iow
Продвинутые
  • Зарегистрирован
  • Посещение
Весь контент iow
  1. Aune S18 поступил не так давно в открытую продажу, в том числе на крупнейшем интернет-аукционе по цене $500 с бесплатной международной доставкой. Увы и ах, но фотографий внутренностей железочки сходу найти не смог, так что любимую форумную игру (лечение по фотографии) придётся отложить. Может, в процессе появятся владельцы, как знать? Никто не хочет заказать? Aune S18 32BIT DSD Music Player Asynchronous (CPLD) Dual clock Fidelity Digital Turntable High-quality multi-format mastering-digital turntable Pure hardware solution asynchronous clock technology, the use of data reorganization algorithm for audio S18 has the very end of the digital jitter and perfect digital waveform, while near the top in particular the use of analog tuning dial, is a turntable that can besubstitute for high-quality digital CD turntable S18 is an Hi-Fi turntable with the music that alternative to traditional CD turntable S18 is a mastering-HIFI dial multiple audio formats S18 is an included CD disc formats, but support more digital HIFI turntable mastering format S18 supports WAV / FLAC / APE / AAC / DSD and other multi-format S18 is a HIFI turntable that support 32BIT and DSD highest formats S18 can play up to 32BIT music files, and supports DSD file format DSF / DFF / ISO playback, support coaxial output DOP (DSD digital format) S18 uses a purely digital technology hardware solution S18 uses an ARM chip and a CPLD chips machine hardware framework ARM is a pure hardware decoding codes, ARM asynchronous clock signal input CPLD chip technology reforming, Asynchronous clock technology allowshardware solution with a high numerical targets S18 S18 uses two ultra-low jitter clock crystal Verification of the entire digital circuit is a clock crystal, S18 using two ultra-low jitter clock crystal clock and asynchronous technology with completely beyond the traditional CD turntable S18 with numerous digital output interface S18 with a group of RCA, a group of BNC, a balanced set of numbers, a set of digital optical interface S18 with full balanced output interfaces IIS S18 uses ultra high-speed full balance IIS output , the most high-speed transmission of HDMI interface, support for long-distance transmission, with higher speeds and longer distances than other IIS turntable S18 uses 2.8-inch display and full remote control technology S18 with a full perspective of the large 2.8 display and minimalist UI design, completely empty external remote control technology, is a very good man-machine interface of digital turntable, the machine includes a traditional analog dial operations, with more features S18 has excellent indicators and excellent sound calibration when playing 24BIT / 192K signal , the digital output jitter is 3.4NS, THD + N-138DB, reached the limit index S18 supports more comprehensive formats ,support the DSD format and DOP output S18 supports up to file playback 32BIT / 96, while supporting DSD 64 of DOP coaxial output, with a balance transfer IIS port provides two-way coaxial output interface (RCA + BNC), is a multi- interface multi-format digital turntable Note:32BIT coaxial can not be transferred because the coaxial agreement can not be reached so high, only IIS transmission, DSD can play in the coaxial port transmission, but it needs the DAC that support DOP interface Front Panel View 1.1 2.8 Display 1.2 Power indicator 1.3 remote control receiver window 1.4 Power Button 1.5 Main Menu button 1.6 on the button, the playback mode, previous / rewind When the file browser mode, select the previous 1.7 keystrokes, playback mode, Next / Fast Forward When the file browser mode, select the next 1.8 Enter / Play / Pause When play mode, play / pause, file browsing mode, it is determined 1.9 SD card connector Rear Panel View 2.1 IIS outlet 2.2AES digital output 2.3 coaxial output 2.4 optical output 2.5 backup WAN port (can not be used now) 2.6 AC input Special Note: Press 2 seconds for a long time, turn on the power; press two seconds for a long time,turn off the power When the play mode, enter the main menu, to return to the previous menu
  2. Даже нет смысла сравнивать, принципиально разные лиги, если говорить о наушниках под классику. 900-е и технически выше, и по уровню комфорта дадут фору любым светлым ушкам.
  3. iow ответил jammer тема в DIY
    Тут кто-то уже критиковал сборку эту. Сам бы не стал брать кота в мешке без возможности предварительной прослушки. Ну, и с высокой долей вероятности там РГ не ахти, какие-то полумеры получаются. Да, кстати, когда я искал усилитель, то заходил в барахолке в раздел посвящённый усилителям, а не "Наушники -> для дома".
  4. Где такую музыку брать, нигде не нашёл. Интересно. Не уверен, что здесь можно давать прямые ссылки, но такой контент за пределами трекеров ищется лучше яндексом, чем гуглом, подойдёт такой запрос: "British Murder Boys - 2015 - Collected Recordings". В dark electro не разбираюсь, но компиляция любопытная.
  5. На первый взгляд, список состоит из имён, названий альбомов и лейблов...странное сочетание! И что???? Это же все музыка, которую легко найти)))) Я искал и выложил то, что понравилось. А как еще-то? Лучше лейблы отдельно, исполнителей отдельно, названия альбомов отдельно, иначе юзеры, зашедшие в тему, просто толком даже не поймут о чём речь.
