Focal Utopia, Elear, Listen?
Focal’s new headphones mix metal and leather for a high-end audio experience
0
Casque_Gam_Ut_Elea_Pan.0.0.jpg <p>
(Left: Elear / Right: Utopia. Image credit: Focal.)
Share on Facebook (69) Tweet Share (4) Pin (1) Share
After more than 30 years in the speaker business, French audio company Focal started taking on headphones in 2012. Today, its headphone line grows from four to seven units with the addition of three new models: one meant to rival a pair of Beats, and the other two meant for serious audiophiles.
The first model is called Listen, and it's a pretty straightforward pair of closed-ear headphones. It has a plastic body and a 4.6-foot cord with a mic on it terminating in a 3.5mm headphone jack. There's no built-in wireless or active noise cancelation, though during a brief demo, the Listen did seem to block out noise pretty effectively. They'll sell for $249.
The Listen are comfortable, but there's nothing particularly compelling about them. On first (ahem) listen, they didn't appear to deliver the audio quality you'd expect from a $249 pair of headphones. And while the Listen’s reliance on a headphone jack seems completely normal today, it’s very possible that it’ll soon limit them, as new smartphones begin to eschew the standard 3.5mm input.
Listen_Reglage02.0.jpg <img alt="focal listen-news-Focal " src="https://cdn1.vox-cdn...age02.0.jpg"> Focal Listen headphones. Image credit: Focal.
The other two headphones are a bit more compelling and feel like the products Focal was actually interested in making. The cheaper of the two is called the Elear and will sell for $999; the other model, called the Utopia, will go for $3,999. In both cases, Focal says its intention was to closely reproduce the feel of listening to a nice set of speakers, rather than tightly clamped headphones.
I only spent a few minutes with them, so I can't fairly say whether they deliver on that goal. But during a short demo, they sounded full and clean (although, they seemed to have a closer soundstage than I'm used to.) When paired with a high-end DAC and amplifier, Focal claims that the Elear can hit frequencies between 5Hz and 23kHz, while the Utopia can reach from 5Hz to 50kHz, with an impedance of 32 ohms for each.The headphones look industrial, but they feel luxurious
The Elear and Utopia — in case the latter’s name didn't suggest it — are basically meant for luxurious home listening, and they have a comfort and build quality that lives up to their goal. Both headphones have open backs, with grated metal curving across each model's earpieces. The Elear has an aluminum body and leather headband; the Utopia mixes metal with carbon fiber for reduced weight, while using pitted leather on both the headband and ear cups.
The look is almost industrial. I don't hate it, but there’s something to be said for the vibe of a pair of headphones matching the music they’re best at reproducing. Focal says these headphones are meant for pretty much anything, and they sort of look that way, like they’re designed to get the job done and nothing more.
While I didn't spend enough time with either model to say how it feels after being worn through an entire album, I was surprised at how the size and heft of both felt almost unnoticeable once they were on my head. Their style was, of course, unnoticeable at that point, too — so, it’s worth weighing which parts of a headphone you value.
Both models come with a 13-foot cord that terminates in a quarter-inch stereo jack. That can sound excessive, but it’s not out of line with the audiophile experience Focal is pitching. If you have these headphones hooked up to your stereo, you’re going to want a cord that can stretch across the room to your easy chair. These ought to be able to do that. Both allow their cables to be detached, too, so they can be swapped out for something shorter if you’re planning to sit right beside your audio source.
Focal will be releasing all three models over the next month. The Listen will be available starting July 15th. The Elear and Utopia will go on sale a bit earlier, beginning June 29th.
All images courtesy Focal.
Hint: Use the 's' and 'd' keys to navigate
  • Ответов 518
  • Просмотры 100,3k
  • В начале прошлой недели предоставили возможность послушать Utopia. Рассчитывал хотя бы на пару-тройку часов, а получил всего час. Поэтому ни с чем не сравнивал, а просто слушал. Вследствие этого впе
  • Hong Kong AV Show 2016   На стенде Focal наушники Utopia были выставлены с цапоусем Goldmund THA 2, я конечно послушал их еще раз, ажиотажа не было, разработчик (на фото с бородкой скучает в телефоне
  • Вчера побывал у Андрея в гостях, спасибо ему за гостеприимство и за возможность познакомиться с новинкой. Хочу сказать, что очень часто солидарен с ним в оценках наушников и трактов, и Elear, здесь б
Интересна начинка. Утопия судя по надписи с бериллиевым драйвером. Соответственно динамические уши. Соответственно еще один неподъемный имиджевый топ. Уверен, что играть будет отлично, но цена явно привязана к линейке Утопий.
Навскидку из любимого в музыке: Аукцыон, Аквариум, Мегаполис, Helge Lien trio, Rebekka Karijord, Kari Bremnes, Esbjorn Svensson, Tori Amos, Jorane, Шостакович, Прокофьев, Григ, Jon Lord, Mark Knopfler, Morten Harkett
:shok: вау, очень крутая новость, спасибо! :good:
@Remilio, нежданно, негаданно, выкатили.. На любой вкус и кошелек :) 249, 999, 3999 :) Утопии по дизайну мне пока непонятны, но чую материалы там хорошие используются!
