Abyss Design AB-1266
Как я понимаю из отзывов, конкретно в Диане за счет PHi сцену расширили, или что там еще по звуку?
Original Diana: The original Diana sounds a bit less dynamic. It is also a little bit warmer. It doesn’t have the same level of detail retrieval of the Diana Phi. However, compared to other headphones in the $3000 range, it is perfectly acceptable in terms of detail, the Phi just takes it to that next level. The original Diana seemed to work better with poorer recordings, as it has a little bit less transparency. The original Diana is probably the better choice of headphone if you just want an all rounder, and the Diana Phi is the better choice if you want a dedicated hardcore top of the line headphone. A part from the extra bit warmth on the original Diana, the tonal signature is very similar. The original Diana was comfortable for me, but for some people I know it isn’t. The original Diana’s pads were over ear for me…just. However, for people with larger ears, they may be more on ear than over ear. The Diana Phi pads should solve that. The Diana Phi also has a tweaked headband that should provide a fit for more head shapes than the original Diana.
AB-1266 Phi: The AB-1266 is, for me, and all or nothing headphone. Its big, brash, and makes no compromises. I have always found it comfortable, but again, I know some people don’t. The Diana Phi is much lighter and comfortable than the AB-1266. However, you do lose out on a bit sound stage and imaging precision with the Diana Phi. This is to be expected as you can’t manually manipulate the angle and width of the frame like you can with the AB-1266. Tonally the Diana Phi is pretty much the exact same, apart from the lack of slight sibilance that I mentioned earlier. If you want the full on Abyss experience, consider purchasing the AB-1266 Phi CC. There is nothing else like it on the market. If you don’t mind a little bit less soundstage, and want a lighter headphone that can be worn all day comfortably, consider at least trying the Diana Phi. You really aren’t missing out on much, in my humble opinion. Might I still purchase a pair of AB-1266 Phi CC some day? Perhaps. However, it is a lot of money to spend when I feel I am getting most of the experience with the Diana Phi. Time will tell I suppose
  • Ответов 4,1k
  • Просмотры 528,1k
  • Несколько месяцев тому назад я обещал выложить сравнительный обзор Abyss 1266 и STAX SR-009. Прослушивание начал еще в Москве, отработав из жанров только БСO, но в связи с переездом вынужден был его п
  • kleymor.metal
    kleymor.metal
    Думаю, еще один небольшой отзыв об Abyss не помешает.   В этот раз мне их внешний вид не показался устрашающим, возможно потому что уже стал к ним привыкать. Посадка может быть удобной, но надо настро
  • Пришло время описать свои впечатления от сравнения AB-1266 и 009 5 апреля сего года на встрече Head-FI в Нью-Йорке. Сначала скажу пару слов о себе. У меня самого не так много опыта прослушивания стаци
Да , спасибо,я читал
У Дианы PHi звук как бы голографичнее получается, и сумка другая :yes:
Изменено пользователем chontvari
Мой тракт здесь  https://forum.doctorhead.ru/forums/topic/38291
Да , спасибо,я читал У Дианы PHi звук как бы голографичнее получается, и сумка другая
Амбушюры говорят гораздо удобнее еще.
У Дианы
сумка другая
... и туфельки новые... и прическа :)
Берегите свои Abyss1266 rev.1.. Собственно брутальный, массивный, фирменный звук на них закончился, дальше погнала азиатчина.
Значит мне везет -))))
@chontvari,В ту же сторону.
Михаил, а вы Диану всё таки послушали? А был какой то отзыв? А то мне очень интересно насколько это альтернатива по звуку АВ1266 при явном снижении ценника.
Не альтернатива. Но звук отличный. Отличается так же как и по размеру)))
Отзыва не было. Последнее время они бесполезны. Никто ничего не слушает, но у всех свое мнение. В эту кашу лезть не охота.
Изменено пользователем ДокторЗло
                                                             Алиса в Стране Чудес
  • 3 months later...
"Известный инженер с дружественной площадки - поведал в отношении Wells Audio, Headtrip 2:
Всем привет.
Недавно начал читать о Хедтрипе , это такой усилитель для тугих и жадных до напряжения наушников. Усилитель более чем легендарный беспорно.
И к сожалению я его еще не слушал.
А очень хочу.
Но и купить желания к сожалению нет, так как цена на мой взгляд запредельна.
Но , в процессе рассмотрения информации и фото , я особенно внимательно изучил фото. И сразу возникли некоторые технические вопросы…
Во первых, на мой взгляд устройство собрано в Китае и отправлено в США а затем на мир.
