Final Audio
Dr.Head Awards 2025
Pro-Ject ART
Dr.Head Awards 2025
KEF
Dr.Head Awards 2025
Premiera
Dr.Head Awards 2025
Noble Audio Artemis 2
Dr.Head Awards 2025
Austrian Audio
Dr.Head Awards 2025
Aurian
Dr.Head Awards 2025
Album Player (Aplayer)
это элементарно - iso/boot/isolinux/isolinux.cfg добавляем ещё один вариант загрузки - копи-пэст label dCore и 3 строки kernel, initrd, append. dcore -> dCore 2, bzImage -> bzImage2, vga=795 -> text default dcore label dcore kernel /boot/bzImage initrd /boot/dCorestretch64.gz append initrd=/boot/dCorestretch64.gz nodhcp tce=LABEL="TINYAP" waitusb=10 noswap nozswap host=tinyap loglevel=3 rd.udev.log-priority=0 showapps vga=795 cde net.ifnames=0 blacklist=floppy,pcspkr,ppdev,parport,parport_pc label dCore 2 kernel /boot/bzImage2 initrd /boot/dCorestretch64.gz append initrd=/boot/dCorestretch64.gz nodhcp tce=LABEL="TINYAP" waitusb=10 noswap nozswap host=tinyap loglevel=3 rd.udev.log-priority=0 showapps text cde net.ifnames=0 blacklist=floppy,pcspkr,ppdev,parport,parport_pc implicit 0 prompt 1 timeout 1 tce/sceboot.lst - диезим, отключая ненужные компоненты: #usb-serial-4.8.17-tinycore64 alsa-base #alsa-firmware-loaders alsa-modules-4.8.17-tinycore64 alsa-utils mc #xorg-all #flwm_topside #midori apmenu если цап USB, то usb-serial оставляем включенным и тд., по названиям пакетов можно догадаться. tce/mydata.tgz/opt/bootlocal.sh #!/bb/ash # put other system startup commands here loadfont < /opt/UniCyr_8x16.psf mount.sh #alsactl -f /var/lib/alsa/asound.state restore #sudo wifi.sh -a #sudo /opt/net_init.sh #aplayer.sh #aprenderer.sh #apmenu.sh touch /etc/sysconfig/superuser sudo dmesg -n 1 sudo mkdir -p /media/iso tce/mydata.tgz/opt/bootsync.sh #!/bb/ash # put other system startup commands here, the boot process will wait until they complete. # Use bootlocal.sh for system startup commands that can run in the background # and therefore not slow down the boot process. /usr/bin/sethostname box /opt/bootlocal.sh & sleep 5 echo
После всех этих манипуляций с флешкой система перестала грузиться.
Пишет:
tc@tinyap:~S /opt/bootlocal .sh: line 8: aplayer .sh: not found
/opt/bootlocal .sh: line 10: apmenu .sh:not found
Что не так сделал?
Может все изменения нужно было проводить прямо на источнике в МС?
Изменено пользователем pupsik2005
музисточник-GIGAH170M-D3H,PentG4400,Juli@ PCI-выход по аналогу; CD-MARANTZ 72MKII; усь-REVOX A78 MKII; акустика-YAMAHA NS-515F напольные+CASTLE ISIS
  • Ответов 20,8k
  • Просмотры 3,2m
@pupsik2005, сообщения об ошибках соответствуют отключению из загрузки в файле tce/sceboot.lst файла apmenu.sce. Из него устанавливаются командные файлы, которые не обнаруживаются при загрузке.
Но насколько я правильно понял,AleXH советует диезить apmenu.sh.
По рекомендациям @AleXH, в файле tce/sceboot.lst строка apmenu не диезится.
МузПК (Asrock Formula+Xeon+Shaare Deluxe+полный ЛБП) - Yulong DA8 - Vincent SV238 - Heco Statement. Кабели - моножильные серебро и медь ОСС в х.б. изоляции + ATL Cu, Oyaide 004 и т.п. Выделенки на каждый компонент. Акустические поглотители и Skyline.
@IgorA, а что если посимвольно выводим индикатор, а после 100% загрузки строку не переводим, а посылаем 28шт. 08h, стирая индикатор и на его месте выводим параметры - и овцы целы и волки сыты? :)
такую крамолу я не советовал
Изменено пользователем AleXH
@Алексей Андреев
Попытка включить Native в консольной версии будет вызывать проблемы у большинства, поскольку поддержка этого режима под Linux весьма ограничена.
Консольная версия даёт полный минимализм тем, кому он, действительно, нужен. Поддержка Native - усложнение реализации, которое доступно в полной версии. В которой тот же движок, что и в консольной, и которая на измерениях тестовых сигналов при равных параметрах настроек не демонстрирует явных отличий от консольной версии.
Проверил - метод работает, отработавший индикатор затирается и на его месте выводятся параметры. Отыгрываем 2 строки.
Прошу прощения,это я попутал с tce/mydata.tgz/opt/bootlocal.sh
@AleXH, стирать символы в консоли я не планирую.
ну вот этого я совершенно не понимаю - где логика??? - индикатор своё отработал, устарел, лишь захламляет экран, на его месте выводим параметры - всё идеально
@AleXH
Консоль - устройство последовательного вывода. Без особой нужды (которой нет) лучше там ничего ранее выведенного не стирать. Это не очень естественно и возможны накладки. Потоки звукового движка и обработчика команд выводят в консоль асинхронно. Никто не запрещает пользователю ввести команду во время длительной загрузки, которая перемешает вывод разных потоков и стирание своего вывода одним из них отработается криво.
отработается криво
значит нужен флаг, что прерывания не было и тогда затираем, иначе нет. И затираем в процедуре вывода индикатора в конце, а не в начале вывода параметров. - В результате будет такое же поведение, что и сейчас.
Выяснил,что загружаться ОС перестаёт после того,как диезится параметр #usb-serial-4.8.17-tinycore64 в файле tce/sceboot.lst.
И самое интересное,что при раскоментировании параметра usb-serial-4.8.17-tinycore64 загрузка не восстанавливается.Нужно заново переписывать флешку.
@AleXH
Пользователь может ввести команды во время загрузки, что добавит строки в разрыв вывода индикатора.
Я предлагаю дискуссию о способах вывода индикатора завершить. Мнениями мы обменялись, пока достаточно, спасибо.
дело не в этом, вы накосячили где-то в другом месте.
@Алексей Андреев
дело конечно Ваше, но пояснения имхо не логичны. Поддержка натив в линукс аналогична полной версии, значит и проблемы аналогичны. Отзывы последних страниц показывают явное не соответствие звучания измерениям тестовых сигналов в пользу ап.
Определить будет ли влиять на звук усложнение реализации можно только попробовав. И если не деградирует, то натив в ап лучшее решение для дсд на сегодня.
Изменено пользователем Алексей Андреев
@Алексей Андреев
И DoP доставляет в ЦАП в сохранности оригинальный DSD поток, не преобразуя его в PCM. При этом позволяя сохранить консольному плееру тот минимализм реализации, который и делает его чем-то особым. В этом моя логика. У кого душа просит Native - полная версия плеера в их полном распоряжении. И даже там Native будет далеко не везде, а в дистрибутивах с официальным ядром - мало где.
Да,нет.
Проверяю третий раз.На свежезакатанной флешке,кроме команды #usb-serial-4.8.17-tinycore64,ничего не трогаю,и не исправляю.
При загрузке выдаёт ошибки и сичстема не грузиться.
Закатываю флешку по новой теперь вообще без исправлений.ОС загрузилась без проблем.
Пробую закоментировать второй параметр #alsa-firmware-loaders.Опять выдаёт ту же ошибку.Переписываю флешку без изменений.Всё отлично.
<p>
<br />И DoP доставляет в ЦАП в сохранности оригинальный DSD поток, не преобразуя его в PCM.<br />
<br /></p>Зачем тогда натив в полной версии? Для того, чтоб «вызывать проблемы у большинства»?
Особым, наверно, консольный плеер делает его звук и добавление натив эту особенность может только усугубить, пусть хотя бы на поддерживаемом железе. Имхо.
@pupsik2005,
У Вас случайно не через джульку звук выводится?
pupsik2005, У Вас случайно не через джульку звук выводится?
Совершенно верно,через неё.
@pupsik2005, то, в чём вы правите файл на концах строк вместо 0A ставит 0D0A, поэтому и не взлетает. FAR ставит такие же концы строк, что уже есть в тексте.
@Алексей Андреев
В полной версии выбор Native просто блокируется для того большинства, у которого он вызовет проблемы. В консоли же нет блокировки ввода команд и интерфейс консольного плеера должен будет "обогатиться" дополнительным урегулированием ввода пользователем невыполнимых желаний. Что его минимализму и простоте способствовать не будет. И это помимо собственно разрастания кода движка.
Изменено пользователем IgorA
Правлю в WordPad.
а зачем её трогать - она уже задиезена и юльке она не нужна - смотрите как у меня сделано, у вас должно быть также
в WordPad
В помойку - поделки MS с линуксом принципиально не работают нормально
Последние посетители 1
