Records
Продвинутые
  • Зарегистрирован
  • Посещение
Весь контент Records
  1. Берите Х1 2-го поколения и не парьтесь
  2. Да ваще ничего не надо, если устраивает то, что есть. Если вас что-то не устраивает, то покупайте, слушайте, сравнивайте.
  3. Ради IPS дисплея у хуелиня стоит менять!
  4. How to use the X3II, X5II, X5 or X3 as a USB DAC on a Windows computer (or all 4 at the same time)? 1. Download the latest USB DAC driver(v 3.34.0) for all X players for windows: The DAC driver for the X5II/X3II/X5/X3 Note: this new DAC driver will not compatible with the X3II which is running FW1.4 or previous version firmware. That is to say, it is suggested to update the X3II to the latest firmware FW2.0(click here) firstly. 2. Update Windows 7 for accepting SHA256 certificates Our driver package is signed with a SHA256 certificate. Windows 8 and 10 accept this SHA256 certificate by default. On Windows 7 Microsoft has released a patch to also accept SHA256 certificates. You will get it through Windows update or you can be downloaded here: https://www.microsoft.com/en-us/download/details.aspx?id=46148 The description from Microsoft can be found here: https://support.microsoft.com/en-us/kb/3033929 Windows 7 only accepts SHA1 certificates by default. But SHA1 certificates are deprecated and shouldn't be used anymore. You also don't get new SHA1 certificates from the certificate providers. Please update your Windows 7 systems and try again installing the driver. 3. On your X player, go to System Settings->USB mode and change the mode to DAC. Then connect it with a USB port on the computer using our provided USB cable (for desktop computers, it is recommended to connect to a port on the back of the computer directly connected to the motherboard. The X player is compatible with both USB 2 and USB 3 ports.) 4. After unzipping the drivers downloaded in step 1, install the drivers following the steps shown here: The user guide for installing the USB DAC driver (note: you would need to uninstall any previous versions of drivers first.) 5. How to use more than one X player as DAC with the same computer? After running the driver installation for the first time, the computer will support using whichever X player was connected during installation as DAC. To support other X players you may own for use as DAC at the same time, simply connect the other player(s) to the computer by the micro USB cable, then it will automatically complete the installation. You can go access to "Hareware and sound" -> "Sound" on the Control Panel, and check whehter the X players is recognized by the computer successfully. (The first person to post a picture of the X3 1st gen, 2nd gen and the X5 all connected to the same computer and running as DAC may win a prize?? ) Как использовать X3II, X5II, X5 или X3 в качестве USB - ЦАП на компьютере Windows (или все 4 одновременно)? 1. Загрузите последнюю версию драйвера USB DAC (v 3.34.0) для всех X игроков для окон: Драйвер ЦАП для X5II / X3II / X5 / X3 https://www.dropbox.com/s/qqz14rnt6at8q1o/FiiO%20USB%20DAC%20Driver%20v3.34.0.zip Примечание: этот новый драйвер ЦАП не будет совместим с X3II который работает под управлением FW1.4 или предыдущей версии встроенного программного обеспечения. То есть, предполагается обновить X3II до последней версии FW2.0 ( нажмите здесь ) , во - первых. 2. Обновление Windows 7 для приема SHA256 сертификата с Наш пакет драйвера подписан с сертификатом SHA256. Windows 8 и 10 принимают этот сертификат SHA256 по умолчанию. В Windows 7 Microsoft выпустила патч , чтобы также принимать сертификаты SHA256. Вы получите его через Центр обновления Windows или вы можете скачать здесь: https://www.microsoft.com/en-us/download/details.aspx?id=46148 Описание от Microsoft можно найти здесь: https://support.microsoft.com/en-us/kb/3033929 Windows 7 принимает только сертификаты SHA1 по умолчанию. Но сертификаты SHA1 устарели и не должны больше использоваться. Вы также не получите новые SHA1 сертификаты от поставщиков сертификатов. Пожалуйста, обновите ваши системы Windows 7 и повторите попытку установки драйвера. 3. На X-плеер, перейдите к System Settings-> Режим USB и измените режим на ЦАП. После этого соедините его с USB-портом компьютера с помощью нашего условии USB кабель (для настольных компьютеров, рекомендуется подключить к порту на задней панели компьютера, подключенного напрямую к материнской плате. Х-плеер совместим с USB 2 и USB 3 порта.) 4. После распаковки драйверов, загруженных на шаге 1, установите драйверы следующие этапы, показанные здесь: Руководство пользователя для установки драйвера USB DAC (Примечание: вам нужно будет удалить все предыдущие версии драйверов в первую очередь.) 5. Как использовать более одного X плеера в качестве ЦАП с одного компьютера? После запуска установки драйвера в первый раз, то компьютер будет поддерживать с помощью какой бы X игрок был подключен во время установки в качестве ЦАП. Для поддержки других игроков X вы можете самостоятельно для использования в качестве ЦАП в то же время, достаточно просто подключить другого игрока (ов) к компьютеру с помощью кабеля микро-USB, то он будет автоматически завершит установку. Вы можете пойти доступ к "Hareware и звук" -> "Звук" на панели управления, и проверьте whehter Х игроков распознается компьютером успешно. (Первый человек , чтобы получить возможность отправлять картину X3 1 - го поколения, 2 - го поколения и X5 все подключены к одному компьютеру и работает как ЦАП может выиграть приз ?? )
  5. Если эргономика важна, то лучше Fiio купить. А так да, АП100 на барахолке за ~8500р - отличный выбор.
