pro(было), CKR9LTD, IM04(было), кастомные Westone ES60, Sony MDR-Z1R усилители: Sovereign Reference, Sovereign Baby Reference, Ратша плеер: Teclast T51, HiFiMan HM-801 (было), Pono Player SE(было), Aune M2 Pro (было), Cayin i5 (было) телега 1 Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
pollar 8 807 Опубликовано 9 января, 2016 Дизайн - это всегда спорное решение ...а вот как подставка для наушников со встроенным усилителем Philips CD104(винтаж) - MS Audio FHA1.2 - Denon 2000 /всё в разной степени доработано/ Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
Александр Карелин 3 721 Опубликовано 9 января, 2016 Дизайн - это всегда спорное решение не всегда, черный монолит параллелепипед золотых пропорций - бесспорен )))) а подставка за 3килозелени, ну бывает... "...сочинение магистра Алькофрибаса, извлекателя квинтэссенции " Наушники: Beyerdynamic T1 2nd Generation, Sony MDR-Z1R, Audio-Technica ATH-CKR9Ltd, кастомные Westone ES60 Усилители: только собственного производства транзисторные и ламповые "Ратша" Плеер: Luxury & Precision L3 Pro (!balanced output!) наушники Audio-Technica: ATH-W5000, ATH-ESW9, ES10(было), A2000x(было), W5000, R70x (было), CK100Pro(было), CKR9LTD, IM04(было), кастомные Westone ES60, Sony MDR-Z1R усилители: Sovereign Reference, Sovereign Baby Reference, Ратша плеер: Teclast T51, HiFiMan HM-801 (было), Pono Player SE(было), Aune M2 Pro (было), Cayin i5 (было) телега Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
Demm 2 032 Опубликовано 9 января, 2016 Lynx AES16 -> Mytek Digital Stereo192-DSD DAC-> AMB Beta22 4-board balanced+2xSigma22 by Helium -> Hifiman HE-6 Snorry Carbon Fiber Headband Mod Lynx AES16 -> Mytek Digital Stereo192-DSD DAC-> Двухтактный усилитель (6SL7/6V6) для наушников Stax by victorvvo-> Stax SR-507, Stax SR-303, Stax SR-007A MKII SZ2 Межблочный кабель: 16 Core Pure Silver Litz XLR Interconnects by Achtung Audio 6 Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
pollar 8 807 Опубликовано 9 января, 2016 не всегда, черный монолит параллелепипед золотых пропорций - бесспорен ))))Я Вас умоляю! Был бы предмет спора (ну о "золотых пропорциях" так о "золотых пропорциях" - ну разве это "проблема", при желании поспорить )а подставка за 3килозелени, ну бывает...Ну да, теперь бывает! На фото ведь "запротоколировано" . но как предмет для спора - Philips CD104(винтаж) - MS Audio FHA1.2 - Denon 2000 /всё в разной степени доработано/ Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
zAg 3 251 Опубликовано 9 января, 2016 Дизайн - это всегда спорное решение ...а вот как подставка для наушников со встроенным усилителем Такая "подставка" подойдёт далеко не всем наушникам. Наушники на подобии HD650-х скорее всего, даже-бы пострадали от такой ненужной растяжки, явно бы лопнуло оголовье, а здесь ещё здобренное теплом от ламп и краска поотлетала-бы на "Ура" в придачу. Продам усилитель для наушников Panda Amp. Classic (новый). Собран из набора Panda amp. KIT с использованием серебросодержащего припоя Oyaide-SS47, кабеля из монокристалической меди Oyaide PA-02, трансформатора Talema 50VA, позолоченных терминалов Neutrik, корпус заводского производства (не самоделка). CD Player (mod), DAC, ZAG : Sapphire (Super mod Buffalo IIISE-Pro - analog full Z-Foil resistive signaling pathway and other improvements).Cables Digital RCA (SPDIF): Oyaide DR-510 (silver 5N),Amplifier's:ZAG : AMB Beta22 Crystal (full Z-Foil resistive signaling pathway and other improvements - Super mod AMB Beta22),ZAG : RoyalGlass (Super mod Panda HA-1MK2),Lehmann BCL (mod).Cables RCA: ZAG : Flame AR7 SPC-Reference SC (PCOCC-A Mono Crystal Copper Wire with solid stranding, Deep Cryo Treated),ZAG : Silver Bullet (??) (Two Wire Gauge, UP-OCC Mono Crystal Silver Wire with solid stranding, Deep Cryo Treated), DAXX R100.Headphones: ZAG : 800SW (capcule sennheiser HD800), Sennheiser HD650, ATH-FC707, Ritmix RH-508.Headphones Cables 4 pin XLR (Furutech) / 4 pin miniXLR (Furutech FT-610mF):ZAG : SA-N7 ADR 2.5 (Silver Angel) (asymmetric diameter ratio of 2.5 hot and cold conductors) (UP-OCC Mono Crystal Silver Wire with solid stranding, Deep Cryo Treated),ZAG : Red Davil 0.6 (UP-OCC Mono Crystal Copper Wire with solid stranding, Deep Cryo Treated). 1 Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
Ilya-s 812 1 Тракты Опубликовано 9 января, 2016 portable: jaybird x2, x3in the past: lcd2r1, lcd3, sr007mk1, sr007mk2, sr009, th900, hd800, d7000, dt911, he4 and many more )) 2 Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
pollar 8 807 Опубликовано 9 января, 2016 Дизайн - это всегда спорное решение ...а вот как подставка для наушников со встроенным усилителем Такая "подставка" подойдёт далеко не всем наушникам. Наушники на подобии HD650-х скорее всего, даже-бы пострадали от такой ненужной растяжки, явно бы лопнуло оголовье, а здесь ещё здобренное теплом от ламп и краска поотлетала-бы на "Ура" в придачу.Ну а как ты хотел! В аудио лёгких путей не бывает учитывая стоимость подставки... ...650-х к ней можно сразу "жменю" брать, как расходный материал Philips CD104(винтаж) - MS Audio FHA1.2 - Denon 2000 /всё в разной степени доработано/ Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
giclee 71 Опубликовано 9 января, 2016 Такая "подставка" подойдёт далеко не всем наушникам. Верно. Это "подставка" для американских наушников, которые делаются специально для квадратных американских голов. Когда я был маленький, у меня тоже был магнитофон... DT 770 PRO > Sennheiser HD600 > Grado RS1 > Grado RS1i > Audio-Technica ATH- ES10 > German Maestro Gmp-450Pro > Fostex T50Rp > Grado RS2i > Sennheiser HD650 > T70 > AKG 712PRO > Sennheiser HD800 > SONY MDR-Z7 + Sennheiser HD600 3 Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
Rutger 14 683 18 Тракты Опубликовано 9 января, 2016 Глядя на такие "шедевры", всегда хочется задать пару вопросов дизайнеру, который проектировал данное устройство. Хотя все субъективно, может кому и нравится. Меня больше размеры смущают, не будет ли данное ламповое устройство перегреваться при работе? Система Rutger Спойлер CD Players: PS Audio Lambda Two Special (CDM-9 Pro), PS Audio Lambda Two (CDM-9 Pro), Marantz CD-23F (CDM-9 Pro, 2xTDA1547) / DACs: RME HDSPe AIO (AD1852/CS5361), Wadia 27ix (8xPCM1702U-K + 2xMotorola DSP), Burmester 870 MKI (2xPCM53KP-I, CX23053) / Amplifiers: Beta22 by Helium (Balanced, AMB Delta1 + AMB Delta2), Victor’s Light Voice IZO DHT (6SL7 WGT Sylvania, 2A3-T Mark II Psvane), Sugden Masterclass IA-4 / Headphones: Audeze LCD-4 (4xLitz Cu 500/2xLitz Cu 1200/Silver Coaxial from "Hybrid Audio Cables"), Audeze LCD-2 (NF, ver. 2.5, Rosewood, SAA Endorphin), Beyerdynamic DT990/600 Ohm (VTG), Koss Pro/4 AAA / АС: Coral DX-Eleven (XLO Signature 5.1, 4 x WBT 0703 Cu) / Power: FluxLab Power Supply Station PS-202, БГР (ТТП-350 "Торэл", 2x225В), Accustic Arts Power Strip Passive 6, кастомный распределитель питания (4 EU - Rong Feng/Rich Bay / 4 US - Oyaide R1) / Analog: National RX-7000 Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
zAg 3 251 Опубликовано 9 января, 2016 Глядя на такие "шедевры", всегда хочется задать пару вопросов дизайнеру, который проектировал данное устройство. Хотя все субъективно, может кому и нравится.Думаю, особенно понравится тем, кто назвал мой дизайн "цыганским". Этот - офисный, им как раз, в самый раз, вместе с подставками под папки в один ряд, самое то будет, аж "описаются" от счастья. Продам усилитель для наушников Panda Amp. Classic (новый). Собран из набора Panda amp. KIT с использованием серебросодержащего припоя Oyaide-SS47, кабеля из монокристалической меди Oyaide PA-02, трансформатора Talema 50VA, позолоченных терминалов Neutrik, корпус заводского производства (не самоделка). CD Player (mod), DAC, ZAG : Sapphire (Super mod Buffalo IIISE-Pro - analog full Z-Foil resistive signaling pathway and other improvements).Cables Digital RCA (SPDIF): Oyaide DR-510 (silver 5N),Amplifier's:ZAG : AMB Beta22 Crystal (full Z-Foil resistive signaling pathway and other improvements - Super mod AMB Beta22),ZAG : RoyalGlass (Super mod Panda HA-1MK2),Lehmann BCL (mod).Cables RCA: ZAG : Flame AR7 SPC-Reference SC (PCOCC-A Mono Crystal Copper Wire with solid stranding, Deep Cryo Treated),ZAG : Silver Bullet (??) (Two Wire Gauge, UP-OCC Mono Crystal Silver Wire with solid stranding, Deep Cryo Treated), DAXX R100.Headphones: ZAG : 800SW (capcule sennheiser HD800), Sennheiser HD650, ATH-FC707, Ritmix RH-508.Headphones Cables 4 pin XLR (Furutech) / 4 pin miniXLR (Furutech FT-610mF):ZAG : SA-N7 ADR 2.5 (Silver Angel) (asymmetric diameter ratio of 2.5 hot and cold conductors) (UP-OCC Mono Crystal Silver Wire with solid stranding, Deep Cryo Treated),ZAG : Red Davil 0.6 (UP-OCC Mono Crystal Copper Wire with solid stranding, Deep Cryo Treated). 1 Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
Александр Карелин 3 721 Опубликовано 9 января, 2016 (изменено) А вообще, девочка-старушка Мэнли, стаиается привить вам девочковый взгяд на аудио, а вы: утюги нетолерантные...непризнающие равенства всех семи цивилизованых полов ))) прям ни одного носителя истиной демократии в ветке))) Изменено 9 января, 2016 пользователем Александр Карелин "...сочинение магистра Алькофрибаса, извлекателя квинтэссенции " Наушники: Beyerdynamic T1 2nd Generation, Sony MDR-Z1R, Audio-Technica ATH-CKR9Ltd, кастомные Westone ES60 Усилители: только собственного производства транзисторные и ламповые "Ратша" Плеер: Luxury & Precision L3 Pro (!balanced output!) наушники Audio-Technica: ATH-W5000, ATH-ESW9, ES10(было), A2000x(было), W5000, R70x (было), CK100Pro(было), CKR9LTD, IM04(было), кастомные Westone ES60, Sony MDR-Z1R усилители: Sovereign Reference, Sovereign Baby Reference, Ратша плеер: Teclast T51, HiFiMan HM-801 (было), Pono Player SE(было), Aune M2 Pro (было), Cayin i5 (было) телега 2 Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
