Audio-Technica ATH-AP2000Ti
На фоне любознательности решил завести эту тему, которая, возможно, будет актуальна позже. Предлагаю пообсуждать.
В теме новинок 2019 года модель ATH-AP2000Ti уже мелькала, но обзоры есть только зарубежные. Средний ценник в известных интернет магазинах порядка 100к деревянных, что немало.
Интересно, нет ли на руках данной модели у обитателей форума? Появится ли она в ДХ?
Один из отзывов владельца с head-fi опубликую на англ:
Got my ATH-AP2000Ti's today. Initial impressions are wow. They are so detailed, the mids are extremely clear, and the bass is very good. The bass doesn't have the presence of a planar headphone but it's nice and punchy with good depth and extension. The bass on the ATH-AP2000Ti's reminds me of the bass on my Utopia's. It's not always present but if the bass in the music they both deliver it with speed, definition, and authority. This is new territory for Audio-Techinca. This headphone is definitely an upgrade from the A2000Z's I had before. They still might be considered bass lite for some but you can always add subbass. The good thing about this headphone adding some subbass shouldn't interfere with the rest of the frequency spectrum.
Audio-Technica does treble as good as any headphone manufacturer and the ATH-AP2000Ti's are no exception. The clarity in the treble is top notch. The overall sound signature is on the brighter side of neutral but to me this adds to the openness of the headphone. They don't sound congested or closed in at all. The soundstage is pretty good. Imaging is very good as well.
They are very light and very comfortable. The wing headband system is gone and I couldn't be happier. These feel so much more nicer on the head with a good seal. When I had the A2000Z's I had to bend the headphone band because I couldn't get them to sit on my head properly. Not so with these. They fit like a "normal" headphone. The earpads are contoured to fit more naturally around the ear. They remind me of a less thicker version of my Z1R earpads, nice touch. That's all I have for now. I'm going to let these burn-in for awhile and come back for more listening.
Can you compare it with Z1R and 820? Those two are the best closed I've ever tried, just want to have some benchmark to judge as I don't think 2000Ti gonna come to my local Jaben anytime soon.
Sure! The AP2000Ti is the brighter sounding headphone of the three by a wide margin. But it's not sibilant at all. I find the clarity amazing. When you compare it to the Z1R and HD820 without giving your ears some rest you would think it sounds thin but it's not. It's just that the AP2000Ti is on the brighter side of neutral. Where as, the Z1R and HD820 are on the warmer side of neutral. The AP2000Ti is very revealing but I think the HD820 is most resolving of the three. Surprisingly, the AP2000Ti has a very good soundstage. It's not as spacious sounding as the HD820 but it holds its own against the other two. Music doesn't sound closed in at all on the AP2000Ti. The Z1R's do a very good job of sounding like an open headphone as well.
The midrange is nicely integrated and smooth on the AP2000Ti. It's clear and ever so slightly pushed back when compared to the Z1R and HD820 midrange. Both of the latter two headphones the midrange is more forward sounding with nice body and tone. The HD820's timbre is the best of the bunch. It just sounds so natural.
The treble on the AP2000Ti is one of the best I've heard. I love the treble on this headphone. The treble on the Z1R can be peaky at times depending on the song. The treble on the Z1R is a lot better with an all copper cable but it's still not as good as the HD820 or AP2000Ti's treble to my ears. The treble on the HD820's matches that of the AP2000Ti in clarity and detail. But begins to separate itself because it sounds more out of your head.
Now on to the bass. All three present bass differently. The Z1R is the deepest and sounds like a subwoofer in your head. The draw back of this kind of bass presentation is that it can over take the music on some songs. The AP2000Ti's and HD820's bass is better integrated, more linear. The kick drums have a nice thump it on both these headphones. The HD820's bass sound so natural and its the most defined of the three. But the AP2000Ti's bass in not far behind in definition to the HD820's. The Z1R's is big and bold and is on a whole different level.
If I had sum up the sound of these headphones it would be as follows:
AP2000Ti: Of a bright nature, but paints a very good image. Every note can be heard and the bass is very good. The midrange is smooth and balanced. Very easy to drive and is not source dependent and sounds good out of lesser sources. Best Audio-Technica I've heard.
HD820: Refined, open, dynamic, resolving and detailed. Finally has the bass I've been looking for from a TOTL Sennheiser headphone. Pin point imaging, with nice bass and midrange body You forget you're listening to a closed headphone. Sounds the best with better sources. Extra power is not required but helps bring out the best sound in this headphone
Z1R: One word, musical. You can put this headphone on and enjoy any type of music. Easy to drive and scales very well. Has the richest sound due to it big bass and full sounding midrange.