Выдают некоторые странные моменты конструкции, особенно проводка и соединения.
Хотя стоит признать часть деталей фирменные.
Принципиально меня заинтриговало не это.
Я не мог понять , что там в усилке…
Ведь если судить по проводам и соединениям на входе , на выходе и на бп , то чисто из увиденного я делаю следующий вывод.
вход псевдо балансный ( иначе там был бы переключатель для xlr ) .
То есть что xlr что rca это одни и те же провода.
Естественно , мы бы увидели или 2 аудио трансформатора или хотя бы счетверенный резулятор громкости "Козьмо ".
Далее , это усилитель с двуполярным питанием в АБ классе на … паре выходных транзисторов.
То есть это не балансный усилитель тем более.
И это даже не дуал моно…
Так как трансформатор всего 1 и кабель питания сначала идет в одну плату усилителя , а затем из первой во вторую.
Выход усилителя идет одновременно на 4 пиновый хлр и 3 пиновый джек , но как им это удалось так )))
Он же не балансный, именно по этому".
Изменено пользователем Pentode
То, что он небалансный - Америку не открыли. Очевидно, что и не двойное моно. Подключение наушников по XLR кабелю к небалансному усилителю элементарно и встречается сплошь и рядом. Откуда следует, что усилитель в классе АВ, а не чистом А, ? Судя по размеру радиаторов, таким чистый класс А позавидует!
судя по размеру трансформатора..
Денег нет , но на фото передерну
Прикольно, не поспоришь
А по размеру радиаторов так не скажешь...
@donPedro, надо на экспертизу его отдать..
возможно 100% Китаец..
В поликлиннику на опыты сдать! :)
автор подозрения начал своё расследование в Китае, планирует выйти на след и обнаружить подпольный завод..
А как же надпись на морде: "Hand maded in California" ?
"эффект забора" :popcorn:
А может китайцы уже и Калифорнию заселили. Тогда всё по чесноку.
К радиаторам крепятся пара транзисторов TO247 и, кажется, пара T220 или TO126.
Можно было обойтись и радиаторами в четверть имеющихся.
По начинке усилитель чудовищно переоценен, конечно.
Ваяю AMB Beta22, KG Dynahi, KG Dynalo, KG Krell KSA5, KG CFA, KGSSHV Carbon, KGST, KG Grounded grid, KG Blue Hawaii, STAX SRM-T2 и т.д.
Наушники: Sennheiser HD800/HD800S/Hifiman HE-500/HE-5XX/Audeze LCD-XC/Fostex TH900mk2/Sennheiser IE-80S
само собой, это и есть woo audio. А хедтрип так пишут, к примеру, из-за того, что готовые платы а корпуса устанавливают в Калифорнии
Ага. Но по какой-то причине звучит лучше, чем ближайшие))) вы понимаете о чем я?
И конечно есть индивиды, которые не могут без теории заговора. Вся их жизнь - это желание бросить дермеца на вентилятор. Конечно все производится там, где написано. У меня знакомый был у них на производстве. Достаточно кустарно, но все по правде. Каким же дебилом надо быть, чтоб посмотреть на фото и объявить страну сборки)))
И еще большим, чтоб это еще и обсуждать серьезно.
@ДокторЗло, это всего лишь предположение, ибо человек плотно завязан с Китаем и производством там..
а вы сразу дебил, дерьмо и т.д...
А заклевать именитого, заклевать его :)
Но вот зачем? К примеру, данный форумчанин пишет:
"Не слушал, но видел фото", "Не слушал, но видел АЧХ" - для меня это, как мем :)
Поэтому хочется пожелать ему продуктивного прослушивания данного усилителя и сравнения с близлежащими оппонентами, для более продуктивного отзыва, но уже с точки зрения звука. Вот это будет уже действительно взвешенный отзыв.
Изменено пользователем Rutger
Система Rutger
@Rutger, на мой взгляд публичный форум и создан для обмена мнениями..
один нахваливает, другой критикует, пятый мечтает, другой ненавидит или развлекается и т.д.
и ещё куча комбинаций.. и в этом и есть прелесть сообщества по интересам..
@Rutger, да никто не спорит, что он может нормально звучать. Но продавать такое за 7000$ с псевдо-балансом, одним трансом и китайской сборкой это наи$%во
Изменено пользователем firewheel
DAC: Muse 192
HEADPHONES: HD800S
я пока помечтаю...
