Черная пятница 2026
Schiit Ragnarok amp, Yggdrasil DAC.
1450317_602291639829463_955766304_n.jpg1451414_602291649829462_1781713052_n.jpg1382241_602291636496130_1565528297_n.jpg
Hey all, a quick update on Ragnarok.
The one that we had with us at the show had multiple problems, including simple mechanical stuff like a loose output connection, and bigger stuff like an oscillating summer. No, not that kind of summer. Summers convert balanced into single-ended output, which is why the SE out on the Ragnarok was unlistenable, and the balanced output was acting, well, odd, and not sounding up to snuff. That's what we get for bringing early stuff. Ah, well.
Here's where we are now: with a set of new production qualifier boards, ready for new firmware and integration this week. If all goes well, we should be able to meet our December ship date. If it turns out we want to make some more tweaks, we may be slipping a bit. This one won't go out until it is absolutely, 100%, no-excuses perfect.
A few photos are attached--the first being the Ragnarok main and control boards without the gain board installed. From left to right on the main board, you're looking at circlotron outputs, drivers, summers, and finally the relay-switched attenuator. The control board on the front has the microprocessor, bias control DAC, relay drivers, indicators, and all the input supervisory circuitry. Not shown are a separate power supply board and the output board for the headphone jacks (minor stuff.)
The second photo is the Ragnarok main and control boards with the gain board installed. Since it's modular, we will eventually be able to offer a hybrid version with tube input, though this will require a separate transformer and additional power supply, so it's not exactly plug and play. It also means we could change the gain board over time, though analog moves much, much slower than digital as far as big changes in technology.
PC (foobar2000) >> iBasso D14 Bushmaster >> UE900
My music on soundcloud (Up to 32/192 .wav)
My music on bandcamp (Up to 24/192 .flac/.wav/.aiff)
Digital collection
CD's collection
Current:
DAC/Amp (portable): iBasso D14 Bushmaster
IEM: Logitech/Ultimate Ears UE900
IC: Audio-gd Balanced Interconnect Assembled Cable (1m)
S/PDIF Cable: Revelation Audio Labs Prophecy Cryo-Silver™ Reference S/PDIF Digital Link cable (BNC-RCA, 0.5m)
Power Cables: 2 x Oyaide EE / F-S 2.6 SE (Oyaide-037e/037) (1.5m)
Wall Socket: Furutech FT-SWS-D® Carbon
USB Cable: Artisan Silver Cables "Ultimate Silver Stream" pure silver USB A to USB B cable (cryo, 1.25m)
Hi-Fi Rack: MetalDesign MD 108-5
Last:
Headamp: Schiit Audio Mjolnir
DACs: Audio-gd NFB-10SE, Matrix Audio X-Sabre
DAPs: QLS Electronics QA350, Colorful Colorfly CK4
Headphones: AKG K27i, Sennheiser HD280, Sennheiser HD595, HiFiMan HE-300 Rev.1, HiFiMan HE-6, HiFiMan HE-400i, Sennheiser HD800
Headphone Cables: Revelation Audio Labs Cryo-Silver™ Reference Headphone cable (HE-Series, 4-pin XLR balanced, 3m), Artisan Silver Cables "Silver Dream" Mark 2 (cryo, HE-Series, 2 x 3-pin XLR balanced, 3m)
IEM: HiFiMan RE-0
USB-S/PDIF Converter: Anedio U2
S/PDIF Cable: Audio-gd Canare Coaxial Cable
IC: Revelation Audio Labs Paradise Cryo-Silver™ Reference Balanced Interconnect cable (0.5m)
  • Ответов 79
  • Просмотры 30,7k
  • Новые фото... PS: решается вопрос об анодировании. Есть шанс что Ragnarok будет без него, таким блестящим, как на фото...