All three are keepers. But if I had to keep one it would be the HD820's.
Изменено пользователем Ololoshevkin
Home: Tube AMP by HOOD / AMP Lynx HA84 / SQTech Matrix R2R / BBB / ATH-ADX5000 / Denon AH-D9200 / ATH-AD900
Portable: Hiby RS6 / ATH-WP900
  • Ответов 53
  • Просмотры 13,4k
  • Сегодня ещё раз довелось послушать AP2000Ti, но на этот раз на AT-HA5050H. Конечно этот гибридный усилок для своих собратьев очень синергичен, добавляет немного тепла в звук (если сравнивать с холодн
  • Ну что, принимайте ещё одни закрытый ТОП. Наушники получились. У них хороша звукоизоляция и звук отвал башки.   Вкусные, увлекательные, особенно на джазе с вокалом. С трудом оторвался от прослушива
  • Дошёл сегодня до ДХ. Удачно, народу было немного сидел один.   Решил убить двух зайцев послушать и новую ATH-AP2000Ti и Focal Stellia.   Сразу скажу, что обе модели наушников мне очень понравились
У АТ в последнее время часто появляются яркие наушники. К примеру, AUDIO-TECHNICA ATH-SR9 настолько ужасны на ВЧ, что их невозможно слушать.
HiBy RS8ii + Noble Audio Onyx + Snorry Si-5 mk2
Да, и это не исключено. SR9 не слышал, но мне и опыта с MSR7 хватило, у них тоже перебор.
  • 2 weeks later...
@clubnewmen,
Спасибо!
На следующей неделе обязательно заскочу послушать
Я в наушниках )))):
@Dima Rodionov,
Какой же ты шустрый, Дим) Жду отзыв, ну и буду спешить сам послушать
Вкусные, увлекательные, особенно на джазе с вокалом. С трудом оторвался от прослушивания, даже забыл, что надо с чем то сравнить. С большим удовольствием послушал классику - интересно, не скучно.
Верх ясный, детальный, чистый. Вокал певучий. Контрабасы и бас гитарки отлично прорисованы.
Баса мощный и густой, его достаточно для рок музыки типа Feith No More. Но, как и в других наушниках Audio-Technica, на тяжёлых и скоростных вещах не хватает панча. Пока идёт инструментальное вступление баса кажется много, но когда начинается основной замес, бас вдруг уходит на второй план. Хотя технически наушники отыгрывают металл без проблем.
ATH-AP2000Ti слушал в начале с плеером AK 1000m. Затем, когда перешёл на плеер Plenue L, звук стал чуть агрессивней и панча стала немного больше за счёт Сабры. Но за организацию меню разработчикам Cowon руки бы поотбивать, а за дизайн дизайнеру глаза выколоть, хотя он и так наверное слеп, раз такое сотворил.
Кроме совсем тяжёлого металла, остальное ATH-AP2000Ti играют супер-пупер. Любителям подачи Аудио-Техника, наушники думаю понравятся. В AP2000Ti реализован фирменный звук + топовый, высокий уровень + закрытая конструкция с хорошей звукоизоляцией.
После них быстро перешёл в Fostex TH909. При первом прослушивании они мне запомнились очень широкой сценой и притемнённым звуком, и ещё чуть более текстурным басом в сравнении с 900-ми. Но сейчас, возможно на контрасте с ATH-AP2000Ti открытые TH909 не понравились. Сцена громадная, все образы отодвинуты далеко вдаль. Но между мной, слушателем, и музыкальными образами нет ничего. А логика подсказывает, что в этом центральном месте сцены должны брынчать ведущие инструменты и вокалист. Из-за притемнённости 909-х впереди кажется жуткая пустота.
Denon 9200 играют с перекосом в светлую сторону, таким образом, пытаясь казаться ещё детальней. Бас всегда на втором плане, очень качественный и фактурный, но количеством не балует. ATH-AP2000Ti лично мне понравились больше, они играют полновесно, лучше передают глубину сцены и атмосферу происходящего.
Приехал сегодня в ДХ после работы уставший и потом 2 часа слушал популярные блютуз наушники для будущих отзывов в своём блоге. Поэтому послушать внимательно и оценить ATH-AP2000Ti подробно не хватило сил.
Изменено пользователем Dima Rodionov
Куча масла в огонь моему любопытству)) Спасибо, Дима.