  6. А поменяв уши на Beyerdynamic DT 770 PRO на выходе будет ли слышна разница?? Безусловно. Правда баеры бывают разные по сопротивлению и по звуку. Но одни из лучших - это 990-е винтажные 600 ом.
  7. Audiotechnica A2000x - это ещё жёстче, чем градо!
  8. Вау после М40 за не дорого могут дать баеры. Драйв есть, мясо есть, короче ухи огонь. 990 и 770 баеры, если чё.
  9. Странное дело. Комп перезагружали? Может прошивку надо на плеере обновить?
  10. На рабочем столе справа снизу есть значок динамика, где громкость регулируете. Кликаете по этому значку правой кнопкой мыши, далее "устройства воспроизведения". Там должны быть встройка realtek и USB DAC Fiio. Нужно кликнуть правой кнопкой мыши на фиио и выбрать его, как устройство вывода звука по умолчанию. Вроде так. Компа под руками нет, точнее сказать не могу. Когда подключаете фиио, как цап по идее виндовс сам должен поставить драйвера и распознать плеер, как USB dac.
  11. На компутере нужно выбрать фио, как основное устройство воспроизведения. Он вообще на компе как-то отображается?
  12. У Х1-2 мощность на наушники крайне мала. В разы меньше, чем у Х3-2. Если вы юзаете низкоомные затычки, которые не сильно требовательны к мощам, то Х1-2 отличный вариант. А Х3-2 более универсальный, т.к. нормально работает и с 600 омными динамами, и с 50 омными изодинамическими ушами.
  13. @Pipka, докупите Objective 2 и будет вам счастье. Ну или комбо ODAC + Objective 2. На что-то более дорогое можете не заморачиваться.
  14. Machine Gun Kelly - Sail
  15. АТН М50 в топ дешманских ушей для электроники!!!! Одного плюсика им маловато
  16. А почему нет? Или вы думаете, что для раскачки 600 ом нужна здоровенная коробка на пол стола размером?
  17. @АНАТОЛИЙ83, теоретически мощности должно хватить, но я предпочитаю с запасом брать. Сам подключил к самопальному БП на LM317, полёт нормальный. Греться будет в любом случае, если использовать 12 вольт.
  18. Главное достоинство иксдуо - это два слота под карты памяти. Если это важно, можно и его взять
  19. Давно пора!
  20. @syncmaster, ВЧ неяркие, песка нет, сибилянтов нет, говорю, как большой ненавистник ярко выраженных сибилянтов. Середина на месте, никуды она не провалена. И классику хорошо играют. С АП100 ваще супер. Короче товарищ Comrade очень странный тип. Какие-то сказки рассказывает.
  21. Zero audio carbo tеnore относительно неплохи на металле.
  22. Ну по звучанию да, хорош. Но эргономика AP100 после FiiO адски убогая. Один из самых крутых вариантов - это Х1-II. Главный минус нового fiio - это цена, ибо доплатив 1500р можно взять на барахолке АП100. Брать старую версию Х1 смысла нет, когда есть более совершенный Х1 2-й ревизии.
