24/192 USB DACs (список пополняется)
  • Ответов 200
  • Просмотры 134,4k
  • пожалуйста, добавьте и нас
  • Resonessence Labs Invicta Mirus ($4995)   Our top-of-the-line product an outstanding DAC for the ultimate in performance. MIRUS uses eight channels of the ES9018 Sabre DAC for each stereo channel, a
  • Sony UDA-1/B   Features: Playback of DSD and the full range of Hi-Res file formats, 20W x 2 Class AB amplifier, compatible with iTunes, Windows Media Player and more, Analog FIR filters, connect to Ap
  • 2 weeks later...
Resonessence Labs Herus ($350)
HERUS: Asynchronous USB Audio 2.0, 24bit 352.8Ks/S, DXD and DSD64/128, 2.4VRMS Headphone DAC
HERUS is our smallest form-factor, audiophile quality USB to Headphone DAC. It uses the USB Audio 2.0 Asynchronous protocol and supports DSD64 and DSD128 as well as high data rate PCM at 24bits up to 352.8Ks/S. It is a USB powered device that achieves more than 100dB of SNR, (typically 108dB) and is capable of driving 2.4V RMS, (ie 6.8V pk-to-pk) into headphones from 600 Ohms to 32 Ohms. The distortion in all cases is better than 0.005% (85dB): the measured THD+N is typically 89dB for 32 Ohms and 90dB (about 0.003%) for 600 Ohms.
HERUS ________________________________________
HERUS-LR.pngHERUS is designed to operate with MS Windows, MAC OS and Linux. You may download our Thesycon USB Audio 2.0 driver to enable USB Audio 2.0 on Windows. HERUS uses the ESS 9010-2M DAC and our custom code, and our own asynchronous algorithms that run in a generic Cypress USB interface chip.
We use Resonessence designed, advanced power line processing circuits that can reliably deliver more voltage range than the USB provided 5V, and we maintain the SNR of the power supply to a degree such that HERUS exhibits well over 100dB of SNR at the headphone output. HERUS also has a very low 0.2 Ohms output impedance that prevents external noise sources coupling into the output.
All Resonessence products feature upgradable firmware and hardware and despite its physically small size, HERUS also contains Resonessence upgradable hardware and firmware.
HERUS is machined from a solid block of aluminum and is 63.5mm (2.5in) long, by 31.7mm (1.25in) wide and 19mm (0.75in) high. It has just two connectors: a USB type ‘B’ socket on one end and a TRS 1/4inch Stereo Headphone connector at the other end. HERUS, like all Resonessence products is Designed, Manufactured, Tested and Shipped in Canada.
HERUS SPECIFICATIONS ___________________________
The total distortion (THD) on any HERUS will always be better than 85dB (ie less than 0.005% distortion) and the noise (SNR) will always be better than 100db, typically 108dB. More detailed specifications are: Asynchronous USB Audio 2.0 PCM bit width 24 or 16 Bits (If provided with 24bits HERUS uses them all, but it works with 16 bits also) Supported Data Rates 44.1, 48, 88.2, 96, 176.4, 192 and 352.8 Ks/S Supported Formats PCM, DXD and DSD64/128 Uses DoP protocol 1.1 over USB for DSD Operating Systems MS Windows, MAC OS and Linux Use the Resonessence Thesycon Driver for USB Audio 2.0 on Windows Output Signal Level At Maximum Volume level 2.4 VRMS Output Impedance 0.2 Ohms SNR at least 100 dB, Typically 108dB THD at least 85 dB, Typically 90dB Power Into 32 Ohms 126 mW THD + N 89 dB Typical Power Into 60 Ohms 95 mW THD + N 90 dB Typical Power Into 300 Ohms 19 mW THD + N 90 dB Typical Power Into 600 Ohms 9.5 mW THD + N 90 dB Typical
HERUS will enumerate to the controlling computer and register itself as being able to handle volume control internally. Almost all music player applications will then send control commands to the HERUS which it will use within the ES9018 DAC chip to implement high performance 32 bit volume control processing. This is significantly better than the volume control implemented in the music player software.
