Noble Audio FoKus Artemis
Dr.Head Awards 2025
Aune S18: твердотельный транспорт с поддержкой DSD
Aune S18 поступил не так давно в открытую продажу, в том числе на крупнейшем интернет-аукционе по цене $500 с бесплатной международной доставкой. Увы и ах, но фотографий внутренностей железочки сходу найти не смог, так что любимую форумную игру (лечение по фотографии) придётся отложить. Может, в процессе появятся владельцы, как знать? Никто не хочет заказать?
Aune S18 32BIT DSD Music Player Asynchronous (CPLD) Dual clock Fidelity Digital Turntable
High-quality multi-format mastering-digital turntable
Pure hardware solution asynchronous clock technology, the use of data reorganization algorithm for audio
S18 has the very end of the digital jitter and perfect digital waveform, while near the top in particular the use of analog tuning dial, is a turntable that can besubstitute for high-quality digital CD turntable
S18 is an Hi-Fi turntable with the music that alternative to traditional CD turntable
S18 is a mastering-HIFI dial multiple audio formats
S18 is an included CD disc formats, but support more digital HIFI turntable mastering format
S18 supports WAV / FLAC / APE / AAC / DSD and other multi-format
S18 is a HIFI turntable that support 32BIT and DSD highest formats
S18 can play up to 32BIT music files, and supports DSD file format DSF / DFF / ISO playback, support coaxial output DOP (DSD digital format)
S18 uses a purely digital technology hardware solution
S18 uses an ARM chip and a CPLD chips machine hardware framework
ARM is a pure hardware decoding codes, ARM asynchronous clock signal input CPLD chip technology reforming, Asynchronous clock technology allowshardware solution with a high numerical targets S18
S18 uses two ultra-low jitter clock crystal
Verification of the entire digital circuit is a clock crystal, S18 using two ultra-low jitter clock crystal clock and asynchronous technology with completely beyond the traditional CD turntable
S18 with numerous digital output interface
S18 with a group of RCA, a group of BNC, a balanced set of numbers, a set of digital optical interface
S18 with full balanced output interfaces IIS
S18 uses ultra high-speed full balance IIS output , the most high-speed transmission of HDMI interface, support for long-distance transmission, with higher speeds and longer distances than other IIS turntable
S18 uses 2.8-inch display and full remote control technology
S18 with a full perspective of the large 2.8 display and minimalist UI design, completely empty external remote control technology, is a very good man-machine interface of digital turntable, the machine includes a traditional analog dial operations, with more features
S18 has excellent indicators and excellent sound calibration
when playing 24BIT / 192K signal , the digital output jitter is 3.4NS, THD + N-138DB, reached the limit index
S18 supports more comprehensive formats ,support the DSD format and DOP output
S18 supports up to file playback 32BIT / 96, while supporting DSD 64 of DOP coaxial output, with a balance transfer IIS port provides two-way coaxial output interface (RCA + BNC), is a multi- interface multi-format digital turntable
Note:32BIT coaxial can not be transferred because the coaxial agreement can not be reached so high, only IIS transmission, DSD can play in the coaxial port transmission, but it needs the DAC that support DOP interface
Front Panel View
1.1 2.8 Display
1.2 Power indicator
1.3 remote control receiver window
1.4 Power Button
1.5 Main Menu button
1.6 on the button, the playback mode, previous / rewind
When the file browser mode, select the previous
1.7 keystrokes, playback mode, Next / Fast Forward
When the file browser mode, select the next
1.8 Enter / Play / Pause
When play mode, play / pause, file browsing mode, it is determined
1.9 SD card connector
Rear Panel View
2.1 IIS outlet
2.2AES digital output
2.3 coaxial output
2.4 optical output
2.5 backup WAN port (can not be used now)
2.6 AC input
Special Note:
Press 2 seconds for a long time, turn on the power; press two seconds for a long time,turn off the power
When the play mode, enter the main menu, to return to the previous menu
Изменено пользователем iow
Было (неделя+):
Внутренности на китайской барахолке есть. Сделано внешне (внутренности) очень не плохо. Тоже интересно что получилось.
пофотке не сказал-бы что питание сделано по аудиофильски... ну а звук в таких транспортах во многом зависит от софта , а не от железа
Изменено пользователем Александр Карелин
телега
CD флешка на 32 гб может 400 ма кушать в импульсе, емкости около картридера небольшие, да и около Spdf выхода тоже один кондесатор, радует что стоит тантал.
Однако звучание может зависеть от многих слагаемых.
Название получается не совсем верное - это именно твердотельный транспорт, а не плейер. Интересен был бы в связке с тем же аюновским S16.
