Черная пятница 2026
Crosszone CZ-1 Headphones
Japanese manufacturer Crosszone has released a pair of headphones that it says do not have the ‘centre of the head’ soundfield of ordinary headphones.
‘Almost all recorded music has been recorded in such a way that it sounds natural only when played back through stereo speakers,’ said Boris Granovsky, of Absolute HiEnd, which distributes Crosszone headphones in Australia. ‘Unfortunately, when this music is played back using ordinary headphones, the result is a biphonic sound field that appears to listeners as though it’s coming from within the centre of their own head, an effect known as internal sound localisation, or ISL. Crosszone’s CZ-1 uses a special tridimensional array of drivers to produce a natural “spatial” sound that’s similar to that you’d hear from a pair of loudspeakers, by producing a sound field Crosszone calls external sound localisation, or ESL.’
Each earpiece in the CZ-1 is equipped with two drivers, one 40mm in diameter that acts as the ‘bass/midrange’ driver and one that’s 23mm in diameter that acts as the tweeter, both plated with beryllium, plus a third driver that delivers sound derived from the other channel via what Crosszone calls an ‘acoustic delay chamber.’ It’s the use of three drivers in each earpiece that gives the CZ-1 earpieces their distinctive triangular shape.
Each pair of CZ-1 headphones comes with one high-quality cable that uses oxygen free copper strands in a Litz configuration using eight cores of cable. The cable can be connected to either the left or the right earpiece. Two additional cables are supplied, one 1.5 metres in length for mobile use and one that’s 3.5m long for use in a listening room. ‘All Crosszone headphones are built by hand in made in Okaya City, Nagano Prefecture, in Japan, using parts that are sourced exclusively from Japanese manufacturers,’ Granovsky told Australian Hi-Fi Magazine, ‘so you can be certain that these headphones are truly ‘Made in Japan’ and that as a result, superior quality is assured.’
Manufacturer’s Specifications: Crosszone CZ-1 Headphones
Type: Circumaural
Frequency Range: 20Hz–40kHz
Efficiency: 97dBSPL/1mW
Impedance: 75Ω (nominal)
Weight: 485g
2 999,00 €
Надо брать.
Надо брать.
Да, давно их ждали!
Продаю (цена договорная)
Усилители для наушников:
Наушники:
и др. ))
ЦАПы:
Да вообще все распродам...
Борис плохого не посоветует.)))
Туфта, как мне кажется. Согласовать такую кучу разных динамиков, чтобы звучало качественно выглядит практически нереальным.
Так, поиграться...может послушать иногда необычное звучание. Но не за 3000 евро.
Вот согласен с Вами! За что мы ценим наушники? В том числе и за то, что весь диапазон частот озвучивается ОДНИМ динамиком, а значит фазочастотные искажения минимальны.
К слову, если мне память не изменяет, их разрабатывала инженерная группа из Technical Audio Devices Laboratories, Inc. (TADL). Что совсем не худший вариант...
Weight: 485g
2 999,00 €
За**али :ranting:
  • 10 months later...
Подниму тему постом с ссылками на обзоры и указанием реальной японской цены: $2265. Это именно те деньги, за которые Crosszone CZ-1 возможно взять с помощью почтового посредника.
Обзоры:
http://inearspace.co...cz-1-going-big/
http://hifiphilosoph...crosszone-cz-1/
http://www.avhub.com...s-review-477459
Изменено пользователем Гедонист
Weight: 485g
2 999,00 €
За**али :ranting:
А че париться гуано же будет аля файнал аудио))
ушки на макушке: 1. JH Angie CIEM + hybrid audio X3 mini, 2. Fostex T50 RP Super Snorry mod
плеерок на вечерок: 1. Hifiman hm-801 symmod + balanced card, 2. Ibasso dx100 USL mod, 3. MA9 Alex mod + balanced card Alex mod
Идеальные наушники. Думаю будут Ультрасонами в квадрате.
будет
Они давно вышли, иначе откуда взяться всем этим обзорам?
  • 11 months later...
1099$ на массдроп
Источник:
Esther M1 Vitality s/n 600, firmware v1.0.072 + Samsung 64GB PRO
Colorfly C200 s/n 0805P1, firmware v.C20016 + Sandisk Extreme 64GB
Усилитель:
RPA Refined Audio Power + потенциометр Vishay Sfernice
Обзор: http://forum.doctorh...als&article=361
Межблок:
8 проводников: Neotech UP-OCC Slilver 4х16x0.025мм/Neotech UP-OCC Cooper 4х16x0.025мм (плетение кабеля - объемное, плетение жил - плотный жгут)
Наушники:
Sennheiser HD 580 Старая версия начала 90-х с бумажным демпфированием. Кастомные амбушюры + кабель LitzCu XXX 4x175x0.04мм (плетение кабеля - жгут. плетение жил - жгут)
Sennheiser HD 25 II Старая версия https://www.innerfid...D251IIB2012.pdf. Сделан мод. Кабель LitzCu XXX 4x250x0.02мм (плетение кабеля - объемное, плетение жил - нет)
Grado RS325i Gold + G-pads
Hifiman RE-00 + Q-jay Tips
Акустикоимитаторы, судя по интервью с разработчиком
Источник:
Усилитель:
Межблок:
Наушники:
  • 2 months later...
  • 4 months later...
Три картинки CROSSZONE “CZ-10”
post-9264-0-95251400-1565330835_thumb.jpgpost-9264-0-48789300-1565330820_thumb.jpgpost-9264-0-42209000-1565330807_thumb.jpg
