PA3BPAT 499 7 Тракты Опубликовано 24 апреля, 2014 (изменено) Просмотр Компонент Изменено 17 февраля, 2017 пользователем PA3BPAT Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
PA3BPAT 499 7 Тракты Опубликовано 16 февраля, 2017 (изменено) Уж не ждал больше ни каких обновлений и вот - Firmware 2016-10-28 08:00:00DA-3000 firmware ver 2.00 - 1.15 MBda-3000_2.00.zip TASCAM has introduced a version 2.0 firmware update for their DA-3000 Master Recorders that brings additional flexibility and convenience to their flagship stereo device. With this update, users may now record to a wide array of media, including SDXC cards with capacity of up to 256 GB. Additionally, ERASE FORMAT has now been added for SD cards, guaranteeing that the card is in its factory-pristine state, protecting against unexpected write slowdowns and recording interruptions.Lastly, version 2.0 enables future firmware updates to the DA-3000 to be performed directly from SD card, providing valuable flexibility when operating outside of the studio environment. The DA-3000 V2.0 firmware update is now available on the TASCAM website. e_da-3000_rn_vd.pdf Изменено 16 февраля, 2017 пользователем PA3BPAT Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
PA3BPAT 499 7 Тракты Опубликовано 16 апреля, 2018 firmware version 2.02 http://tascam.com/product/da-3000/downloads/ V.2.02 fixes• The error occurring during the recording of a track on DD mode on the auto track function where the breakpoint between the track number of the playback CD / MD and the recorded track file were misaligned has been fixed. V.2.01 fixes• If the file type was DSD (DSDIFF/DSF), noise sometimes occurred in the monitoring signal when the IN MONITOR item was set to ON. This has been fixed.• After inserting a CF card, if the card were removed while READING MEDIA appeared on the unit, this message would not disappear for a long time. This has been fixed.• When the INPUT SELECT screen setting is set to SDIF-3 or DSD-raw , noise will no longer be output if a different sampling frequency is received.• Operation stability has been improved. Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