  • @myrgab_8593, Ваши требования подходят лишь под один термин - проверка работоспособности. Спорить о чем то другом не имея за спиной сравнительного опыта многих сотен устройств/кабелей занятие почти бе
  • @Ragnar-BY, дело не в том кто виноват, а то что покупатель лишается права выбора, как только появляется дистрик (со своими тараканами, аппетитами, проблемами с растаможкой и т.д.) он как правило "наст
Кто что по потрохам скажет? Я смотрю ни у mj ни у Рагнарока нет радиаторов совсем. Нигде не заявлено, что это усилитель класса А. Стало быть AB. Сложно представить класс А с такой мощностью без радиаторов. А раз по мощности Рагнарок равен балансному b22 с Ку=11, то все же стоит смотреть в сторону b22, работающем в классе А :think: Получается вся основная прелесть старших шиитовских усилков в их топологии цирклотрона, а на деле b22 может вытянуть больше микродеталей? :notknow:
Digital collection
CD's collection
Current:
Last:
IEM: HiFiMan RE-0
  • Администраторы
Радиатором скорее всего служит корпус как у BursonAudio. Что очень правильно.
На фото видно что транзисторы на нижней части платы.
Писали, что прототип грелся как утюг, конечно автор оправдывался как мог, мол несправность и все такое, но осадок остался. Что-то по фотографиям не впечатляет, очевидно, что усилитель не all-discrete, аудиофилом такое не по вкусу. ф
На прошедшей выставке CanJam в конце 2012 года было много переговоров в том числе и с Woo Audio. Но не все производители готовы работать с Россией и давать возможность заработать.
Может быть в этом году что то и получится, благо у Shiit появились дорогие компоненты.
Нет ли новостей в этом вопросе ?
Стоит ли ждать рагнарёк и другую продукцию Shiit в ДХ в следующем году?
  • 2 weeks later...
Не факт, что не all-discrete. Микрухи в корпусе DIP8 могут быть вообще не опампы, а что-то другое, а во вторых, в Lyr тоже есть опампы, но они служат для управления DC напряжением и совсем не влияют на звук.
Усилительная плата Рагнарока как раз полностью дискретная.
Имхо бета22 все равно покруче будет, и намного... Хоть и нравится мне продукция Schiit. ;)
Изменено пользователем Helium
Ваяю AMB Beta22, KG Dynahi, KG Dynalo, KG Krell KSA5, KG CFA, KGSSHV Carbon, KGST, KG Grounded grid, KG Blue Hawaii, STAX SRM-T2 и т.д.
Наушники: Sennheiser HD800/HD800S/Hifiman HE-500/HE-5XX/Audeze LCD-XC/Fostex TH900mk2/Sennheiser IE-80S
  • 2 months later...
Новые фото...
Digital collection
CD's collection
Current:
Last:
IEM: HiFiMan RE-0
Павел, про Yggdrassil известно, на каком камне выпустят, с каким usb?
Иггдрасиль может быть и вообще не на камнях. Например проприетарная дискретная R-2R. Во всяком случае было сказано, что точно не на Asahi Kasei. Впрочем пока никаких деталей. Джейсон обещал поделиться информацией о нем в ближайшее время...
Digital collection
CD's collection
Current:
Last:
IEM: HiFiMan RE-0
  • 2 years later...
Есть тут владельцы гидрасила? Его вообще где-то модно купить в Москве предварительно послушав?
Наушниковая: Soundaware d100/Metrum Pavane/РАТША/Sony Z1R
Большая 1: Metrum Pavane/Audio Note OTO Phono SE Signature /Audio Note AN/E spe HEMP
Большая 2: Metrum Pavane/Audia Pre/Audia Flight 100/?
Питание: Flux Labs 1700/500/200 +Torus Power RM16
Портатив: Cayin N6 + Westone UM 50 Pro (Cu Litz cable, 44Sound plugs)
Сомневаюсь что они вообще в России есть с дебильной политикой Шиита неотправки в Россию. Как и Рагнароки. Плюс отзывы не айс.
Nad M51 _ Sennheiser HDVA600 _ Sennheiser HD 650.
Ruizu 05, 06 _ Kennerton Jimo.
Вот, кстати, может кто-нибудь Yggdrasil поругать? Хотелось бы почитать критику этого ЦАП, а то пока только сплошь хвалебные оды и молчаливое одобрение встречал.