Порт.источники iBasso DX100 SLmod, iBasso DX90 SLmod, MA-9 Balanced (SL Mod), QLS-QA360, Astell&Kern AK100. Наушники порт. Dunu-2000, Fostex TH900, HiFiMAN RE-600, ATH-CK90Pro, Yuin G1/G2A , Yuin PK1. Стац.источники Aune S1, Fostex НР-А8, BBP 101 Plus. ЦАП- Audio Alchemy 3.0. Усилители Luxman P-1, HiFiMan EF-6, Stax SRM-727А. Наушники стац. HiFiMan HE-6, Stax 007 Omega II, Audeze LCD-3, LCD-ХС, Sennheiser HD-800.
Исправил. Меня скорее интересует, лучше ли он по сравнению с bbp-200 - этот я совсем не слушаю, уж больно он китайский в плане удобства. Пока мне с транспортами не везёт. Можно, конечно, взять не глядя, благо s18 относительно небольших денег стоит, но неудачный опыт с qls меня останавливает.
Было (неделя+):
@iow, а вы продукцию Raumfeld не рассматривали? У меня весьма положительный опыт.
Дома
Кино/музыка Multi-channel: NAS Synology DS-214 Play/HTPC => Onkyo TX-NR579 => Canton Movie 1050 5.1
Музыка стерео (громко): NAS Synology DS-214Play => AudioPC (Work in progress) => Foobar2000/Aplayer => Echo AudioFire 2 => РГ Никитина на бистабильных реле => Genelec 6010B + Genelec 5040
Музыка стерео (тихо): NAS Synology DS-214Play => AudioPC (Work in progress) => Foobar2000/Aplayer => будет что-то типа PPA V2 => M2Tech HiFace DAC / iFi Nano iDSD => Laconic HA-04AF => AKG Q701/AKG K501 Litz Mod/Audio-Technica ATH-A700/Philips Fidelio X2/Sony MDR-7506.
С собой: Notebook (foobar)/Xperia Z5 Compact (USB OTG + UAPP) => iFi Nano iDSD => Etymotic ER-4P Customs
Для некритичного прослушивания "на ходу" - Xperia Z5 Compact (Neutron Player) => Samsung Level Link (AptX) => Etymotic ER-4P Customs
Редко и для души: Audio-Technica ATH-EW9, Sennheiser PX-100
У девочки: Samsing A5 -> Sony SBH-20 -> Klipsch X7i Customs, Sony MDR-10RBT
@SV_huMMer, я не знаю, что это такое.
Было (неделя+):
@iow, https://www.raumfeld.com/
У меня имеется Connector, за свои 200 евро - весьма и весьма заслуживающий внимания вариант.
Изменено пользователем SV_huMMer
Дома
Это концептуально иное устройство. Мне нужен твердотельник без wi-fi. Имеющийся под рукой oppo bdp-103 играет музыку как по сети, так и с флешки, но по качеству уступает тому же bbp-200.
Было (неделя+):
@iow,
так может не размениваться на китайцев, а сразу посмотреть что-то вроде bryston bdp-1/2, если важно именно такое устройство?
хотя они стоят конечно прилично :think:
я с 101 bbp так и не нашел общего языка - продал.
qls550 конечно менее удобен, но такого количества глюков не было.
Сорри, видимо не понял. Хотя его можно превратить в "твердотельник без Wifi", в том смысле что контент можно воспроизводить с USB-флэшки, а не с сети. Но управление все равно только с телефона/планшета по Wifi. К тому же, по SPDIF он может отдать до 24/192 на любой ЦАП из домашней коллекции. Но по звуку - да, звезд с неба он не хватает.
Дома
@iow,
Не уверен, что он лучше, но знаю, что намного дороже. Посмотреть-то всегда можно, а вот купить - это уже совсем другое дело. :)
http://htpc.jp/hires/index.html
Молочный брат?
На рынке предостаточно похожих устройств. Просто c aune я уже сталкивался, а тут они выпустили концептуально близкий мне вариант транспорта.
Было (неделя+):
  • 4 weeks later...
Он только с SD флешки музыку играет, т.е. жёсткий диск к нему не подключишь?
