Черная пятница 2026
Beyerdynamic T1 2nd Edition
beyerdynamic updates the T 1: the next generation of high-end headphones for an even more sublime audio experience
Heilbronn, August 2015: The T 1 from beyerdynamic represents the highest sound quality and precision craftsmanship. In 2009, the audio specialist from Heilbronn redefined the high-end headphones with its top model for home use. Now it's time for the bar to be raised even higher. When developing the second generation of the T 1, the sound wizards at beyerdynamic subjected their flagship model to some subtle but effective fine tuning.
Silky-smooth warmth meets precise bass
The T 1 has always been a paragon of transparency and precision. Now, thanks to new, further improved tuning, the dynamic and clean sound of the original has been enhanced with a touch more warmth and musicality that will have audiophile listeners in raptures. The additional attenuation in the heart of the Tesla driver eliminates disruptive resonances in the high frequency range. In order to achieve the ultimate sound experience, we fundamentally optimised the form of the baffle and replaced the single-layer baffle material with a more stable, high-tech compound material. This minimises vibration of the material to deliver even clearer sound reproduction. Music lovers will experience a solid, low-frequency foundation what they are looking for.
Studio-quality plug-in cable
The connection cable with fabric sheathing and threaded jack plug ensures optimum transmission. Its conductors, made from ultra-pure OCC copper, are among the best in the industry. The supplied lead can be removed from the headphones and, if required, exchanged for an optional cable with 4-pin XLR connector. This enables users with a headphone amplifier with the right outputs to take advantage of 'symmetrical transmission'. This connection method, used in professional equipment, prevents faults on the conduction path – acoustically, the cable practically melts into thin air.
New materials for maximum comfort
Two new ear cushions ensure that listening to music is also a comfortable experience. The fleecy velour made from hollow fibres transports warmth and moisture away from the wearer's head, allowing you to listen for hours without getting the dreaded 'hot ears'. A memory foam layer beneath the velour covers makes the cushions exceptionally soft. Even in terms of comfort, the T 1 is state of the art.
When not in use, the headphones can be stored in a luxurious hard case with a hinged lid. Not only is this ideal for transporting the headphones, but also perfect for displaying this classic piece next to your hi-fi system at home.
Unique Tesla technology "Made in Germany"
The T 1 remains the only high-end set of headphones in the world to feature 600-ohm transducers. beyerdynamic is the only company to use such delicate moving coils to convert electric currents into an explosion of acoustic colours and fine dynamic precision.
Special machines and experienced employees at the company's headquarters in Heilbronn are required to wind the coils. The wafer-thin copper wire is only around half as thick as a human hair. A further speciality of the company is also required: the exclusive Tesla transducers. With their powerful magnetic drives, they are able to compensate for the fundamentally higher voltage requirements of high-impedance moving coils. As a result, the T 1 reaches at-home listening volumes that other manufacturers would only be able to achieve using transducers of simpler construction and with significantly lower impedance. A sound such as that produced by the T 1 can only be achieved using Tesla technology.
The new T 1 i will be available from mid-August in specialist stores and on www.beyerdynamic.com at a price of 990 Euro. You can test it at the beyerdynamic booth at the IFA (hall 1.2, booth 204).in Berlin from September 4th to 9th, 2015.
Characters in the German press release (including spaces): 3,961; lines: 58
Publication free of charge; specimen copy requested.
Technical Data
Transducer type dynamic Operating principle semi-open Nominal frequency response 5 - 50,000 Hz Nominal impedance 600 Ω Nominal SPL 102 dB T.H.D. 0.05% Sound coupling to the ear circumaural Power handling capacity 300 mW Weight without cable 360 g Cable 3 m, double-sided, detachable OCC 7N copper conductors, textile braided Connection gold vaporized mini stereo jack plug (3.5 mm) & 1/4“ adapter (6.35 mm) Accessory luxury grade hard carry case Warranty 5 years Recommended retail price 990,- Euro
About beyerdynamic
Over 90 years' experience in developing audio electronics
beyerdynamic GmbH & Co. KG, based in Heilbronn, is synonymous with innovative audio products with superior sound quality and pioneering technology.
Three divisions – Conference, Pro Audio and Consumer – provide tailored solutions for professional and private users. All products are developed in Germany and are largely made by hand – from hi-fi headphones and stage microphones through to conferencing and interpreting systems.
