Весь контент qsk
- CHORD MOJO
FiiO
ну они и не топ, но для портатива из полноразмерных по сути безальтернативные для динамичных жанров.
FiiO
Ну если сигничи по вашему мнению не раскрывают потенциал Х7...
FiiO
@Ганс, а что Fiio X7 в топы записали?
- Тяжелая металлическая и неметаллическая музыка.Обмен опытом и мнениями.
Fostex TH-X00 - пушка от Massdrop
Ну вот более или менее вменяемые вещи стали рассказывать http://www.head-fi.o...s#post_12141866 The New TH-XOO: Andrew, @Soundsgoodtome stepped up and got a demo X00 in time for the meet so we can all see what we are waiting for in the mail. And I have to say that it impresses. I was worried at first having heard the Dennon D5000 which is supposed to be a comparable and it was sounding somewhat pedestrian to me. However, when I finally got to hear the XOO on Andrew's setup, all worries were gone. It has a nice flat response with glorious mids and welcome bass response - even driven by my AK100ii DAP directly. I put on my basshead song with the AK and was rewarded with ungodly bass quantity, and good quality too. This will be a fun headphone to say the least, and it is different enough from my LCD to make it a fun addition. I didn't get a chance to see how it scales on other gear, but was happy on both my AK and Andrew's setup. Now, I should say that Andrew's setup is always spectacular with an ease of power and SQ with full sized sound stage. While the setups are always different, they are always good. I enlisted Andrew to help me with mine. у чувака был сетап Foobar on laptop > Gustard U12 > Schiit Bifrost Multibit > Schiit Sys preamp > Project Horizon 3 with Russian Gold Grid tube > A) THX00 or Denon D5000
ааа чума просто!!!! СИЛИЩЕ! блэко-дум БАТЮШКА! Чуваки явно вдохновлялись и Во Скорбях тоже, видимо Восемь молитвенных прошений (ектений) - восемь мощных и мелодичных композиций с наличием низкого/глубокого мужского вокала. Имена музыкантов пока неизвестны, а в графе "страна" на сайте лейбла указано, что проект международный. Батюшка - Литургия, 2015 http://youtu.be/PUhBykAA0D8 Такой подарок под новый год!!!!
Что купить первым NW-ZX2 или NW-ZX100 или PSM11 ANGIE
Отличные однодрайверы с широкой сценой, немного ярчат, могут фонить и капризничать на разных источниках (6 Ом), ну и арматурный бас (хотя, у них и siren armature) если не смущает, то вполне себе хороший вариант.
Sony NWZ-ZX2 high-res Walkman
@Hibeat, можно купить плеер айбассо DX90, например, с ним идет специальный прогревочный кабель - с одной стороны джек, с другой нагрузка. Кабель оставляете, а плеер выкидываете/дарите/ продаете Шучу! Погоняйте по нагрузкой (наушники) часиков 100. P.S. Кстати ,что мешает просто слушать плеер и осуществлять естественный прогрев? Или не устраивает звук из коробки? Не факт тогда, что будет устраивать после прогрева.
Да нет пока там вменяемых и адекватных отзывов, а есть типа - they kick ass или not my sound signature. Напокупали их все кому не лень...
ULTRASONE SIGNATURE DJ
поздравляю, да 7100 столько же фактически. Главное что человеку нравиться. правда , это pro были, не dj
усилитель для Philips Fidelio X1
Кажется, они писали в блоге своем, что отказались от ES9023, и теперь там PCM5102A. Вы путаете с похожей моделью от Mayflower Electronics ODAC (revB) + Objective2 , там стоит PCM5102A Я попутал с ODAC, там теперь PCM5102A, тогда по идее в комбинации с О2 тоже, собственно ниже лог. http://blog.jdslabs.com/?p=1003 Change Log ODAC RevB resolves all reliability inadequacies of the original ODAC, while meeting or exceeding original transparency requirements. ODAC RevB utilizes the same PCB footprint and is a physical drop-in replacement to all existing ODAC and O2+ODAC assemblies. Revision B’s stronger output voltage of 2.10VRMS must also be accompanied by a slight DAC volume or gain adjustment when used in O2+ODAC; optimal gain is now 1.0/3.33x. Analog filters and power supply passive components remain identical to the original board. The new chipset consists of an SA9023+PCM5102A, and the LDO has been updated to a ceramic stable Analog Devices ADP151 equivalent part
К слову, продал свои сигничи человеку, у которого деноны 7100. Через пару дней он мне написал о том, что деноны идут на продажу, не выдержав конкуренции с сигничами, которые на голову их выше во всем...а сколько сейчас 7100 стоят?
Заказавшие так их ждут, как будто это единственные наушники на свете... Ну, или Орфеи, которые удалось купить за 400 долл... Скорее всего - это просто очередные 400-долларовые Фостексы... Хотя, я искренне рад за тех, кто их купил. в крайнем случае кино в них смотреть буду ))
- Fostex TH-X00 - пушка от Massdrop
И снова наушники для fiio x5
Этих ушей не слышал. А с Н3 было именно так , как описал выше. Странно, у меня только положительные эмоции оставил этот усилок. И далее второй владелец после меня так же был доволен. С линейного выхода сигнал снимаете? Возможно, с этими ушами он себя ведет нехорошо.
@campdee, на каких наушниках слушали? Он для IEM
Ну вот и начались первые отгрузки http://www.head-fi.org/t/788776/fostex-x-massdrop-th-x00-review/1260#post_12133088
не дразните...а то придется посредника просить EMS отправить, как приедут к нему, а это существенно дороже из штатов )))
Ну, самые ровные, если можно так сказать, по указанным параметрам из всех, 8-9 практически по всем лучам из 10. Без каких-либо перекосов куда-либо.
Questyle QP1R отзывы
на другой форум сходите, профильный по портативу.
Пока на собственном опыте не поймете ,что именно Вам нужно, никакие рекомендации и советы не помогут найти "свой" звук.