Изменено пользователем kabuto
Моя система:
Источник:
Винил: Thorens TD318 (Pickering XV-15/D6800EEE-S) -> Авторский ламповый фонокорректор ->
Цифра1: ATV3 -> optical cable -> Behringer Ultramatch SRC2496 Mod
Цифра2: Ноут -> AQ Forest USB -> Energy Audio DACore v2
Усилители:
Авторский ламповый двухтактный на 6SL7GT и 6п6с (6V6)
Наушники:
Pioneer SE-505
1more TDOE
Grado SR80i
Grado iGrado
Sennheiser Momentum 2.0 AEi
DUNU Titan 3
АС:
HECO Direkt Einklang
Portable:
iPhone X
Meridian Explorer 2
Meier-Audio PCSTEP
Earstudio ES100
П-пафосно
Д-дорого
когда открывал тему, думал кто-то колонки утопии купил)
Изменено пользователем AAB
MIT ISO-DUO -> LynxStudio Hilo Thunderbolt -> Beta22 balanced by (Helium) -> Abyss AB-1266
Система AAB
Портатив: телефон -> Sone MDR-1000x (Ve Monk Plus)
Акустика -> Devialet Phantom Silver Duo
В продаже:
Acoustic Signature Tango Phono Mk3 - 40 тр
Synergistic Research Element Copper (Us) - 26 тр
Даже Master 1 от Пионеров переплюнули по цене. Ай молодцы - кто дальше? :))
Там же поле электростатов да Эбиссов...
@AAB, К Гранд утопиям в подарок давать будут:)
Моя система:
Источник:
Усилители:
Наушники:
Pioneer SE-505
1more TDOE
Grado SR80i
Grado iGrado
DUNU Titan 3
АС:
Portable:
iPhone X
Meridian Explorer 2
Meier-Audio PCSTEP
Earstudio ES100
Я мечтал о том, чтобы Focal выпустили hi-end наушники и они это сделали. :good: Внешне мне очень нравится. Если к августу в Россию завезут, у меня появится еще один серьезный повод посетить столицу :)
П-пафосно
Д-дорого
Никогда не понимал подобных комментов про вещи от людей, которые по сути могут себе их позволить.
Изменено пользователем Remilio
Я не думаю просто, что они могут переиграть хешки или одинов.
Система AAB
В продаже:
А я хочу в это верить. По крайней мере в то, что это будут едва ли не лучшие динамические наушники на рынке. Потому что если не топовому производителю акустики, то кому под силу их сделать? Могу уже сейчас поспорить на пиво, что будут ну точно не хуже К812 и Пионеров.
Лучше - это ты про те которые за 3999?
Система AAB
В продаже:
Да. За 999 будут очередные проходные наушники, которые нафиг никому не сдались. Мой прогноз профана :)
Ну учитывая что абисы стоят на 500уе дороже, я думаю оно нафиг не нужно
Система AAB
В продаже:
@сergey,
ужо футбол скоро смотреть, а вы мне такое видео подкидываете! Змий! :D:good:
Вариант Утопии лично мне было-бы интересно послушать. Остальное, интереса не вызывает. ...все как и с АС этого бренда.
Изменено пользователем Александр Карелин
телега
Да но 4к зелени, четыре! :stopit:
Изменено пользователем Gold
<p>
<br />Да но 4к зелени, четыре! <br />
<br /></p>
Так я и не про покупать... а про послушать. А ценник конечно насквозь дурной, но жизнь их пообломает.
телега
А динамические уши за 4кБ есть еще, или это - рекорд?
Продаю (цена договорная)
Усилители для наушников:
Наушники:
и др. ))
ЦАПы:
Да вообще все распродам...
По абсолютной (без учета инфляции и т.д.) цене вроде бы рекорд. А так, R10 - цена на вторичке от 3к для Басона до бесконечности для простых смертных.
Да, было бы любопытно послушать. Чисто теоретически, думаю, потенциал совершенствования далеко не исчерпан у всех трех технологий.
Но на практике, боюсь, будут очередные +5% за тройную накрутку в цене против классической линейки топов 812-800-т1.
Knowledge is not wisdom. Wisdom is not truth. Truth is not beauty. Beauty is not love. Love is not music. Music is the best. — Frank Zappa
Избранные журналисты и пользователи уже послушали Utopia и провели ряд параллелей с конкурентными продуктами. Есть вероятность, что это новый лидер пространственной передачи. Кое-кто отмечает, что Utopia строит сцену правильнее, чем HD800. Odin, на сколько мне известно, не имеет выдающихся результатов именно в этом направлении, а HE-1000 получились не слишком сбалансированными наушниками с чудинкой. Таким образом, Utopia могут быть так называемым end-game решением для охотников за реалистичной звуковой панорамой в сочетании с беспристрастной подачей материала. Хотя, после доставки первой партии к покупателям может выясниться, что в действительности звук кривоват, а сценка средненькая. Нужно подождать, пока утихнет раж анонса и начнут появляться стоющие доверия мнения частных новообладателей. Там и рассудим.
Изменено пользователем Гедонист
Ну, это уже сумасшедшие коллекционеры "дуют" цену... Я имел ввиду аппетит и совесть производителя (или, скорее, ее отсутствие) .
Наушники:
и др. ))
ЦАПы:
Если доверять одной рускоязычной статье, новые R10 на старте продаж в конце 80-х годов оценивались в $2500, а концу выпуска спустя пару десятилетий уходили по $6000. Так что нет, рекорд не побит. Да и не надо нам таких рекордов.
Ну на старте продаж r10 вроде бы 2500 стоили, а это 80е годы.. Я не экономист, но насколько я понимаю, в те годы 2500 - это явно не меньше 4000 сейчас.