Тракт: Lynx Hilo USB => Fostex TH900
Портатив: XDuoo X10AE => Noble Kaiser 10C
Было:
Транспорты:
Berkeley Alpha USB
Lynx AES16
ЦАП:
Berkeley Audio Design DAC Series 2
North Star Design DAC Extremo
Meier Audio Corda StageDAC
Creative X-fi Elite Pro
Усилители:
Mjolnir Audio KGSSHV (450V, Sanyo parts)
Headamp GS-X MKII
Audio-Technica AT-HA5000
MS Audio Laboratory FHA 1.3
MS Audio Laboratory FHA 1.2
Наушники:
ATH-W2002 #0836
ATH-W2002 #0389
ATH-W3000ANV #1120
Audio-Technica ATH-W5000 (три пары)
Audio-Technica ATH-ESW10JPN
AKG Q701
Beyerdynamic T1
HiFiMan HE-6
Sennheiser HD580
Портатив:
AleXmod #2
Sony Discman D-311
Cayin i5
Sennheiser IE4
Sleek Audio SA6
Westone W20
Westone 3
TDK BA-200
Поругать-то любой может :) , только реальных владельцев в России вроде как и нет. По крайней мере на ДХ.
Изменено пользователем Remilio
@Remilio, а мне как раз не особо интересны мнения реальных владельцев. Если человек купил, значит ему ЦАП понравился, а хотелось бы узнать почему не стали покупать те кто рассматривал такую возможность. А еще интереснее почитать критику по схемотехнике, задействованным решениям, и т. д. Я только по реализации USB владею информацией, она посредственная, но для меня это не фатальный недостаток, например, никто же не мешает использовать Berkeley Alpha USB.
Было:
Транспорты:
Berkeley Alpha USB
Lynx AES16
ЦАП:
Усилители:
Headamp GS-X MKII
Наушники:
ATH-W2002 #0836
ATH-W2002 #0389
ATH-W3000ANV #1120
AKG Q701
Beyerdynamic T1
HiFiMan HE-6
Sennheiser HD580
Портатив:
AleXmod #2
Sony Discman D-311
Cayin i5
Sennheiser IE4
Sleek Audio SA6
Westone W20
Westone 3
TDK BA-200
@Nifrigel,
Есть небольшая критика о зернистости звука в сравнении с аппаратом на АКМ: https://parttimeaudiophile.com/2016/01/30/review-aune-s16-dac/
Система:  Teac R-9000 (Яуза 220) - Audio-GD Master 9P- Dali Opticon 2 MKII (Амфитон ТДС-7).
Были: Aune S16, Lynx Hilo LT-TB3- MS Audio Laboratory FHA 1.5, Unison Research SH, Audio-GD R-7HE MK2 - Cayin HA-3A; Focal Spirit Professional, Fostex TH900, Sennheiser HD800, Ken..ton HeartLand
балансный ЦАП на базе 4-х AD5791 c дискретным буфером и цифровом фильтром на базе SHARC DSP, данный чип применяется в медицине (МРТ) и в военной промышленности..
Потрошки (для тех, кому лень гуглить)
Аудиотракт (Hi-End)
Портатив:
И стоит даже при заказе в 50 штук на маузере целых 78 евро за один.
Если это поможет, хотя и не совсем в тему. Как-то мой друг Эд покупал усилитель для наушников у этой конторы. Модель, если не ошибаюсь, Asgard 2. Началось все с того, что он попал на смену версий. Поэтому честно оплаченный заказ завис на неопределенный срок. На вопрос, когда можно ждать отправки усилителя был получен спустя неделю ответ "ой, не знаю, да не парься, когда-нибудь будут они, сейчас пока нет, тут немного дела тормознулись, но отправим обязательно" - буквально в таком тоне. Ладно, не прошло и пары-тройки недель, как усилитель был отправлен. Через положенное время он приехал. Сразу выяснилось, что в наушниках есть гул. Этот гул проявлялся то тише, то громче. У меня дома почти совсем не было, у Эда было все заметно хуже. Представитель конторы ответил на вопрос так: "не знаю, у нас все окей, это у тебя электричество плохое, смирись". Вдобавок, на корпусе усилителя с отделкой алюминия под сатин оставались не стираемые никакими средствами отпечатки пальцев. На вопрос "что это, б...ь?" был получен из-за океана ответ, что "ну не знаю, жалоб не было, ты первый такой".
Если бы все это окупалось каким-то особым качеством звучания или хотя бы чуть большим, чем средним bung for the buck, то ладно, но звук был, мягко скажем, достаточно серым, впрочем, и цена была не высока. Усилитель был позже выставлен на продажу, разумеется, не скрывая косяков по корпусу и с обещанием вернуть деньги, если владельца побеспокоит гул, но видимо он оказался вполне доволен (еще бы, скидка была более половины цены).
