pm325
Пользователи
  • Зарегистрирован
  • Посещение
Весь контент pm325
  1. Кстати, если вместо пресловутого USB задействована, например, плата PinkFaun I2S Bridge, то как в этом случае сравнить путь прохождения сигнала? Под Windows вывод KS, под Linux - ALSA.
  2. This dac does NOT do DSD512. From Jeff Zhu, the designer: By now, Spring can't support DSD512. You might see some picture shows DSD512 but it's not supported by now. I was planned to support that, but it seems have no music source at all even the test file. Sony has stopped DSD and turn to DXD now. So DSD256 might be the end of DSD. However, DSD512 is not so hard. If it is really needed, I can put it into 'May'. Spring can support DSD512 by upgrading the firmware also, but it must return to factory. I'm afraid it will bring some troubles for dealing this matter. The oversampling is done by AK4137, 'OS PCM' converts the input stream to PCM no matter it is PCM or DSD, then send to DAC. 'OS DSD' converts the input stream to DSD no matter is is PCM or DSD, then send to DAC. 'OS' oversamples the input stream. If it is DSD input, it oversample to DSD256. If it is PCM input, it oversample to PCM384K or 352.8K 'NOS' does no oversampling. send the input stream directly to DAC module. About DSD 'native', it is the way the USB transfer the stream. You know DOP, which is DSD Over PCM. DOP put the DSD into a PCM stream. At the receiver end, it just unpack the PCM stream and get the DSD back. DOP does NOT change any bit of DSD stream, just sending it with the package. So it waste some data rate. At the same data rate, DOP is 1/2 of DSD native, the other 1/2 is the package. So DOP and DSD native are all bit perfect. The DSD stream sending to DAC is all the same. So, now you should know, DSD native is just about the way it transfer the stream. Not describing the way it doing digital to analog conversion. At the DAC stage, the DSD stream can convert to PCM then do the final digital to analog covert. Actually, most DAC chips doing this inside the chip. One point need to be remember, DSD stream can't do volume attenuation. If this chip can do digital volume control under DSD mode, then is must converted to PCM already. Let's go back to Spring. If Spring works in 'NOS' mode. There is no oversampling, no conversion, just the original data doing the final digital to analog conversion. I will not explain how it does PCM conversion, you should already know quite well about it. There is a lot of resistor ladder DAC, they are born to do this. I just explain how Spring can do 'discrete DSD conversion'. Actually it is like DCS and CHORD. If you looking to DCS and CHORD's pcb, you will find 'discrete DSD conversion' is also using switches and precision resistors, like resistor ladder dacs. So, no matter it is 'discrete DSD conversion' or 'discrete PCM conversion', they all use the same discrete devices. Just work in different architecture. That makes possible to combine these two modes in one device. Best Regards Jeff Zhu
  3. Напряжение питания в вольтах. Предел стабильности около 120MHz и дальше хоть жидким азотом поливай. Если бы все упиралось в тепловыделение... там еще ворох других проблем. Можете поинтересоваться у Марата, сколько он отлаживал свой "тутти".
  4. Производители знают как о рекомендованных режимах работы чипа, так и о последствиях разгона
  5. Дабы не быть голословным, приведу несколько ссылок: https://hifiduino.wordpress.com/2012/01/20/interesting-details-of-weiss-implementation-of-es9018/ http://www.xtremeplace.com/yabbse/index.php?topic=181813.0 http://www.gryphon-audio.dk/products/da-converters/kalliope.aspx в чем она состоит, в наличии и/или их высокой стоимости? В необходимости модифицикации фабричного изделия.
  6. Согласен, что описанная многоходовая процедура плохо сочетается с предвкушением удовольствия от прослушивания С другой стороны, внутренний формат представления данных для dCS Ring DAC (5bit, 2.8MHz) и наличие встроенного апсемплинга PCM2DSD наводят на мысль, что лучше избежать двойного преобразования. Из меня "специалист" тот еще выходит - не знаю даже что такое OSF На практике отмечаю следующее: 1. при воспроизведении DSD в режиме native DSD ЦАП греется ощутимо меньше, чем при воспроизведении PCM; 2. младшая "сабря" отличается довольно визгливым характером при воспроизведении PCM, может даже добавить сибиллянтов там, где их и нет. При воспроизведении DSD она теряет свой визгливый характер и звучит на удивление ровно (особенно заметно при прямом сравнении файлов DSD и файлов PCM, конвертированных из этого-же образа SACD); 3. в режиме DoP образы SACD воспроизводятся, но визгливость "сябры" и нагрев при этом сохраняются на уровне воспроизведения PCM. Отсюда делаю умозрительный вывод, что при воспроизведении DSD ЦАП "не используется на полную силу". Вывод скорее что цап лишний раз не напрягается промежуточным пересчетом и конвертит в аналог свой родной(нативный) формат. OSF - oversampling filter. Собственно, характерный "почерк Sabre" на PCM не что иное, как результат нойз-шейпинга. В качестве эксперимента можете подать на вход поток 24bit/352.8kHz, полученный из исходного 16bit/44.1kHz с помощью AuI 44x48 ConverterR с "no pre-ringing filter". Визгливости поубавится, а если OSF вообще отключить, то на слух узнать чип будет весьма проблематично. От DSD64 до нативного формата представления данных довольно далеко, качественный скачок наблюдается, начиная с DSD256, но тут возникает другая проблема - дальнейшее увеличение битрейта требует более высоких частот тактовых генераторов (грубо, 90/98MHz). В новом ES9038Pro можно использовать клоки меньшей частоты.