  • Ответов 1,2k
  • Просмотры 239,3k
  • Кажется пора оживить эту тему, а то пол годы тишины - не совсем справедливо для этой модели.   Начну издалека с маленькой истории. 2 года я жил с 800 сенхами... и это были сложные годы, полные радости
  • Александр Карелин
    Александр Карелин
    Закончил вчера специальную усиленную приработку/прогрев наушников Т1_2 ~195ч наработки. Далее, уже слушаю в обычном режиме использования наушников. - первые несколько часов "из коробки" 3-5 - самые н
  • Бергамот
    Бергамот
    Ну что, вчера весь вечер после работы их слушал. Небольшое вступление: Вообще изначально я нацеливался на Одины, но пообщавшись с сотрудниками магазина, понял что цена на них будет расти из-за курса
На мой взгляд, на классике Senn будут информативнее, а на роке наоборот Т1. Но в целом, превосходства одних над другими я не вижу.
В свое время у нас в городе T1 почти год продавали по супер цене 24 т.р. При том что 800е стоили 35+. Однако последние продавались пачками, а одинокие T1 стояли на полке и никому не были нужны и даром. Собственно стоит посмотреть на количество владельцев Т1 и HD800 на форуме чтобы понять что вы единственный кто не видит превосходства. Надеюсь новые T1 получатся лучше старых.
Показатель продаж наушников или (других компонентов) - разве критерий качества (и звука)? В мелкосерийном, кустарном Хай-энде?
Может и Битсы тогда можно как-то соотнести?
Изменено пользователем ravich1984
Чтобы с вами не случилось - ничего не принимайте близко к сердцу (Э.М.Ремарк)
Нет, но если одни наушники в 1,5 раза дешевле никому не нужны, а другие в 1,5 раза дороже расходятся, для меня это показатель. Есть конечно любители Т1, даже на этом форуме их хватает, но в целом модель провальная и большинство со мной согласится. Вы думаете например у кустарной Audeze есть какой то особый маркетинг? Однако трешки которые сейчас стоят 166к и то популярнее чем Т1.
Сейчас, кстати, вообще должен начаться слив старых версий Т1, по крайней мере на head-fi. Судя из анонса, разница будет большая и не в пользу старой версии, плюс еще сменный кабель. Все фанаты Т1 будут просто обязаны обновиться. Так что, если кому нужны наушники для игр, для дачи и т.д...))
У нас на форуме как Т1 вышли, так о них еще поговорили вначале, особенно когда Кронос их купил и пиарил, а затем их дружно записали в хлам. Но на head-fi они еще более менее популярны, хотя и в разы меньше 800-х.
Так дороговато для дачи-то с нынешним курсом. Даже за 500$ и то дороговато :)
Ну за 400 можно взять)) Тем более что там новыми люди покупали за 650.
А вообще, с нынешним курсом скоро будет не до наушников))
Да на самом деле стоит всего лишь сгладить им горб на вч и получатся очень толковые ушки, плюс сменный кабель и вообще будет крайне привлекательный вариант. Но вот цена в 1000 евро у нас превращается в 70 - 75т.р. а это уже серьезно.
@Shadow39, совершенно некорректное сравнение.
На нашем форуме большинству абсолютно фиолетово на техничность наушников. Люди даже яркость от детальности отличить не могут, например.
Те же Hifiman He-6, имхо, самые детальные наушники из топ-сегмента. Но что-то не очень популярны они, тех же HD800 гораздо больше.
Здесь люди выбирают исключительно то, что нравится им на слух. Hd800 нравятся многим, поэтому их и покупают. Sony MDR Z7, как я слышал, продаются пачками, хотя на нашем форуме они почти никому не нужны.
Битсы вообще самые популярные наушники, хотя даже подделки китайские превосходят их в детальности, например.
Т1 просто не пришлись по вкусу местной аудитории. Но это не значит, что они плохие.
Аудиотракт (Hi-End)
Портатив:
Здесь люди выбирают исключительно то, что нравится им на слух. Hd800 нравятся многим, поэтому их и покупают. <...> Битсы вообще самые популярные наушники, хотя даже подделки китайские превосходят их в детальности, например.
Кроме того, популярность той или иной модели определяется именно "стадностью" потребителя, будь то HD800 среди аудиофилов или Битс среди "непросвещённых".
