chontvari 1 508 Опубликовано 22 августа, 2020 Такой красавчик и без отдельной темы Specs на англ. Audio: DAC 2 x SABRE ES9028PRO 32-Bit External DAC Functionality Yes, DSD up to 384 kHz / 32-Bit Audio Resolution PCM: 384 kHz / 32-Bit DSD512: 22.5792 MHz / 1-Bit Frequency Response 10 Hz to 40 kHz -0.2 dB (Headphone Out) 10 Hz to 40 kHz -0.2 dB (Balanced Headphone Out) 10 Hz to 40 kHz -0.2 dB (Balanced Line Out) Volume Control Analog Maximum Output Voltage 8.8 Vrms (4.4 mm Balanced) 4.4 Vrms (3.5 mm Unbalanced) 4.4 Vrms (3.5 mm Balanced) Signal to Noise Ratio 125 dB (Balanced Headphone Out) 122 dB (Headphone Out) 125 dB (Balanced Line Out) Custom Equalizer Yes Performance: CPU Octa-Core RAM 4 GB Operating System Android Internal Storage Capacity 128 GB Flash Media Slot 1 x microSDXC Display 5" LCD (1920 x 1080 Resolution) Operation Method Physical Buttons, Touchscreen Media Support: Formats Supported Audio: MQA, APE, FLAC, WAV, WMA, AAC, ALAC, AIFF, OGG, MP3, DFF, DSF, and DXD Connectivity: Wireless Bluetooth 5.0 Dual-Band Wi-Fi Connections: 1 x 1/8" / 3.5 mm Headphone Output 1 x 4.4 mm Balanced Line Output 1 x 4.4 mm Balanced Headphone Output 1 x USB Type-C USB 3.0 Input 1 x 1/8" / 3.5 mm Optical / S/PDIF Output Power: Battery 1 x Built-In Rechargeable Lithium-Polymer Battery 4400 mAh Providing up to 14 Hours per Charge for Audio Playback Charging Time 2 Hours (Digital) 2.5 Hours (Analog) Packaging Info: Package Weight 3.48 lb Box Dimensions (LxWxH) 9 x 6.8 x 4.6" Specs на русском Операционная система и железо: ОС: Android 8.1, Предустановленные APKPure и CoolAPK, ЦАП: двойной SABRE ES9028PRO Выходы: Pentacon 4.4 мм, TRS 3.5 мм, Line Out Pentacon 4.4 мм, SPDIF Coaxial, USB Экран: 5,0 ″ IPS во весь экран (1080 * 1920), с емкостной сенсорной панелью On Cell Передний экран и задняя панель: стекло Corning Процессор: Octa Core Оперативная память: 4 ГБ LPDDR3 Bluetooth: Bluetooth 5.0 Аккумулятор: цифровая часть — 4400mAh 3.8V Li-Polymer, аналоговая часть — литий-полимерные аккумуляторы емкостью 900 мАч 4 штуки с блоком питания 8,4 В Зарядка цифровой части: 2 часа Зарядка аналоговой части: 2,5 часа Micro-SD: SDXC, SDHC Внутренняя память: 128 ГБ Быстрая зарядка для цифровой части: QC3.0, PD2.0, MTK PE Plus Поддерживаемые форматы аудио: MQA, APE, FLAC, WAV, WMA, AAC, ALAC, AIFF, OGG, MP3, DFF, DSF и DXD. (Поддерживает до 32 бит / 384 кГц PCM и собственный DSD до 512x при использовании в качестве USB-DAC) Размеры: 145 x 86 x 27 мм Среднее время воспроизведения: 14 часов (время воспроизведения варьируется в зависимости от громкости, нагрузки и формата аудио) 4,4 мм выход на наушники Выходное напряжение: 8.8VRMS (-108 дБ, 0.0004%, без нагрузки), 8,7 В среднеквадратичного значения (-107 дБ, 0,00045% при 300 Ом) Частотная характеристика: 10 Гц – 40 кГц (-0,2 дБ) S / N: 125 дБ Динамический диапазон: -125 дБ THD + N: 14 дБ (0,0002%) (3VRMS, DAC132, без нагрузки) 113,5 дБ (0,00021%) (3VRMS, 300 Ом) 101,5 дБ (0,00084%) (3VRMS, 32 Ом) Перекрестные помехи: -119 дБ 3,5 мм выход на наушники Выходное напряжение: 4.4VRMS (-105,5 дБ, 0,00053%, без нагрузки) 4,35 В среднеквадратичного значения (-104 дБ, 0,00063% при 300 Ом) Частотная характеристика: 10 Гц – 40 кГц (-0,2 дБ) S / N: 122 дБ Динамический диапазон: -122 дБ THD + N: 114 дБ (0.0002%) (2.5VRMS, без нагрузки, DAC140) 112 дБ (0,00025%) (2,5 В, среднеквадратичное отклонение, 300 Ом) 97 дБ (0,0014%) (2,5 В, среднеквадратичное отклонение, 32 Ом) Перекрестные помехи: -118 дБ 4.4.mm Line Out Выходное напряжение: 4.4VRMS (-112 дБ, 0.00025%, без нагрузки) Частотная характеристика: 10 Гц – 40 кГц (-0,2 дБ) S / N: 125 дБ Динамический диапазон: -125,8 дБ THD + N: -115,4 дБ (0,00017%) (2,6 В среднеквадратичного значения, DAC141) Перекрестные помехи: -115 дБ Инструкция на англ https://drive.google...jkp8CNOKE0/view Последняя официальная прошивка на момент публикации поста http://www.ibasso.co...MaxFW-V1.01.rar Cтраничка Lurker с прошивками по сабжу https://github.com/L...Add-on/releases Обзоры на русском http://audio-ph.ru/r...ez-kompromissov https://porta.fi/ru/...asso-dx220-max/ http://black list/in...?showtopic=2749 Пара обзоров на английском https://headfonics.c...220-max-review/ (есть сравнения с другими топами) https://www.headpie....-unveiling.html Спойлер Мой тракт здесь https://forum.doctorhead.ru/forums/topic/38291 2 Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
avdrool 1 024 Опубликовано 22 августа, 2020 Он такой же нейтральный, как и 220? Т.е. гитары не драйвовые на металле и все такое? MATRIX.usb (AZURE) music streamer - DSC2+DSDit - Lynx ha84 - Кennerton Heartland Dynamic Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
chontvari 1 508 Опубликовано 22 августа, 2020 Я бы не сказал Спойлер Мой тракт здесь https://forum.doctorhead.ru/forums/topic/38291 Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
chontvari 1 508 Опубликовано 24 августа, 2020 Специально сегодня заслушал тяжелые жанры - Мax очень злой Единственно чтобы его сильнее позлить я взял соответствующие уши -ABYS -1266 Громкость понадобилась от 12 до 2 по стрелке часов Спойлер Мой тракт здесь https://forum.doctorhead.ru/forums/topic/38291 Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
donPedro 3 650 Опубликовано 24 августа, 2020 чтобы его сильнее позлить я взял соответствующие уши -ABYS -1266 Позлить или подразнить? "профессор конечно лопух, но аппаратура принём... принём..." Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
chontvari 1 508 Опубликовано 24 августа, 2020 (изменено) Ну ему виднее.По крайней мере AB с ним достаточно естественно себя чувствуют. (слушал с баланса) Все имхо Изменено 24 августа, 2020 пользователем chontvari Спойлер Мой тракт здесь https://forum.doctorhead.ru/forums/topic/38291 Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
chontvari 1 508 Опубликовано 31 августа, 2020 (изменено) Большое ревью от Twister6 включая подробное сравнение с другими топами https://twister6.com/2020/08/29/ibasso-dx220-max/ Изменено 31 августа, 2020 пользователем chontvari Спойлер Мой тракт здесь https://forum.doctorhead.ru/forums/topic/38291 Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
chontvari 1 508 Опубликовано 20 сентября, 2020 (изменено) А тем временем в чехле с крокодайлом Изменено 20 сентября, 2020 пользователем chontvari Спойлер Мой тракт здесь https://forum.doctorhead.ru/forums/topic/38291 2 Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