После этой истории у меня полностью пропал к данной конторе интерес, хотя ранее планировал их ЦАП к покупке.
Мой канал в Telegram
https://t.me/hifiaudio
Мой канал на Youtube
https://www.youtube....O_jZbHflAzcc5Vg
  • 1 year later...
У меня сейчас Yggdrasil DAC и Молинор 2. Правильно Амеры написали yurivv ""ну не знаю, жалоб не было, ты первый такой".
Нет ни каких проблем, взял и протер тряпкой корпус и следов не видно.
Yggdrasil DAC мне нравиться, сравниваю на стационаре: Audio Note CD 2.1xV2, Legacy Audio Signature SE, Pass Labs NT30 c винилом.
Детализация прекрасная, басы очень натуральные. Единственное не привычно - на каждом треке реле щелкает, амеры говорят, что входы закрывают якобы от перегруза.
У Schiit всегда серьёзные проблемы с качеством были, первый Asgard 1 который я заказал у них сдох через 10 минут работы, замену выслали сразу, полностью возместив издержки, этот Асгард 1 до сих пор жив, держу как запасной. Хороший, музыкальный усилок за свою цену, говорят второй Асгард скучнее. С первым Бифростом проблем вроде не было, но я его быстро продал. Потом купил первый Mjolnir, у него был заметный шум в одном из каналов, у присланного на замену всё было ещё хуже, отправил назад, мне вернули деньги и все издержки за пересылки тоже возместили, а через пару дней я прочитал что они к нам больше не отправляют :)
К тому же MJ1 по звуку мне не понравился, очень скучный аппарат, предельно нейтральный, детальный, с огромной сценой, но извините, слушать на нём Led Zeppelin и натурально засыпать это уже диагноз. с асгардом такой фигни не было. Думаю Mj2 должен поживее звучать.
Потом решил чисто из любопытства купить обновлённый мультибитный Бифрост, что я и сделал через сервис пересылки. У аппарата естественно были проблемы с фоном, не сильные, но заметные, на высокой громкости немного шипел, что правда не помешало ему отправить мой гораздо более дорогой Nad M51 на продажу буквально через пару дней :)
Продал его через год где-то, у нового хозяина проблем с шумом не возникло.
Заказывать технику Schiit напрямую у производителя через всякие сервисы пересылки сейчас безумие, про большое количество брака всем давно известно, а с тех пор как они приобрели популярность, они стали куда менее лояльны в вопросах обмена и возврата, особенно по мелким по их мнению поводам.
Изменено пользователем Grizly
До молинор 2, у меня асгард 2 был, сейчас продаю.
На молинор 2 путем замены ламп в небольших пределах можно подобрать звучание, но не в больших конечно (это на мой средний слух).
А с железками, конечно как повезет -даже думать страшно и не говорите, особенно, когда все за бугром.
Я зарёкся покупать сложную технику с гипотетической возможность брака за рубежом. Даже с компенсацией за пересылки время и нервы того не стоят.
Оба основателя (они же главные инженеры) Schiit есть на Head-Fi. Оба ведут блоги, общаются, отвечают на вопросы. Стоддард (главный по усилителям) уже целую книгу собрал из своих записей. Моффат (главный по ЦАПам) пишет меньше, но тоже интересно. Я начал читать, залип на пару дней - очень интересно, и сама история откуда они взялись, и масса подробностей по техническим реализациям, почему что-то сделано так, а не иначе. На Head-Fi у них уже целый фан-клуб собрался и небезосновательно. Немного обидчивые на критику, но все вопросы, которые всплывали на форуме, решали. Деньги недовольным возвращали, аппаратуру чинили/меняли и т.д. В целом, я бы сказал, что хорошая компания, с правильными целями.
Шипел по USB? Если так, то у них сейчас новая реализация USB-входов. У меня есть Schiit Wyrd (там такая же развязка, как в USB-интерфейсах их ЦАПов), от него ЦАП включён - разница очень большая по сравнению с USB напрямую. Wyrd фоновый шум компьютерного USB полностью убрал.
Изменено пользователем Ragnar-BY
Шипел во всех входах. USB у него хороший, даже Gen2, но я в основном через Stello U3 слушал.