  7. Небольшое дополнение к предыдущему ответу, поскольку сам столкнулся с подобной проблемой (источник - SDtrans384): во-первых, dcs Puccini может принимать DSD64 по входу spdif только в формате DoP, поэтому результат конвертации ISO -> DSF/DFF необходимо перевести в него с помощью DSD to PCM Converter (в поле DSD Native выбирается соответствующий формат); во-вторых, образ iso-sacd может быть с dst-сжатием, что можно проверить, либо посмотрев заголовок файла в бинарном виде, либо попробовав открыть его в Tascam Hi-Res Editor. В таком случае необходимо предварительно разжать образ тем же scarletbook или задействовать DST2DSD.
  8. На форуме computeraudiophile было высказано подобное предположение: They can play DSD natively by simply substituting all 1's by maximum internal sample value and 0's by minimum internal sample value, no change in sample rate. This way multibit SDM can work as completely native 1-bit DSD converter without performing further processing.
  9. Если бы не утверждение на сайте MSB открытым текстом (From there the DSD 1bit 2.8 MHz (DSD64x) and DSD 1bit 5.6 MHz (DSD128x) is mapped to our 1.4 MHz 24bit Ladder DAC with no analog filtering), вопросов бы не было. У Лукаса есть модель, где реализован упомянутый low pass filter, но речь не о ней. Более того, далее по тексту следует предупреждение о нежелательности внешней конвертации в PCM (It is VERY important to note that all players have the option - and usually the default option - of converting DSD into PCM in the program and outputting a down-sampled version. This will sound VERY bad.). Насколько мне известно, с пресловутой микросхемой Sabre ситуация несколько иная - входной поток в обязательном порядке проходит встроенный OSF (его отключение приводит к невозможности воспроизведения DSD, остается только PCM с необходимостью внешнего апсемплинга), в результате получается 5- или 6-битный поток с частотой около 40МГц, поступающий на матрицу из 64-х 1-битных декодеров. Увеличение битности сигнала позволяет осуществлять регулирование громкости, так что говорить о "native DSD" в данном случае можно лишь с большой долей условности В общем, вопрос пока остается открытым...
  10. Кстати, может ли кто-нибудь объяснить, каким чудесным образом MSB в своих R2R цапах организовали воспроизведение DSD без конвертации в PCM? Аналогичный функционал заявлен у Rockna и Lampizator (свежий Atlantis R2R DAC, например, имеет ревизию DSD only). Или же разработчики лукавят?
  11. Как максимум - аккумуляторное питание входного каскада в колоночном усилителе ASR Emitter II Exclusive. Сорри за оффтоп.
  12. Если с сетевым интерфейсом и коаксиальным выходом - Sonore Signature Rendu или младшую модель Sonore Rendu. С выходом USB - Sonore microRendu.
  13. Есть способ проще - плата PinkFaun I2S Bridge, вывод по этому же протоколу
  14. Amare Musica Tube DSD Dac - Не совсем DIY`ерство, как у Lampizator`а
  15. Sonore PureDSD Dac, Signalyst DSC1, Soekris DAM1021 - первое, что вспомнил.
  16. Еще можно обратить внимание на рендерер Sonore Rendu, а если не смущают DIY-разработки, то и на SDtrans384.
  17. Например, первая ревизия iPurifier для Berkeley Alpha бесполезна, тогда как Hydra-Z отзывается положительно. Что "намудрили" во второй ревизии - неизвестно.
  18. Описываю свои впечатления "как есть". Сразу из коробки W3000ANV вообще "бумбокс", на мой ух, разумеется
  19. W3000ANV более камерные, басовитые и частично скрадывают послезвучия на контрасте с DX2000. Правда, я меня усиление под сабж далеко не оптимальное, тогда как в паре с Yamamoto HA-03 Шарапова наблюдается явная синегрия. На норвежском джазе я просто "выпадаю из реальности". Мой экземпляр HD800 (12ххх) сравнивался с поздней серией (39ххх, если не ошибаюсь). Ожидаемо меньшая вирт. сцена и более плотный звук, но замыленности отмечено не было.
  20. JVC DX2000 на просторах нашей необъятной отнюдь не в единственном экземпляре - в моем кулацком хозяйстве, после рекабелинга на silvergold, разбавляют компанию W1000 и W3000ANV. Ранее 1000-ми викторами не владел, так что на привыкание не спишешь... да и разные они. На усилении трудится Luxman P-1u.
  21. В режиме KS x64 Full Memory влияние со стороны плеера также минимизировано или есть существенные отличия от ASIO? У меня плата вывода Pink Faun I2S Bridge, производитель выпустил драйвер только под KS, родного ASIO нет.
  22. К примеру, автор плеера MQn в последних версиях компилирует в двух вариантах - с опциями SSE4 и AVX2 (исходники на GCC). Но декодеры не используются, поддерживается только WAV 16/44,1.
  23. Зависит от качества соответствующих входов на цап. На сундуке отписался владелец свежей ревизии Рокны, по его мнению хваленый штатный USB-вход уступает AES (источник Lynx Two).
  24. У Valkyrya карта Lynx AES 16 подключена через Adnaco с линейным БП.
  25. "Лекарство" от щелчков между треками - режим true gapless conversion в AuI ConverteR, вот только iso преобразуется в dsf. Преобразование форматов dsf/dff в tascam hi-res editor.
