Final Audio
Dr.Head Awards 2025
Pro-Ject ART
Dr.Head Awards 2025
KEF
Dr.Head Awards 2025
Premiera
Dr.Head Awards 2025
Noble Audio Artemis 2
Dr.Head Awards 2025
Austrian Audio
Dr.Head Awards 2025
Aurian
Dr.Head Awards 2025
Benchmark DAC2 HGC
post-7388-0-28672200-1391502205_thumb.jpgpost-7388-0-65085900-1391502210_thumb.jpgpost-7388-0-52552300-1391502216_thumb.jpgpost-7388-0-39003500-1391502220_thumb.jpg
Как пользователь и любитель DAC 1, не могу не создать ветку по случаю выхода нового Benchmark DAC2 HGC. Отправки начнутся 19 октября 2012 года, цена 1995$.
Внешне схожий с дак 1 имеет совершенно другую начинку,и несёт гораздо больший функционал.
"The Benchmark DAC2 HGC is a reference quality converter and functions as well as a preamplifier. It competes...and wins...against anything at any price, including the Light Harmonic $20K DAC (no kidding)."
- Mark Waldrep - aixrecords.com
Обзоры
http://www.audiostream.com/content/benchmark-media-systems-dac2-hgc-dac
http://www.stereophile.com/content/benchmark-dac2-hgc-da-processorheadphone-amplifier
http://www.hometheaterhifi.com/dacs/dacs-reviews/benchmark-dac2-hgc/page-5-conclusion.html
http://www.soundonsound.com/sos/oct13/articles/benchmark-dac2-hgc.htm#Top
http://www.newrecordday.com/2597-2/
http://www.whathifi.com/benchmark/dac2-hgc/review#XuhdfJOkhzJzHE35.99
http://benchmarkmedi...mp_created_link
http://www.benchmark...om/dac/dac2-hgc
Ключивые особенности
Benchmark introduces some exciting new technologies in the DAC2 HGC:
Hybrid Gain Control
High-Headroom DSP
UltraLock2™ Jitter Attenuation System
Quad 32-bit balanced D/A Conversion System
Multi-Mode Asynchronous USB Audio System
Distributed Power Regulation
DAC1 customers requested many new features which have been integrated into the new DAC2 HGC:
Sample Rate Display
Word Length Display
More Digital Inputs (5 total)
More Analog Inputs (2 total)
More Analog Outputs (3 total)
Digital Pass Through
Native DSD Conversion
Polarity Switch
Asynchronous USB 2.0 (24/192)
Driverless Asynchronous USB 1.1
Home Theater Bypass
Bi-Directional 12 Volt Trigger
Power Switch
Low Power Consumption
DAC2, оснащенный помимо традиционных цифровых входов асинхронным портом USB2.0, воспринимает музыкальные файлы высокого разрешения (до 24/192), а также DSD-поток. В режиме USB 1.0, не требующим установки дополнительных драйверов на компьютере, с которого производится воспроизведение музыкального материала, могут проигрываться фацлы до 24/96.
Мощный DSP-механизм интерполяции (рабочий формат 211 кГц / 32 бит), переводит входной цифровой поток в 32-битную форму и обеспечивает запас по уровню в +3,5 дБ. В исходном сигнале отсчеты, превышающие 0 дБ, исключены, однако, как показывает математический анализ преобразования PCM, возможно превышение на 3 дБ в промежуточных отсчетах, полученных путем интерполяции. В большинстве известных моделей ЦАП с DSP-интерполяцией сигнал на выходе при этом ограничивается, обогащаясь нелинейными искажениями. Компания BenchmarkMediaSystemsисключила подобную возможность.
В новой модели используется улучшенная технология полного подавления джиттера UltraClock 2™: отсчеты сигнала изначально записываются в буфер большой емкости, откуда затем извлекаются со сверхстабильной тактовой частотой для подачи на DSP. Суммарные искажения и шумы, вызванные искажениями преобразования и последствиями влияния джиттера, не превышают уровня -140 дБ.
Цифро-аналоговое преобразование производится с помощью четырех балансных преобразователей Sabreв формате 32 бит.
DSD-поток в формате DoP1.0 на входе опознается автоматически и полноценно преобразуется в аналоговый сигнал.