Phones: AKG K812, AKG K712 PRO, Audio-Technica ATH-A990Z, Beyerdynamic T1, Beyerdynamic T5p-2, Beyerdynamic T90, Beyerdynamic T70p, Beyerdynamic T51i, Beyerdynamic DT 1770 PRO, Fostex TH-X00, Sony MDR-Z7 + Kimber Kable, Sennheiser HD600 (ca. 2003), Sony MDR-V6 (ca. 1991), Sony XBA-H3, Ultimate Ears TripleFi 10, Ultimate Ears SuperFi 3, Bose QC25 / QC20i / QC15 / QC1, AKG K391NC
Amps: TEAC HA-501, Beyerdynamic A1, Violectric V200, Lake People G109-S, HeadRoom Little (1st gen ca. 1995)
DACs: TEAC UD-503, Meridian Director, Meridian Explorer, CEntrance HiFi-M8, CEntrance Mini-M8, CEntrance DACport HD, Sony PHA-3, AudioQuest Dragonfly, Beyerdynamic A200p
Source: Pioneer N50, TEAC HA-P90SD, Windows / iOS / Android devices.
Ну не знаю, я лучше за 250 (российская цена в переводе на доллары) возьму моментум 2.0 (что собственно я и сделал :) )
По поводу курса - согласен, скоро будет полная (_._)
@Milhouse, тоже актуально. Не все могут послушать много наушников, поэтому выбирают по советам. На форуме хвалят HD800. Люди пробуют - и им нравится, так как топ наушники вообще довольно взрослый звук выдают, а сравнить Senn не с чем. Потом уже начинается привыкание и оценить объективно другие устройства становится невозможно.
Конечно, не у всех так, но ситуация нередкая.
Баеры просто не прижились, бывает такое. Возможно, их не вовремя выпустили, так как сейчас популярность классического рока (где баеры раскрываются максимально) сильно упала, а современную музыку и свободную от моды классику Т1 играют средненько.
Аудиотракт (Hi-End)
Портатив:
Даже если лучше чем "средненько", всё равно они не самый оптимальный выбор. Успех второй версии будет сильно зависеть от "замеряльщиков" - Тайлл уже высказал интерес, так что посмотрим насколько вторая версия ему приглянется. Неспособные сформировать собственное мнение хедфайщики ориентируются почти исключительно на его обзоры.
@Solitudo,
А когда должны появится? Сорри. Может уже и был ответ, но я на плохой сети и мучительно грузятся страницы. Но тема чертовски интересна"
                                                             Алиса в Стране Чудес
, а чем первая версия то уже не нра?
По роду деятельности случается использовать топовые наушники заказчиков параллельно со своими 800ми и тестировать их длительно. И если некоторые из них как тo Fostex th900 или НЕ-6 ещё могут составить хоть какую то конкуренцию 800 м ,то у T1 это никак не получается.посмотрим как выступит новая версия
Изменено пользователем sergst
CD транспорт-CEC TL1. ЦАП-ламповый DAC CS 4397(топовый от Demograf).Усилитель наушников - ламповый 300В+EL8(топовый от Demograf). Усилитель-ламповый Unison Research Simply 845(для АС). Усилитель мощности - ламповый Audio Note P2 SE (для AKG K1000 и Abyss).Наушники (все с рекабелингом от Art-cables.com).Focal Utopia 2022 (RLS-24), Abyss 1266 rev1 s/n 0125498(RLS-76), Abyss 1266 rev1 s/n 9024353(RLS-76), AKG K1000(RLS-75), HD 800(RLS-50), Victor HP-DX 1000(RLS-67), Sony MDR-CD3000 mod(RLS-70), Myst Izophones-C(RLS-70) .Акустика Altec 9862)
Уже в этом месяце обещали.
Ну так тебе и Абиссы и SR-009 не понравились )))) Хотя на их фоне Hd800 это ничто ))))
Аудиотракт (Hi-End)
Портатив:
На фоне HD800 Т1 тоже ничто. Кто прав?
  • Администраторы
Тем не менее это отличная новость для любителей тяжелой музыки. T1 избавленные от косяков очень хорошо подходят для разных направлений тяжелека.
Сам заинтересован их послушать.
Я не думаю, что изменения коснулись только ВЧ. Вполне возможно иной драйвер, но в страром корпусе. Вдруг это новый достаточно ровный топ с универсальной подачей.
Наоборот -800 лучше и этой парочки
Если б тебе предложили только одни наушники иметь в системе,неужели ты предпочел бы 009 восемьсотым?
На эмбиенте да. А вот на роке Т1 просто смеются над Hd800.
Я да.
Для рока скорее. Тяжеляк для Т1 сложноват, все же. Хотя у Beyerdynamic очень быстрый драйвер. Это хорошо для такой музыки.
Аудиотракт (Hi-End)
Портатив:
Может на этот раз у Бейеров получится =).
В тракте Сергея тоже? ;)
Похожий контент