HERUS is easy to use: plug HERUS into a USB 2.0 (ie High Speed port) [with USB Audio 2.0 enabled if on MS Windows] and select HERUS as the output device in your system control panel. That is all there is to it…
IMPORTANT Please note: some (if not all) software on the PC, MAC and Linux will, the first time HERUS is connected, set the volume to 0dB. That is, to the highest volume level. This may be very loud in the headphones. On subsequent connections the music player application will recall the last volume setting, but we have seen instances where plugging into a different USB port again sets the volume back to 0dB. Consequently, we strongly recommend that you plug the HERUS into any new port on your computer with the headphones unplugged, and set the volume to a reasonable level prior to plugging the headphones into HERUS.
Finally, you may, if you wish, use HERUS as other than a headphone driving DAC. For example, when driving a power amplifier you will find that HERUS is a capable and high performance system component. It is perhaps the optimum and lowest cost solution to accessing DSD music from your computer collection. Read our FAQ on this question for more information.
PC (foobar2000) >> iBasso D14 Bushmaster >> UE900
My music on soundcloud (Up to 32/192 .wav)
My music on bandcamp (Up to 24/192 .flac/.wav/.aiff)
Digital collection
CD's collection
Current:
DAC/Amp (portable): iBasso D14 Bushmaster
IEM: Logitech/Ultimate Ears UE900
IC: Audio-gd Balanced Interconnect Assembled Cable (1m)
S/PDIF Cable: Revelation Audio Labs Prophecy Cryo-Silver™ Reference S/PDIF Digital Link cable (BNC-RCA, 0.5m)
Power Cables: 2 x Oyaide EE / F-S 2.6 SE (Oyaide-037e/037) (1.5m)
Wall Socket: Furutech FT-SWS-D® Carbon
USB Cable: Artisan Silver Cables "Ultimate Silver Stream" pure silver USB A to USB B cable (cryo, 1.25m)
Hi-Fi Rack: MetalDesign MD 108-5
Last:
Headamp: Schiit Audio Mjolnir
DACs: Audio-gd NFB-10SE, Matrix Audio X-Sabre
DAPs: QLS Electronics QA350, Colorful Colorfly CK4
Headphones: AKG K27i, Sennheiser HD280, Sennheiser HD595, HiFiMan HE-300 Rev.1, HiFiMan HE-6, HiFiMan HE-400i, Sennheiser HD800
Headphone Cables: Revelation Audio Labs Cryo-Silver™ Reference Headphone cable (HE-Series, 4-pin XLR balanced, 3m), Artisan Silver Cables "Silver Dream" Mark 2 (cryo, HE-Series, 2 x 3-pin XLR balanced, 3m)
IEM: HiFiMan RE-0
USB-S/PDIF Converter: Anedio U2
S/PDIF Cable: Audio-gd Canare Coaxial Cable
IC: Revelation Audio Labs Paradise Cryo-Silver™ Reference Balanced Interconnect cable (0.5m)
ORB JADE-1 and JADE-2
http://www.orb-audio.jp/english/jade-img/jade-1-2-main-720.jpg
http://www.orb-audio.jp/english/jade-1-2.htm
Product name
JADE 1 (DA-HP1)
JADE 2 (DA-HPU1)
Power
AC100V, 50/60Hz
Power consumption
15W
Headphone Amplifier
Class A
Recommended load
impedance 16-600?