Ну и уши совсем негретые ещё, другими они и быть не могут.
Сразу скажу, что обе модели наушников мне очень понравились и признаюсь честно мне не хватит опыта расписать всё услышанное, однако по части Audio-Technic'и Дима всё расписал очень достоверно, поэтому в основных качествах я с ним полностью солидарен.
Начнём с оформления: ATH таки ушла от системы Air в подвесе самих телефонов. Я совру, если скажу, что мне не нравится подвес Air, очень нравится, но AP2000Ti одна из самых удобных и лёгких, что мне доводилось мерить, включая саму Stellia (как минимум поэтому количество поклонников новой ATH вырастет). Ты просто одеваешь сразу правильно, тебе удобно и максимально комфортно, потому что иначе их одеть невозможно. Амбюшуры самые глубокие, что были у Аудиотехники (не накладные как раньше, а такие как у Fostex или Focal - глубокие). Шумоизоляция стала на порядок лучше закрытой серии Z (это бесспорно).
Звук: в целом как поклонник марки с уверенностью могу сказать, что это большой шаг вперёд. Модель во всём превосходит предшественников серии Z. Середина - очень сильная сторона данных наушников. Превосходно звучат джаз, блюз - тут из своего скромного послужного списка прослушанных закрытых динам я не вижу им конкурентов (конечно же это моё субъективное мнение). Вокал так же сильная их сторона. Честно скажу, не зашёл быстрый метал. Вероятно проблема в качестве записи, но Children of Bodom - Bodom after Midnight песочил на верхах (так же не исключаю, что не прогреты). С другой же стороны Vildjharta и Bring me the horizon звучали очень технично, я прям залип. Вообще модель получилась технически очень сильной, она отлично разрисовывает образы, порой до безобразия чётко (а я такое люблю). В некоторых треках тарелочки и вся подробная мелочуха звучали настолько натурально, что мне не верилось, почему я раньше этого не слышал. Отдельного упоминания заслуживает и бас: глубокий, фактурный, прекрасно артикулированный. Ревебраций при, казалось бы, непреодолимых резонансах нет, я специально заострял на этом внимание - очень точный и быстрый бас. На жёстком тяже в большинстве случаев, как и было сказано Димой, теряет вес и тело. Сцена широкая и хорошо читаемая. Один субъективный минус - нестандартные разъёмы кабеля при подключении к чашкам, как и в случае с ADX5000.
Stellia: это модель полная противоположность звуку ATH, при этом она мне всё равно очень понравилась. Опять же извиняюсь перед владельцами, но вот теперь я получил тот Focal, каким его себе и представлял (Utopia мне не понравилась совсем). Теплоё ламповое звучание с обволакивающим жирнющим и глубоченным "тапочковым" басом (под тапочками я подразумеваю эдакую мягкость и уют). Звук произвёл на меня "вау" эффект, потому что такого густого звука я не слышал никогда. На самом деле, на мой вкус, баса чрезмерно много, но что самое удивительное, динамики, выдавая всё это количество, настолько технично и быстро его обрабатывают, что мозги не верят происходящему. Такая гуща должна сама в себе захлёбываться, но этого ни разу и в помине не происходит - удивительно. По части универсальности наушники уникальны, они пусть не на отлично, но зато играют вообще всё и очень комфортно (хотя опять же я от такого количества баса все же уставал бы), но вот середина очень комфортная. Порой они довольно ровно себя ведут, но частенько середина все же отодвигается уступая басу. И нет, бас не затмевает общую картину, но всё же отвлекает внимание - вот как-то на этом я себя поймал. Убавить бы количество баса ровно в 2 раза сохраняя его сильные стороны - было бы идеально. В музыкальных стилях явно не их сильная сторона - это джаз, вокал и классика, а вот рок, метал и любая динамичная музыка звучат шикарно (хотя опять же мне довольно сильно не хватает прозрачности на середине, сравнивая с ATH). По комфорту уши так же топ.
Примерно такие впечатления у меня остались. Модели вполне достойны друг друга. Выбор между ними исключительно вкусовой. Ярым металлюгам явно лучше смотреть на Stellia (не могу представить, что их сможет переиграть среди динам в закрытом исполнении). За всем остальным к ATH. На этом и закончу свой субъективизм.