Я вам покажу, где Shigaraki зимуют!!!11 :D
Essence ST (coax) -> Muse TDA1543x4 -> Objective2 -> DT990Vtg, AKG K612
Болтун - находка для шпиона, а бестолковый и наивный гуманитарий - находка для местных барыг ;)
дом: Muse TDA1543x4 -> Behringer B2030A Truth
Trio KP-7070 (Empire 880P, Pioneer PC-330, AT140e) -> SanderZ -> Lehmann BCL (клон) -> Баеры, AKG
вне дома: Fiio X5 II -> Zero Audio ZH-DX200 Carbo Tenore, TDK IE800 upgrade
было: Hidizs AP100, IHiFi-960PRO, FiiO X3-II, Sony NWZ E-583, Sony NWZ-A15, ATH IM02, ATH M-50, ATH AD900X, ATH AD2000X, Fostex T50RP mod, FA Dubliz (ДНО), HiFiMAN RE-400, DUNU DN-2000J, DT770 PRO 32 LE, JVC HA-FXZ100, ODAC XL Rev.B, Brainwavz HM5, Flare audio R2Pro (best of the best)
В чем 103 хуже?
Вопрос не праздный - нахожусь в процессе поиска нового транспорта, и было намерение взять 103.
Продаю (цена договорная)
Усилители для наушников:
Наушники:
и др. ))
ЦАПы:
Да вообще все распродам...
В целом, интересное устройство. Характеристики, на первый взгляд, впечатляют. Даже I2S выход есть.
Однако, как и на примере того же Auralic Aries (тоже китаец), слабо верится в чудо. Aries сравнивают по качеству звука с MacMini. В лучшем случае и этот транспорт будет играть на уровне MacMini. Т. е. потенциал ЦАПа уровня Berkeley этот транспорт не раскроет.
Источник и пред: Linn Klimax DSM, АС: Linn Klimax 320A, Саб: Linn Klimax 345, Кабели: Bertram Cuprio Flow. Питание: PS Audio P3, Isotek Evo3 Aquarius. Виброизоляция: Finite Elemente Cerapuc, Symposium Rollerblock Series 2+ (G3) Double Stack, Jr. HDSE. Акустическая обработка: Vicoustic Wavewood + Wavewood Basstrap.
Было: Luxman P-1u, Sennheiser HD800, Luxman P-200, Linn Majik CD, Audio-Technica ATH-W5000, Schiit Lyr, Sennheiser PXC450
Aune S1, к примеру, играет (в том числе, и как твердотельный транспорт) несравнимо лучше, чем MacMini. Так что как минимум S18 должен быть не хуже S1, поскольку это транспорт, а не плейер. Так что если нужен именно транспорт - попробовать стоит, да и цена вопроса вполне приемлема.
Изменено пользователем PathologSPb
В чем 103 хуже?
Ну, в 103-м много воздуха, но он притемнённый, не шибко детальный. Звуковые образы в bbp более рельефные. Когда у меня месяц стоял dCS Debussy, то в качестве транспорта с огромным отрывом лидировал mac mini с выносным блоком питания (+Jriver), bbp и oppo при таком конкуренте по уровню звука казались одноклассниками. Однако, при переходе на mytek такой разницы между маком и другими транспортами не было. Тут они уже болтались в одной лиге. Впрочем, все кому удалось лично послушать и сравнить, были разочарованы и bbp, и тем более oppo. Ещё я сравнивал bbp200 с заточенным под музыку компьютером с Lynx AES16 на двух ЦАПах (или трёх? уже не помню...) - компьютер тоже оказался немного предпочтительнее.
Допускаю, что при подключении какого-нибудь другого ЦАПа тот же bbp будет не хуже или даже лучше mac mini. Это же от многих факторов зависит. От качества реализации usb (в dCS с этим всё отлично) или от уровня конвертера (при связке mac mini -> sotm / berkeley alpha usb -> DAC). Например, Debussy, если верить отзывам, добавление прокладки в виде беркли или сотма ничего особо не дают. Всей этой суммой уточнений и обусловлена разница мнений.
Было (неделя+):
bbp200
в оригинальном состоянии, без твиков и модоинга?
телега
bbp200
Всё верно, без твиков.
Было (неделя+):
В чем 103 хуже?
Спасибо за ответ.
Хотел использовать 103-й только в качестве транспорта с коаксиальным выходом на Цап.
Встроенный цап 103-го, да - не особо.
Имхо - 105-й на Сабре - предпочтительней.
Наушники:
и др. ))
ЦАПы:
Спасибо за ответ.
В 103-м ЦАП уровня встроенной звуковухи, естественно его следует рассматривать только как транспорт. Переплата за столь посредственную реализацию сабре в 105-м того не стоит. Любой середняк на 9018 будет лучше. Сравнивал цаповую часть в 105-м с mytek 192 dsd (там 9016), разница пугающе велика в пользу майтека.
Было (неделя+):
@dj000001, где вы там плеер увидели? по ссылке сплошное сделай сам, найди из чего сделать сам, настрой сам, слушай тоже сам и ни с чем не сравнивай
телега
@dj000001,штука интересная, если создатель поставит на поток или будет точная инфа по созданию, то можно заказать умельцу.
