Черная пятница 2026
fiio x1
ага заказывайте, деньги за рекламу только не забудьте занести.
Продаю всё из подписи.
Home:PC(USB3.0)->QED Performance USB Graphite->(DAC/Amp:Audinst HUD-MX2)->~remote access~->
Notebook:Asus S200E(USB3.0)+(foobar2000 by Audiophile)->USB ADL by Furutech Formula 2->DAC:Yulong D200->Rainbow Air(neotech copper)->Amp:Violectric HPA V200
Phones:Audeze LCD-2 rev.2(Evo Insane CL)+Fostex TH-600
Portable:Player:FiiO X5III->Phones:Ortofon e-Q8+DUNU DN-2000J+DUNU Titan1+Philips Fidelio X2(Silver plated cable) Sport:Player:Sony Walkman NWZ-W273
Before: Sennheiser CX 300-II/AKG K712 PRO/Philips Fidelio X1/Vsonic Gr07 Classic/FiiO X5/Vsonic Gr01/QLS QA360
Нужно отстать от дурного вкуса – желать единомыслия со многими (с)
..не суетитесь из-за "пары копеек", а если вы россиянин, то вообще выкиньте эту затею из головы..
  • 2 weeks later...
http://www.headfonia.com/fiio-x1-99-dap/2/ ipod classic дешевле и лучше
Конкретный закос под ipod (форм-фактор, безконденсаторный выход и т.д.)
1, Target M.S.R.P US$100 in U.S. the retail price in other countries will depended on our distributor and different VAT...
2, Playback supported: almost same as X3/X5, but it can't support DSD playback and work as USB DAC like X3/X5.
3, Size: 96.5 X 57 X 13.5 mm, Weight : 108g;
4, Build in Memory : None
5, Extend Memory : Micro SD card slot x1, supports up to 128g.
6, Audio out : LO and PO, no Coaxial out. The LO/PO will use the same 3.5mm headphone jack but switched by menu.
7, Micro USB socket.
8, output power: 70@32ohms and 120mW@16ohms
9, Screen: 2.0'' 320*240 TFT
10, DAC : PCM5142 from TI, OP: OPA2322, BUF: ISL28291
11, Power supply for amp section : +/- 3.3V not output capacitor.
12, Battery: 1700mAh.
13, Play time: > 12 hours.
14, The other features is similar with X5, includes gapless playback , cover display, playlist, EQ.
Источник:
Esther M1 Vitality s/n 600, firmware v1.0.072 + Samsung 64GB PRO
Colorfly C200 s/n 0805P1, firmware v.C20016 + Sandisk Extreme 64GB
Усилитель:
RPA Refined Audio Power + потенциометр Vishay Sfernice
Обзор: http://forum.doctorh...als&article=361
Межблок:
8 проводников: Neotech UP-OCC Slilver 4х16x0.025мм/Neotech UP-OCC Cooper 4х16x0.025мм (плетение кабеля - объемное, плетение жил - плотный жгут)
Наушники:
Sennheiser HD 580 Старая версия начала 90-х с бумажным демпфированием. Кастомные амбушюры + кабель LitzCu XXX 4x175x0.04мм (плетение кабеля - жгут. плетение жил - жгут)
Sennheiser HD 25 II Старая версия https://www.innerfid...D251IIB2012.pdf. Сделан мод. Кабель LitzCu XXX 4x250x0.02мм (плетение кабеля - объемное, плетение жил - нет)
Grado RS325i Gold + G-pads
Hifiman RE-00 + Q-jay Tips