Input sensitivity / impedance 2V / 47k? Rated output
16?: 1100mW+1100mW
32? : 560mW+560mW
64? : 280mW+280mW
300?: 60mW+60mW
600?: 30mW+30mW Frequency response 20Hz-20kHz +0dB, -0.5dB fs=44.1kHz(EIAJ) Total Harmonic Distorsion USB <0.018% fs=44.1kHz (EIAJ)
Optical <0.018% fs=44.1kHz (EIAJ)
Coaxial <0.018% fs=44.1kHz (EIAJ)
RCA <0.004% fs=44.1kHz (EIAJ) S/N Ratio >127dB fs=44.1kHz (EIAJ) Dynamic Range >120dB fs=44.1kHz (EIAJ) Output impedance 0.1? Inputs
USB: B-type
Optical: TOSLINK
Coaxial: S/PDIF
Analog: RCA Sample rates 44.1kHz / 48kHz / 96kHz / 176.4kHz / 192kHz Supported file formats (USB memory stick port) WMA / AAC / MP3 Output connector types
Headphone TRS 6.3mm (1/4")
Analog RCA
AC connector type Standard inlet cord C13/C14 Dimensions W:238 D:317 H:96 mm
W:9.37 D:12.48 H:3.78 inches Weight 4 kg (8.8Ibs) approx.
  • 1 month later...
http://www.oppodigital.com/future/HA-1_Headphone_Amplifier.aspx
Было не было не помню, орро короче теперь все делает
Комбайн Resonessence Labs Concero HP $850
CONCERO HP is the Headphone driver version of CONCERO. It supports DSD64 and DSD128, Sample rates up to 352.8kS/s and 24bits. Over 100dB (0.001%) THD+Noise performance into headphones above 300 Ohms (over 90dB performance into 32 Ohm headphones). S/PDIF and USB Audio 2.0 data sources.
CONCERO HP Uses the ES9018-2M - the latest chip from ESS Technology.
Изменено пользователем Hybrid
  • DCD-755RE Demon - CD player / USB DAC.
http://www.denon.jp/...RE#.UnxCRJDTlBA
Розничная цена в Японии 23000йен (около 8000 рублей)
NuForce ?DAC-3
В своем третьем воплощении этот компактный ЦАП для работы с компьютером (поддерживается Windows 7/8 и Mac OS) обрел возможность декодировать DSD-аудиопоток. Наушники, активные колонки или усилитель можно подключить к линейному стереовыходу, а AV-ресивер — к коаксиальному выходу цифрового аудиосигнала. К компьютеру ЦАП подсоединяется в асинхронном режиме через порт microUSB.
На фронтальной панели находятся светодиодный индикатор, 3.5-мм гнездо для наушников и регулятор громкости (на прецизионным устройстве TOCOS), одновременно выполняющий роль включателя питания.
Встроенный усилитель способен работать вместе с наушниками импедансом от 16 до 300 Ом и выдает 80 мВт/кан. (16 Ом). В нем нет разделительных конденсаторов, способных внести в сигнал фазовые искажения.
Еще одна полезная особенность ЦАПа связана с тем, что при подключении к ПК установка драйвера необходима только для воспроизведения DSD-файлов. Для отработки PCM-потока драйвер не потребуется. ?DAC-3 читает файлы разрешением до 24 бит/96 кГц.
Устройству не нужен отдельный блок питания, так как запитывается оно по USB-шине. Специальный контур поддерживает напряжение на необходимом уровне.
Корпус модели — полностью металлический. Доступны три цвета отделки: черный, серебристый и красный.
NuForce ?DAC-3 будет доступен во всем мире по рекомендованной розничной цене $ 125
Изменено пользователем vitta77
а вот сайт http://high-end-news.blogspot.ru/ где всякой новой хрени - "как у дурочка махорки" :popcorn:
Не верю я в нормальный звук за 125$, да ещё через USB, а DSD тут как спортивный обвес на ВАЗ 2101.
Дом: Lynx AES 16 - Onkyo DAC1000 - Lukich Tube Amplifier AL4: Beyerdynamic DT911, Sennheiser HD800,
HiFiMAN HE1000SE.
@Френки, На удивление нормальный звук. Много лучше того же Asus, к примеру.
NuForce ?DAC-3
Native Bit Rate :32, 44.1, 48, 88.2, 96 kHz, 24-bit
А эта тема вроде "24/192 USB DACs"?
  • 24-bit/192kHz XMOS High-Performance Streaming Controller supports ASIO and Asynchronous mode
  • USB 2.0 High Speed (480Mbit/s) compliant supporting 8/16/32/44.1/48/88.2/96/176.4/192 kHz sampling rates
  • High-performance ESS-ES9023 24-bit/192kHz DAC chip
  • Maxim MAX9724C Power IC , Low-RF Direct-Drive Stereo Headphone Amplifier with 1.8V compatible shutdown
  • TI- LMV832 Dual 3.3 MHz EMI-Hardened Low-Power CMOS OP AMP
  • Power Supply 1: DC 5V 500mA ~ 2000mA
  • Power Supply 2: DC 3.7V 2600 mAh Li-ion rechargeable battery
  • High-quality volume control and On/Off switch (front)
  • Gold-plated 3.5mm input connector: Analog line input (switched)
  • Gold-plated 3.5mm output connector-1: Headphone or Analog out
  • Gold-plated 3.5mm output connector-2: Headphone / Analog out or 3.5mm optical output for 24/192 (MAX) SPDIF
  • 4-layer gold-plated printed circuit board with >1oz copper thickness
  • Gold-plated USB A socket for 16/48 iDevices (iPod/iPhone/iPad)
  • Gold-plated USB mini-B connector for 24/192 PC operation
  • Recharges via PC USB connection or AC/DC switching power adapter (sold separately)
  • Attractive aluminum cover and ABS plastic body
  • Max headphone output at 1%THD @ 1KHz: 34mW(12 ohm), 60mW(16 ohm), 82mW(32 ohm), 86mW(56 ohm), 36mW(300 ohm), 19mW(600 ohm)
  • Channel separation 60?64dB (1KHz) 33ohms -50dB/<=±3dB
  • Frequency characteristics 20Hz?20kHz (±0.5dB)
  • Total Harmonic Distortion 0.033% (33ohms) , <0.02% (300ohms) , 0.0085% (600ohms)/1mW
  • S/N Ratio 95.5dB/32ohms , 98.1dB/56ohms , 101.6dB/300ohms, 102.1dB/600ohms
  • Charge time approximately 4?5 hours (AC/DC 5V, 1.0-2.0A switching adaptor – sold separately)
  • Charge time: approximately 7 hours (DC 5V 0.5A USB bus power)
  • Music playback time up to 7.5 hours when fully charged
  • Dimensions 68 (W) x 118 (D) x 16.5 (H) mm
  • Weight: 147g Approx.
http://www.adl-av.com/products/headphone_amplifiers/x1/
не ЦАП, но конвертер, причем первый (мной виденный) с разъемом 3.0 http://www.zionote.com/javs/x-ddc.html
но похоже и мало кому известный, 122$...попробовать чтоль
вот еще попробовать, развелось их... :notknow:
ПРОДАМ
Интересный дивайс от TAD стоит добавить в список,правда дороговато будет стоить небойс за 10000$
  • 2 weeks later...
Phasemation HD-7A192
DA чип PCM1794 x2
  • 2 weeks later...
JAVS Audio X-DAC HDS
Навороченная корейская коробочка
x mos
DSD
... интересно, дебюсси есть, асус есть, а беркли нет (?)
... и вообще ни одного из моих даков нет. ESI нет, MS Audio Laboratory нет - ж(
правда, последний насколько помню он всё апсемплит... но 192 он честно, вроде играет
но почему беркли нет?
ж)
Используется:
из более-менее серьёзных:
Наушники
- электростатические: STAX SR-009 (2шт), Sennheiser HE60, STAX SR-507;
- изодинамические: LCD-2 rev. 2;
- динамические: HD800, T5p, HD650, Ultrasone Pro 900;
- арматурные: Westone 4R.
