Александр Н
Пользователи
  • Зарегистрирован
  • Посещение
Весь контент Александр Н
  1. Ещё одна реставрация миланского Кольца Фуртвенглера 1950 года. На этот раз от Эдуардо Чибаса, профессионального дирижёра и Президента Вагнеровского общества Венесуэлы. Опубликована запись в формате FLAC (16 bit 44,1 kHz) четырьмя частями на сайте "Furtwangler Sound", который сам Чибас посвятил своим же реставрациям записей Фуртвенглера: http://furtwanglersound.com Работа более чем достойная, сделана очень аккуратно. По моему мнению, на сегодняшний день она является лучшей в отношении к этой записи. В отличие от версии Эндрю Роуза (Pristine Classical) выполнена без стереофонизации, раскрашивания и чистки в ущерб оригиналу. Ниже привожу в оригинале ответ Эдуарда Чибаса на вопрос об источнике, использованном для реставрации: I used a CD as the source. I don’t like to say exactly which to avoid problems, but I can tell you what I look for and what I have to do. First of all I look for a version that is as dry as possible, since one can put in ambience, but one cannot take it out. I found a fairly dry version that unfortunately had terrible equalization. This can be remedied, but it too me a long tima. I can tell you that I worked on this Ring for a couple of years until I was satisfied with the result. I had a lot of problems with the EQ because it was an unusual one, so it took great deal of trial and error to neutralize it. Then I equalized it correctly and put in some ambience to give it a more natural sound. It was a lot of work to get the dynamics right. Very old live recordings often have problems with dynamics. Recording equipment at the time had a narrow dynamic range, so that recording engineers had to correct the recording volume during the performance to prevent saturation, but keep it loud enough to hear the soft passages. Some times it is done well, others not so well. There are times that there were volume adjustments that were unnatural and had to be corrected. Particularly bad in this regard were the third acts of Die Walküre and Siegfried. People who restore these recordings rarely if ever take this into account. Another thing I work on is trying to find nodes from the hall acoustics. One needs to find the frequencies. When you correct that, everything sounds more natural and you can increase the bass without overloading. The Ring had some additional problems from distorted passages that gave me some grief as well. But the effort was worthwhile since I think this is the greatest Ring ever recorded. Furtwängler is at his best and the singers are fantastic. Even the orchestra, playing music not familiar to them, were terrific, playing with great passion and commitment.
  2. Греть 150 часов, а лучше пару лет, чтоб гарантия кончилась. За такой срок некоторые люди пары три-четыре наушников меняют )
  3. В этом же флаконе ещё и салат Оливье... Главное - разложить "по полочкам" (во-первых, во-вторых, в третьих).
  4. На вход RCA внешнего усилителя нужно подавать сигнал с линейного выхода плеера, а не с усилителя. это как? все подавал с выхода на наушники. А зачем использовать балансный выход вместо выхода для jack 3,5 ? Для RCA-входа разницы уже не будет. Через усилитель тогда соединятся и заземлятся клеммы (-). Чревато или не чревато для плеера - одному Богу или создателю схемы плеера известно.
  5. Хотя бы скидку в цене установили для этого экземпляра? Галоши, хранившиеся внавал, может и восстановят свою форму, а здесь - сомнительно...
  6. Вроде недавно только поздравляли с Днём рождения... То ли время так быстро летит, то ли у вас этих Дней рождения несколько в году?! Тем не менее, с прошедшим! Не снижать активности! Даже если судить по этому форуму она, эта ваша активность, так и прёт
  7. На мой взгляд, все эти теоретические разговоры про "верить" или "не верить" в некий "эзотерический" прибор не несут какой-то глубокой смысловой нагрузки. Более правильно и корректно, проверить это влияние самому, на своем тракте и своими ушами на практике убедиться, есть разница и изменение звука в лучшую сторону или нет. А уж что и на что влияет и почему, это уже вторично. Мой взгляд на это устройство был лишь техническим и опровергающим примитивные суждения "Заземление - есть ломы, вбитые в землю", а именно с точки зрения достижения потенциала на корпусе, близкого к нулю путём создания элементарной электрической цепи. Поэтому здесь я всё же максимально близок к "верю". Далее - способность тех или иных ушей почувствовать изменения опытным путём.
  8. Лучше))) Эта штуковина, кстати, здесь на форуме уже обсуждалась несколько лет назад. Про веру и неверие в неё...
  9. Если дойти до определённой стадии оформления заказа, то со стоимостью доставки станет ясно. Цена зависит от выбранного способа отправления. Есть один минус - мистер Дрю отправляет относительно долго, может и на пару недель затянуть.
  10. Может кто обратил внимание на появление таких фирменных сменных кабелей Audio-Technica? А может кто уже и попробовал? hdc_en.pdf
  11. Очередной выпуск отреставрированной Эндрю Роузом (Pristine Audio) записи Мастеров Ойгена Йохума 1949 года в формате Ambient Stereo. https://www.pristine...roducts/paco145 Редкий случай исполнения Хансом Хоттером партии Ганса Закса. В более поздней байрейтской постановке 1956 года (Андре Клюитанс) он уже воспринимается как Странник (Вотан), забредший в средневековый Нюрнберг.
  12. Евгений! Корифей форума! С Днём рождения!
  13. В этой записи ещё особо отмечают интерпретацию увертюры как наиболее верное прочтение, а именно темп, в котором она исполнена. Кстати, здесь на форуме есть особенная ветка "Вагнеровский театр".
  14. На мой взгляд, байрейтский Тангейзер Заваллиша 1962 года - безусловно лучшее исполнение прошлого века. Ещё интересен Тангейзер Брайзаха 1944 года из Метрополитен Опера. Но опять же, это лишь архив...
  15. Ну а другие записи из этой серии "Яновский взялся за всё сразу и разом" удалось послушать? По мне, так кроме Лоэнгрина и Мейстерзингеров мало что интересного в ней есть.
  16. Компания Warner Classics выпустила новую реставрацию Голландца Отто Клемперера 1968 года в формате 24bit 96kHz https://www.prestocl...gende-hollander Возможно кто-то начинал своё знакомство с вагнеровскими операми именно с этой записи.
  17. Да и я ему посылку отправил буквально в конце июля... Неожиданно как-то...
  18. А что же произошло? Есть подробности?
  19. Самое интересное (или даже забавное) в том, что признанные лучшими дирижёры-интерпретаторы Вагнера имеют хоть какую-то степень родства с евреями. Взять тех же Артура Боданцки и Георга Шолти...
  20. Кто мне может аргументированно ответить на вопрос: являются ли медиа-плееры АК шифровальными или криптографическими устройствами?
  21. Но пожить-то наверняка ещё хочется. И подольше, чем плеер )
  22. Вот только при вопросах "в лоб" Эндрю Роуз почему-то всегда убегает. И на самый главный из них - "Что вы использовали в качестве первоисточника?" - молчание. Существует мнение, что он попросту перезаписывает чужие реставрации, добавляя акустический эффект. Отмечают также, что записи, выпущенные M&A, он просто попортил, поскольку они и без его вмешательства очень хороши.
  23. Экий смысл получился у надписи под коробкой на предпоследнем рисунке... )
  24. Компания Deutsche Grammophon выпустила запись байрейтского Тристана Карла Бёма 1966 года в формате Hi-Res FLAC 24 bit 96 kHz: http://www.prestocla...uk/r/DG/4797530 Запись давно считается одной из самых популярных и рекомендуемых. Вокальный состав в целом настолько силён, что постаревший Виндгассен является в нём чуть ли не слабым звеном. Лучше Кристы Людвиг в партии Брангены разве что она сама в более поздней караяновской студийной записи. Для Мартти Тальвелы роль Марка в этой постановке - высшее достижение. Эберхарда Вехтера, на мой взгляд, можно признать лучшим Курвеналом прошлого века (голос Фишера-Дискау в других записях слишком интеллигентен для этой роли). Сложно пройти мимо после прочтения рецензии Светланы Поповой: «Данная запись - один из памятников последней великой эпохе вагнеровского пения… Запись производит поистине шоковое впечатление с первых минут. Ураганные темпы, наэлектризованный бушующий оркестр, невероятной силы и экспрессии стальной голос Нильсон (с аналогичной Брангеной - Людвиг) приводят слушателя в трепет».