pollar 8 807 Опубликовано 9 января, 2016 (изменено) А вообще, девочка-старушка Мэнли, стаиается привить вам девочковый взгяд на аудио, а вы: утюги нетолерантные...непризнающие равенства всех семи цивилизованых полов )))Это правда! То что делал (совсем) старый Менли в ВТЛ, ни чем (ну почти) "не радовало глаз" ТАК как творения Анны Изменено 9 января, 2016 пользователем pollar Philips CD104(винтаж) - MS Audio FHA1.2 - Denon 2000 /всё в разной степени доработано/ 1 Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
zAg 3 251 Опубликовано 9 января, 2016 А вообще, девочка-старушка Мэнли, стаиается привить вам девочковый взгяд на аудио, а вы: утюги нетолерантные...непризнающие равенства всех семи цивилизованых полов ))) прям ни одного носителя истиной демократии в ветке)))Нет в Нас не чуточки - толерантности... этой. Не встроили как-то, за 25 лет, нам этот "чип" в мозг. Продам усилитель для наушников Panda Amp. Classic (новый). Собран из набора Panda amp. KIT с использованием серебросодержащего припоя Oyaide-SS47, кабеля из монокристалической меди Oyaide PA-02, трансформатора Talema 50VA, позолоченных терминалов Neutrik, корпус заводского производства (не самоделка). CD Player (mod), DAC, ZAG : Sapphire (Super mod Buffalo IIISE-Pro - analog full Z-Foil resistive signaling pathway and other improvements).Cables Digital RCA (SPDIF): Oyaide DR-510 (silver 5N),Amplifier's:ZAG : AMB Beta22 Crystal (full Z-Foil resistive signaling pathway and other improvements - Super mod AMB Beta22),ZAG : RoyalGlass (Super mod Panda HA-1MK2),Lehmann BCL (mod).Cables RCA: ZAG : Flame AR7 SPC-Reference SC (PCOCC-A Mono Crystal Copper Wire with solid stranding, Deep Cryo Treated),ZAG : Silver Bullet (??) (Two Wire Gauge, UP-OCC Mono Crystal Silver Wire with solid stranding, Deep Cryo Treated), DAXX R100.Headphones: ZAG : 800SW (capcule sennheiser HD800), Sennheiser HD650, ATH-FC707, Ritmix RH-508.Headphones Cables 4 pin XLR (Furutech) / 4 pin miniXLR (Furutech FT-610mF):ZAG : SA-N7 ADR 2.5 (Silver Angel) (asymmetric diameter ratio of 2.5 hot and cold conductors) (UP-OCC Mono Crystal Silver Wire with solid stranding, Deep Cryo Treated),ZAG : Red Davil 0.6 (UP-OCC Mono Crystal Copper Wire with solid stranding, Deep Cryo Treated). Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
Shadow39 1 083 Опубликовано 9 января, 2016 Самое забавное что с такими ТТХ он вряд ли нормально потянет ту хрень которую на него сверху натянули. Тугие изодинамы точно не его стихия. Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
kleymor.metal 4 775 4 Тракты Опубликовано 9 января, 2016 @Shadow39, говорят, HE-1000 можно как портатив использовать, так что не такие они и тугие. Вот если бы HE-6 натянули... Спойлер Аудиотракт (Hi-End) Динамики ГР-9 военной приемки (винтаж). Усилитель - Интерскол ИСП-200 (7кВт) Портатив: iPhone Chine Limited Edition, наушники родные, провод в оплетке из синей изоленты. Все прогрето в аудиофильской СВЧ от Samsung. Вся музыка приготовлена ручным апконвертом из mp3 (128) в DSD (128). Разницу между t.A.T.u. и The Berzerker слышу! Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
pinh0le 10 935 23 Тракты Опубликовано 9 января, 2016 Да уж, красивый трамплинчик. Как играет - загадка. Ну а вдруг с чем-то средним типа 800-ых лучше не придумаешь? Пыль, кстати, собирать будет неслабо, а вот протирать его та еще морока будет. Куплю: винил: Matti Jurva, Веня Д'ркин амбушки к AKG 812 вертушечка - фонокорчик - усилочек - наушнички 1 Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