DAC 2 HGC имеет комплексную регулировку усиления и выходного уровня. На цифровом уровне громкость может регулироваться в 32-битных DSP. На выходе аналоговой части имеются пассивные аналоговые аттенюаторы, управляемые с пульта ДУ или лицевой панели. Их действие распространяется на любые сигналы, включая входные аналоговые с одного из двух аналоговых входов.
Все важные узлы схемы DAC 2 обеспечены локально расположенными индивидуальными стабилизаторами напряжения питания.
На лицевой панели DAC 2 имеются индикаторы формата входных цифровых сигналов, отражающие значения тактовой частоты и глубины разрешения.
Переключатель полярности выходного сигнала помогает восстановить изначальную полярность на иногда встречающихся инвертированных записях.
С целью легкой интеграции DAC 2HGC в систему домашнего кинотеатра предусмотрен программируемый сквозной режим для аналоговых входов, а также индикатор данного режима на лицевой панели.
Второй коаксиальный цифровой вход может перепрограммироваться в цифровой выход, на который выводятся любые входные цифровые сигналы, в т.ч. с порта USB и с поддержкой DSD (DoP1.0). Потоки Dolby Digital и DTS также могут пропускаться через данный сквозной цифровой канал.
На лицевой панели имеется два выхода на головные телефоны.
Двунаправленный триггерный порт (12 В) совместим с любыми входами и выходами триггерного управления других устройств.
DAC2 по окончанию работы может переводиться в режим Standbyлибо выключаться полностью, при этом он продолжает реагировать на сигналы управления с пульта ДУ и триггерного порта.
Изменено пользователем kachinskii
  • Ответов 232
  • Просмотры 50,2k
  • что за шиза по поводу апсемплинга? примитивные словесные ассоциации типа "апсемплинг - обработка - накрррутить басков и верхов - сверкающий музцентр о 25 дсп презетах"? Почитайте что ли об архитектуре
  • @xtraktz, сравнивать нужно не по ценам, не по возможности отключения апсемплинга, а по факту, сталкивая устройства лоб в лоб, тогда все вопросы отпадут. Первый бенч, на мой взгляд, весьма посредственн
  • DAC2, оснащенный помимо традиционных цифровых входов асинхронным портом USB2.0, воспринимает музыкальные файлы высокого разрешения (до 24/192), а также DSD-поток. В режиме USB 1.0, не требующим устано
При таком-то ценнике, кроме поддержки DSD ничего интересного нет, ИМХО :notknow: Mytek 192 ver 2.0
интересно, как он против Weiss DAC2 :think:
portable: jaybird x2, x3
Ну ДА, он не ламповый, не деревянный, не весит 10кг и не покрыт золотом!за что ж тут платить=) просто дак!.....Ведь за эти деньги можно просто обвешаться Шитом балансным)
Для меня интересно уже то что это бенчмарк, второе - четрые цапа (если я правильно понимаю), по юсб 24/192 фигачит, DSD читает, и его теперь можно выключить! Дальше будет интересней
Ну это прямой конкурент Майтеку, вот с ним и сравнивать нужно. Словосочетание "асинхронный USB" ни о чем не говорит - надо на реализацию смотреть.
Тракт: Lynx Hilo USB => Fostex TH900
Портатив: XDuoo X10AE => Noble Kaiser 10C
Было:
Транспорты:
Berkeley Alpha USB
Lynx AES16
ЦАП:
Berkeley Audio Design DAC Series 2
North Star Design DAC Extremo
Meier Audio Corda StageDAC
Creative X-fi Elite Pro
Усилители:
Mjolnir Audio KGSSHV (450V, Sanyo parts)
Headamp GS-X MKII
Audio-Technica AT-HA5000
MS Audio Laboratory FHA 1.3
MS Audio Laboratory FHA 1.2
Наушники:
ATH-W2002 #0836
ATH-W2002 #0389
ATH-W3000ANV #1120
Audio-Technica ATH-W5000 (три пары)
Audio-Technica ATH-ESW10JPN
AKG Q701
Beyerdynamic T1
HiFiMan HE-6
Sennheiser HD580
Портатив:
AleXmod #2
Sony Discman D-311
Cayin i5
Sennheiser IE4
Sleek Audio SA6
Westone W20
Westone 3
TDK BA-200
Вам schiit уже везде мерещиться в моих постах :stopit: За 2000$ реально много чего можно собрать, даже в конфигурации ЦАП+усилитель :notknow:
Послушал Асгард на тупых Денонах и все, фирма лишилась респекта. А на других усилителях за ту же цену ты их слушал?