Портатив: C4 Pro.
Транспорт: Berkeley Alpha USB.
ЦАП(ы): Berkeley Alpha DAC Series 2, Mytek Stereo192-DSD DAC (Mastering version), MS Audio Laboratory DAC 1.0, Dr. Dac Prime.
Звуковая(ые) карта(ы): Asus Xonar Essence ST+ASUS Xonar HDAV H6 (дом), Asus Xonar Essence STX (работа).
CD: Creek Evo.
Усилитель(и) для АС: Rotel RA-06.
Усилитель(и) для электростатических наушников: Cavalli Liquid Lightning II, WooAudio GES [upgraded], STAX SRM-727A.
Усилитель(и) для динамических наушников: SPL Auditor 2910, Laconic Lunch BOX HA-06 PRO.
АС: Focal 716v.
Кабеля:
- Siltech Classic Anniversary 770i XLR 0.75m (серебро с золотом),
- Siltech Classic Anniversary 220i XLR 0.75m (серебро с золотом),
- SAEC XR-DIG/S1 AES/EBU 0.7 m,
- Audioquest Diamondback 0.75m (балансные - Solid Perfect-Surface Copper, Triple Balanced, PE Air-Tubes),
- Harmonic Tech (видимо, монозерновые медные межблочники).
Питание: регенератор PS Audio PerfectWave Power Plant 5 Black.
Система Дмитрия (Pipha)
@Pipha,
потому что USB нет
portable: jaybird x2, x3
@Pipha,
потому что USB нет
логично.
А связки видимо не считаются (?).
А продукты ESI - там есть usb, зато всегда делается апсемплинг на 192 (подобно тому, что я писал выше) (?)
а что с двухсотым люксманом?
ни его ни других продуктов этой фирмы нет в основном списке поскольку где-то один пост затерялся про одно из их решений (наверняка не двухсотый - ж) ) на страницах ветки?
Используется:
Наушники
Портатив: C4 Pro.
CD: Creek Evo.
АС: Focal 716v.
Кабеля:
@Pipha,
связки не считаются, цапы с апсемплингом до 192 - видимо, тоже.
Лучше клабньюмену задать такие вопросы, всё таки его ветка.
  • 1 month later...
Не знаю точно, мелькало у нас это, или нет
Nagra HD
http://www.6moons.com/audioreviews/nagra7/1.html
  • 3 months later...
D 1050 USB 24/192 DAC
  • Asynchronous 24/192 USB input
  • 2 x Optical, 2 x Coaxial SPDIF Inputs
  • Balanced XLR and Single Ended Outputs
  • Discrete High Performance Headphone Amplifier
  • Remote Power Supply
Ultrabook ASUS - бесплатный кабель USB - NAD D1050 - VDH Second - Авторский усь Danfi - стоковый кабель - Audeze LCD-2
  • 1 month later...
Пионер приготовил новинку - USB DAC U-05 на ESS 9016.
Весьма неплохо на первый взгляд:
DSD 2.8/5.6MHz file native playback and PCM 384kHz/24bit
6.3-mm SE, headphone output = 180 mW+180 mW (32 Ω)
3-pin balanced and 4-pin balanced headphone outputs = 300 mW+300 mW (32 Ω)
XLR for balanced @ 4.4V and RCA for SE @ 2.4V line outputs.
USB input, 2 coaxial inputs, 2 Toslink inputs, and AES/EBU input.
Изменено пользователем yurix67
Портатив: Cowon Plenue S - Effect Audio Eros II - Rhapsodio Solar;
На столе: iMac (Audirvana+) + Forza Audioworks Twin USB Cable + TEAC UD-503 + JVC HA-DX2000; Denon AH-A100;
В комнате: Sony HAP-S1 + Monitor Audio Silver RS6.