kleymor.metal 4 775 4 Тракты Опубликовано 9 января, 2016 @pinh0le, зачем протирать? Усилитель маленький, одной рукой взял, перевернул, потряс над мусорным бачком, вся пыль ссыпалась... Спойлер Аудиотракт (Hi-End) Динамики ГР-9 военной приемки (винтаж). Усилитель - Интерскол ИСП-200 (7кВт) Портатив: iPhone Chine Limited Edition, наушники родные, провод в оплетке из синей изоленты. Все прогрето в аудиофильской СВЧ от Samsung. Вся музыка приготовлена ручным апконвертом из mp3 (128) в DSD (128). Разницу между t.A.T.u. и The Berzerker слышу! Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
pinh0le 10 935 23 Тракты Опубликовано 9 января, 2016 @kleymor.metal, низя так лампы трясти. Куплю: винил: Matti Jurva, Веня Д'ркин амбушки к AKG 812 вертушечка - фонокорчик - усилочек - наушнички Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
8street 392 Опубликовано 9 января, 2016 kleymor.metal, низя так лампы трясти.Они же в космос летали. Хотя я согласен, у меня усилитель со стола упал, эмиссия в одной лампе сильно понизилась. TDA1541, KGSSHV Carbon, SR-009 and the music was electric Продам Wa6Se maxxed. Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
pinh0le 10 935 23 Тракты Опубликовано 9 января, 2016 (изменено) @8street, так это...если с душой тряхнуть, да в перевернутом состоянии, можно вообще лампы из панелек вышибить Изменено 9 января, 2016 пользователем pinh0le Куплю: винил: Matti Jurva, Веня Д'ркин амбушки к AKG 812 вертушечка - фонокорчик - усилочек - наушнички 1 Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
pollar 8 807 Опубликовано 9 января, 2016 @8street, так это...если с душой тряхнуть, да в перевернутом состоянии, можно вообще лампы из панелек вышибить Вот это уже по-взрослому! Всю эмиссию в ведро! :D Philips CD104(винтаж) - MS Audio FHA1.2 - Denon 2000 /всё в разной степени доработано/ Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
Rutger 14 683 18 Тракты Опубликовано 9 января, 2016 так это...если с душой тряхнуть, да в перевернутом состоянии, можно вообще лампы из панелек вышибитьУ меня ребенок пару лет назад из WA6 обе драйвовые лампы "выковырял", на полу валялись с погнутыми контактами. Чуть не поседел вечером, когда обнаружил. Но ничего, работало все исправно после. Система Rutger Спойлер CD Players: PS Audio Lambda Two Special (CDM-9 Pro), PS Audio Lambda Two (CDM-9 Pro), Marantz CD-23F (CDM-9 Pro, 2xTDA1547) / DACs: RME HDSPe AIO (AD1852/CS5361), Wadia 27ix (8xPCM1702U-K + 2xMotorola DSP), Burmester 870 MKI (2xPCM53KP-I, CX23053) / Amplifiers: Beta22 by Helium (Balanced, AMB Delta1 + AMB Delta2), Victor’s Light Voice IZO DHT (6SL7 WGT Sylvania, 2A3-T Mark II Psvane), Sugden Masterclass IA-4 / Headphones: Audeze LCD-4 (4xLitz Cu 500/2xLitz Cu 1200/Silver Coaxial from "Hybrid Audio Cables"), Audeze LCD-2 (NF, ver. 2.5, Rosewood, SAA Endorphin), Beyerdynamic DT990/600 Ohm (VTG), Koss Pro/4 AAA / АС: Coral DX-Eleven (XLO Signature 5.1, 4 x WBT 0703 Cu) / Power: FluxLab Power Supply Station PS-202, БГР (ТТП-350 "Торэл", 2x225В), Accustic Arts Power Strip Passive 6, кастомный распределитель питания (4 EU - Rong Feng/Rich Bay / 4 US - Oyaide R1) / Analog: National RX-7000 Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