Имел счастье отслушать
Stellia на голову выше
Не было бы Утопии - удержаться от покупки было бы тяжело
Аудитехника ярчит, без темного источника ловить нечего
А другая аудиотехника ATH-ADX5000 - там действительно очень высокий уровень, и несмотря на отличное разрешение на высоких -все там на месте, и по басу вопросов нет, интересно если бы обе аудитехники сравнили
Изменено пользователем chontvari
Мой тракт здесь  https://forum.doctorhead.ru/forums/topic/38291
@chontvari,
Я не спорю, но, как говорится, на вкус и цвет. Джаз я бы в Stellia слушать не стал бы. Поэтому где-то лучше, а где-то нет.
Очень от записи зависит. Мне так наоборот в некоторых композициях Stellia глуховаты, а в некоторых нормально. Про "песок" на AT я так же упомянул (причём он был очень ярко выраженный), но из того то успел послушать, он был только в Children of Bodom - Bodom after Midnight
Тоже думал об этом, но уж очень хотел послушать Stellia и не прогадал. Повторюсь, они мне очень понравились, именно такими я их себе представлял, просто сам я люблю другой звук.
Слушали на чем ?
Не хотел заморачиваться и времени было не сильно много, поэтому на стоявшем там HDV 820
Интересно, столько Аудиотехника будет продолжать накрывать излучатели этими своими слабоперфорированными дребезжащими жестянками? Даже верхние модели. Ну почему, спрашивается, не сделать, как у людей? Просто потому, что дешево и технологично?
Срезал как-то еще очень давно эту жестянку (конечно, не на топовых моделях) - ну так это же совсем другое дело, ну вот совсем-совсем другое!
А что не так с металлом капсюлей? С демпфированием резонансов бренд справляется на отлично, не припомню каких-нибудь паразитных призвуков или чего-нибудь ещё.
<p>
<br />А что не так с металлом капсюлей? <br />
<br /></p>
<p>
<br />песочил на верхах<br />
<br /></p><p>
<br /> ламповое звучание <br />
<br /></p>
Посмотрите на демпфирование Стелии/Элегии и старших Аудиотехник закрытых, может вопросов станет меньше.
Изменено пользователем Бергамот
Думаете песок именно из-за этого? Надо будет проверить. К своему стыду так до сих пор не слышал не одних старших деревяшек от AT (быть может всё-таки отсутствие прогрева, наушники ещё совсем свежие)
Кстати на своих A1000Z в этом упомянутом треке песка нет и в помине. (хотя капсюли тоже металлические, но не титановые)
Все титановые Аудиотехники этим страдают, начиная с А 2000. В той или иной степени.
В деревяшках свои особенности.
Именно титан? Просто у меня чашки из алюминия
Про деревяшки наслышан, но за обертоны их вроде бы и любят.
Безусловно. В т.ч. и я.
Именно титан?
Да, титановые чашки в большей степени повинны в этой искристости. Не забывайте, что это вообще фирменная черта Аудиотехники-приподнятая середина, да ещё и металлический подзвон чаш.
А2000Z, например, меньше всего ярчит(из верхних с металлом), но если сравнивать с Фокал, то и она будет яркой на их фоне.
  • 2 weeks later...
Конечно этот гибридный усилок для своих собратьев очень синергичен, добавляет немного тепла в звук (если сравнивать с холодным HDV 820) ну и не знаю как ещё описать. Всё как-то на своих местах, причём все отлично подчёркнуто. Сцена очень детализирована и объёмна, но с агрессивным металлом ситуация принципиально не изменилась - именно это направление явно не для них (тут даже A1000Z выигрышнее смотрятся).
Так что очень советую слушать на HA5050H, в том числе и ADX5000 (звучат очень комфортно и детально, хотя и не столь прозрачно как с Zen Monster) или W5000 (наконец-то послушал эти деревяшки, очень понравились, но амбюшуры - это ужас)
p.s.
изодинамы на примере LCD3 не раскачиваются - звук плоский и скучный
Насколько я понимаю эти наушники как бы продолжение линейки для портатива. Предыдущий топ был 2009 года выпуска - ATH-ES10 и стоил на момент выпуска 45 000¥
Данные же наушники стоят уже порядка 140 000 ¥
Трех кратный рост цены. Но это похоже уже тенденция в данных реалиях. Грустная тенденция.
https://www.audio-technica.co.jp/atj/show_model.php?modelId=114
iPod shuffle + earpods
@Surgut2006,
Не могу сказать за саму компанию, как они видят философию данной модели в своей линейке. Скорее всего они хотели уйти от ярлыков портатив и стационар. Модель существенно крупнее накладной серии ES, при этом, в силу отсутствия системы Air, они не выглядят очень габаритными. Цена же да - это скорее тенденция, нежели реально подкреплённая дороговизна