  6. Это кусок из Le Grand Macabre, оперы Лигети. Я предпочитаю запись из Ligeti Eidion 8, начало фрагмента в этом случае - 2-й диск и 4-й трек, где-то с 25-й секунды. Эта опера, имхо, не ахти какой образец современного авангарда.
  7. Похожие впечатления были от dCS. Дикое разрешение при существенно возрастающем комфорте звучания, будто у других ЦАПов детальность включает в себя какие-то искажения, а тут всё чисто-ясно. И что касается "звуков без локализации", то тоже имелся похожий эффект, я бы назвал это очертанием образов, их объёмом. Как условный пример: иногда в dark ambient слышно гудение, но с хорошим ЦАПом мы очень ясно ощущаем буферную зону между слушателем и объёмным источником звука, имеющим различимые очертания и находящимся на строго определённом от нас расстоянии.
  8. У нас на форуме, кстати, продаётся Yamamoto Ha-03. Насколько я понимаю, этот усилок как раз отлично подходит под W5000.
  9. @Andrey23, на современных жанрах для меня 900-е ярковаты, но это, наверное, индивидуальное.
  10. Я могу. У хешек на хорошем усилении значительно выше разрешение и меньше искажения. Это очень отчётливо слышно. Конечно, каких-то потерь музыкальной информации у 900-х нет, более того, за счёт грамотной АЧХ фостексы вытягивают многие важные нюансы и обогащают тембры. Хайфаймены звучат на таком фоне блёкло и очень сдержанно, тембрально бледно особенно по сравнению с насыщенным цветастым звуком фостексов. Хешки больше склонны к яркости в области пиков, то есть случайный громкий всплеск флейты может заставить подпрыгнуть при недостаточно точном выставлении уровня громкости, в 900-х всегда очень комфортно и уютно - на моей памяти это первые наушники, которые совершенно не ярчат, но при этом не звучат ватно-тёмно. Особенно очень грамотно у них сбалансирована середина и переход к ВЧ. Тембрально, конечно, 900-е чуть высветляют звук, но это не удаляет их от натуральности и совершенно не сказывается негативно на восприятии живых инструментов. Сцена естественная у 900-х, концертная, находится спереди, хорошая локализация, в то время как шестёрки чуть разносят звуки по каналам - аудиофильский вариант. Имхо, хешки рвут немного центр, во всяком случае с беркли (с ЦАПами на сабре это было меньше заметно). У меня было сразу два экземпляра 900-х. Что удивило - кажется, будто в два раза различалась громкость на НЧ. Понятия не имею, с чем это связано, с разбросом экземпляров или с прогревом, но некоторую музыку на басовитом экземпляре фосткесов было слушать очень тяжело, порой физически невозможно. Немного различались и в области ВЧ. Басовитый экземпляр был на высоких мягкий, едва заметно тягучий при сохранении кристальной ясности, а второй экземпляр поострее. Ещё втыкал 900-е в некоторые другие устройства. На родном комбайне (и на айпэде ) 900-е звучали колко и немного кислотно. Слишком уж существенный урон реализму и это очень быстро утомляет, даже если очевидных всплесков яркости не наблюдается. Я долго их вместе сталкивал. В своём тракте на классике всегда предпочту фостексы. Хешки больше нравятся на современных жанрах, но, честно говоря, я их редко слушаю.
  11. Та бета, которую вы слушали, была, вероятно, в четыре раза менее мощной по сравнению с балансной. Так что обычные варианты беты точно отпадают. Не думаю, что тут стоит изобретать велосипед - просто достаточно погонять АКГшки с колоночными усилками, которые попадутся под руку. Выбор-то из них большой.
  12. На первый взгляд, список состоит из имён, названий альбомов и лейблов...странное сочетание!
  13. У вас какой КУ? 8? Пару раз об этом писал, но уже не помню.
  14. Так 24 ватта - это мало. Даже если взять балансную бету, которая прилично мощнее Unison Research (112 ватт, из которых 50 ватт самим разработчиком считаются "чистыми"), то её, на мой слух, не очень-то хватает для К1000. Имхо, синергия синергией, но надо выбирать из усилков помощнее.
  15. Сейчас уже можно смело говорить о возрождении интереса к индустриальному техно. На этой волне в феврале сего года хорошо известный поклонникам жанра прожект British Murder Boys выпустил знаковую компиляцию. Пожалуй, пока именно это событие можно считать главным на "околотехно" сцене. http://www.youtube.com/watch?v=3vGjBtpg0Sc Ещё из свежих пластинок индустриального техно можно выделить Tzusing - A Name Out of Place Pt. II: http://www.youtube.com/watch?v=P6AR0M6Ktzw&index=1&list=PL2BGnJf-ac3QiU5UbC98-YWnO0Bm6d-lO , ремикс от Regis выше всяких похвал: Наверное, такая музыка мало кому интересна, могу вечером написать про что-нибудь более попсовое из релизов текущего года. PS - можно только два видео вставить, беда-беда!