И что можно хотеть услышать от Денонов D2000/5000? :)
Временно danik97
Честно - я не знаю таких таких конфигураций. Скорее всего он только лишь как ДАК сможет тягаться с отдельными даками от 2000$ - так было с оригинальным даком в СВОЁ время. А теперь прибавьте хотя бы баксов 500 на усил, не считаю межблочники. И посчитайте.
Ну и вообще я тяготею к таким решениям, комбайном (майтекам лаври), и всегда их предпочту.
Деноны 7000. Дальше не хочу обсуждать тут шит. Крутая фирма.
Ну да, не будем обсуждать. Название не понравилось. :)
Временно danik97
а что там за микруха внутри, кто знает?
Demm
Только сегодня анонсировали и такой инфы нет ,на сайте его даже в продуктах нет и предзаказ не сделать
А будут ли шитовские усилки лучше встроенного в этот цап? Просто цап шит оказался дерьмовеньким, как бы каламбурно не звучало, ощутимо хуже того же бенчмарка.
Solitudo, так ЦАП еще не вышел, откуда же кто знает будут они лучше или хуже? :notknow:
Но я бы поостерегся усилители ихние покупать, как бы опять "каламбур" не получился. :stopit:
Было:
Транспорты:
Berkeley Alpha USB
Lynx AES16
ЦАП:
Усилители:
Headamp GS-X MKII
Наушники:
ATH-W2002 #0836
ATH-W2002 #0389
ATH-W3000ANV #1120
AKG Q701
Beyerdynamic T1
HiFiMan HE-6
Sennheiser HD580
Портатив:
AleXmod #2
Sony Discman D-311
Cayin i5
Sennheiser IE4
Sleek Audio SA6
Westone W20
Westone 3
TDK BA-200
Я про бифрост, он мне показался чуть лучше(а может даже наравне) essence.
Просто были у людей восторги насчет него, а оказалось...Поэтому сложилось впечатление о фирме, как о продавцах "разрывателей всего и вся", на дело рассчитанных на лохов. В связи с этим не жду чудес от их новых изделий.
Наверняка можно сказать лишь дешёвых шитах (они похуже будут), а вот их балансный вроде неплох (700$). И могу сказать ещё вот что, у меня был усилитель Violectric v100 (500евро), покупал специально для НЕ-4, при смене цапа на бенчмарк дак 1, я отказался от этого внешнего усилка в пользу встроенного в бенч и потерял лишь немного в громкости. ..........хотел брать V200, пока забил на это)
Чего то валом сейчас распродают V200 их владельцы и уходят на новый Шит. Лохи. Все.
Временно danik97
Цена нового бифроста почти в 3 раза меньше цены бенча на старте продаж - чего Вы хотели-то?
Я не могу сказать 100%, какой усь будет лучше, потому что у меня его нет :notknow: , но я общался с человеком, владеющим eximus и балансной связкой schiit - он считает, что как ЦАП eximus прилично лучше, а встроенный усь гораздо хуже, чем шитовский (наушники - LCD-3)
Грубо.....но вполне возможно что да, лохи, это ж американцы по большой части=) ШУЧУ)........ Сейчас например все покупают кастомные мониторы, потом все бегут покупать новый плеер, или другую новинку, расхватывают как пирожки, а потом... начинается
с V200 было так же :D)
Временно danik97
Просто есть категория людей, которые хотят верить в чудеса, например, в то, что кастомы будут на уровне одиссеев :D
Такими моментами нужно уметь воспользоваться) и купить то что хотелось в полтора раза дешевле.
Иметь бы возможность все переслушать заранее ;) чтобы потом не скакать от одного к другому. и главное! не брать не приятное уху название.
Временно danik97
А на наушниках полегче усилитель наушников в Exiumus на 99% не отличим от ZDSE — последний отзыв head-fi
«powering my AD2000 from either the ZDSE or DP1 sounds 99% identical to my ears. So much so that I simply could not justify keeping the ZDSE if these were my only headphones (they're not).I know that the AD2K is very easy to drive, but it also has been known to be a VERY synergistic pairing with the Zana over the years. So as far as low impedance, high sensitivity cans go-the DP1 has proven a stunning pairing. I will post my findings with the HD 800s (STUNNING w/ the Zana) and DP1 if they ever show up from customs.»
На хед-фай отзывов много, разных :stopit: надо брать процентами соотношений!
Временно danik97