  16. @pinh0le, интересно как 900-е на разные тракты реагируют, включая тот же портатив.
  17. Надо было слушать даркстар по балансу!
  18. Для классного звука. Ну, какая, по большому счёту, для нас разница из-за чего наушники играют от усилителя лучше по балансу нежели небалансу? Это актуально для разработчиков, а не конечных пользователей. Лампа, транзистор, баланс, небаланс - всё это пустое, я не вижу никакого смысла об этом много думать. Я ведь некоторое количество усилков перебирал, которые покупать не собирался, а балансная бета просто случайно оказалась пугающе хороша с хайфайменами. Уж как так случилось и почему - до конца знать не могу, но четырёхканальная версия беты от двухканальной отличается - чем бы вы думали? - правильно, числом плат. Разница действительно очень большая, это не домыслы и не заблуждения, а практика энного числа слушателей. Может, кому-то такая информация полезна.
  19. Да там всё нормально, вот фотографии экземпляра. У меня был точно такой же усилитель. Просто новый он стоил 45к, сам при продаже скидывал неохотно, но сейчас другие реалии, другой доллар, всё поменялось. Сравнивал лично со своей четырёхканальной бетой, собранной по феншую, по TRS они действительно очень похожи, то есть я не думаю, что есть какая-то реальная качественная разница, учитывая, что в усилке Энергетика стоит альпс, а у меня всё-таки голдпойнт. Хочу, конечно, подчеркнуть, что это усилитель по мотивам беты, а не именно что сборка беты. Для многих это важно.
  20. Если позволяют финансы, то можно купить 2-3 усилителя на вторичке. Вот, например, адекватное предложение двухканальной беты. Сборка известная, пользуется стабильным спросом, ценник чуть сбить бы. Подводные камни очевидны - пользователь с 0 сообщениями, нужно с него требовать аккаунты на аудиофорумах. Ещё у нас тут продают SPL Auditor. Затрудняюсь сказать, какой сейчас будет адекватный прайс, но цена выглядит разумной. Есть те, кому этот усилок с 800-ми категорически не нравится, но, например, форумчанин borlebsin (композитор и преподаватель музыки) любит эту связку. Из минусов: Auditor'у противопоказаны тугие и низкоомные ушки, то есть помимо 800-х к ним не так и много ушей подключить можно. Тут же лежит Violectric Hpa V-200 за 30к. Усилитель известен тем, что его использовали в процессе разработки 800-х, то есть он в достаточной степени должен быть согласован с наушниками. Все три варианта - приличный средний уровень для 800-х по весьма умеренным ценам. EF-6 никак не прокомментирую, не помню, слушал ли его, но у него имидж оверпрайснутого продукта, не пользующегося на наших просторах большой популярностью, что делает его покупку достаточно рисковой затеей.
  21. Представительнее было бы сравнение скорее с чем-то типа Асгарда 2 - выделенный усил за схожие деньги. А есть ли смысл в начальном сегменте разделять усилитель и ЦАП? Недорогой комбайн - это классное универсальное решение для входа в мир персонального аудио, а иногда и end game.
  22. Те, кто могут написать любопытный субъективный обзор, интересуются более серьёзными устройствами, да и редко будут держать под рукой реальных конкурентов из схожего ценового сегмента. В практическом плане проще всего проверить уровень усилителя, если подключить его к какому-нибудь простенькому комбайну, например, Audio-GD NFB-28 (цена $750, фото внутренностей по ссылке). Будет слышимое преимущество? Хорошо. Нет? Тогда в утиль.
  23. В Мариинском театре поступили в продажу абонементы. Нас, прежде всего, интересует #10 "Кольцо Нибелунга". Стоимость абонемента от 3600 до 4800. Составы, к сожалению, пока неизвестны. Ещё обратите внимание на #11 "Вагнер. Штраус" - хороший шанс послушать, например, Никитина в роли Голландца, Шагера в роли Тристана или Петренко, который будет задействован и в "Лоэнгрине", и в "Летучем Голландце", и в "Тристане и Изольде". Цены, повторюсь, очень умеренные.
  24. @Френки, у девяток разрешение выше и, что сразу бросается в уши, очень низкий уровень искажений. Не переходят на стаксы по понятным причинам: в наушниках, что я встречал, принцип камень-ножницы-бумага ярко выражен, девятки не исключение.
  25. iow ответил Khronos тема в Sony
    Ну, вот @only_a_lad купил за $1500 в идеале, а в обычном убитом состоянии, как можно заметить выше, уходили за $430. Мне, как ни странно, тоже встали в своё время ровно в $430 + доставка и разные комиссии. Я поменял амбушюры, ободрал оголовье, оставив там только ткань и выглядели они терпимо:
