Final Audio
Dr.Head Awards 2025
Noble Audio Artemis 2
Dr.Head Awards 2025
Noble Audio Iris Blue
Dr.Head Awards 2025
Austrian Audio
Dr.Head Awards 2025
Aurian
Dr.Head Awards 2025
YULONG Crystal DA DAC AMP - ЛУЧШИЙ КОМБАЙН <150$ ?
www.audiophilechina.com/cp-show.asp?C_i ... 2=57&s_id=
Price: $ 149    ?
Shipping Price: $ 40
DETAIL :
Crystal DA is a small integrated personal audio system with an USB input, a S/PDIF input, an Optic Fiber input, an independent DA conversion, a Line output and a headphone power amplify output. Crystal DA has a small size,only 160*110*45mm.It uses the refined aluminum shell and it is exquisite in styling.To your surprised, it weighs only 0.68Kg.It is inconvenient for you to use a large desktop audio device to enjoy the music in some places such as offices, dormitories,etc.It is also inconvenient for you when you are away on business.Crytal DA can help you to play music,and it will become your best partner! Crystal DA uses the CS4398 to complete the DA conversion.The CS4398 with little distortion is produced by the Cirrus Logic Inc. The gain and noise figure of the CS4398 are about 120dB and -107 dB respectively. The Digital Input uses the CS8416 of Cirrus Logic which can recognize and sorpport the frequency from 32KHz to 192KHz automaticly. The USB uses PCM2704 of BB.The PCM2704 can convert the USB to the SPDIF as the input of the CS8416. The part of analog circuits uses a dedicated audio OPAMP OPA2134 of BB, 5% high-precision SMD capacitor and 0.5% SMD resistor. The part of headphone amplifier uses the OPA2134 to drive the A-type buffer current output stage with the constant current source, and uses the low power tube whose output current can achieve 800MA.This will not only ensure enough drive capability but also get the fine voice. Crystal DA uses the universal high-quality external power supply which is AC 90V-270V, 50/60HZ.In the Crytal DA,high frequency switching power supply with high performance and without noise, which is developed by YuLong Audio,is transformed to multi-channel voltage-stabilized source to supply the DAC and the part of the headphone amplifier independently. The whole circuit uses the high-precision components with famous brands,QC is necessary before production,each of the components must be tested to achieve high performance index and adjusted by YuLong senior audio engineers before use. All the machines must be passed through the 24-hour reinforcing experiment and examined by the dScope Series III digital audio analyzer critically.From production to voice adjusting to technical indicators and the stability of the machine,these procedures can guarantee the consistency of high quality.
дома = hifiman hm-602(16Gb+SD128Gb) => A-Th AD700 vs FA-003 махагони+литцрекабелинг(огромная благодарность Диме Губченко - Demograf)+neutrik) vs Sony MA-900
на улице = Samsung Wave S8500 => hifiman re-0 rev.№4+кабель nobody+neutrik
Было:
AKG K550
Audio-Technica SJ3
Pioneer SE A-1000
Sennheiser HD595
AKG K-701
Brainwavz M3
Creative X-Fi HD USB
Cowon iaudio7
Dr.Dac2
Musiland 02US
Alt Audio Element №1
Судя по всему девайс только появился и нормального обзора не найти. Я не разбираюсь в элементной базе и особенностях цапостроя, но на мой нубский взгляд всё выглядит очень неплохо.
Очень импонирует неплохая репутация производителя.
Внешний вид- строгий, скромный, универсальный.
Из конкурентов вспоминается только Zero Dac, который сейчас стоит 130-140$, новая версия с usb & opa627
Я уже собрался покупать небольшой, лёкгий(походный) комбик, ориентируясь на отзывы бывалых уже присмотрел nu force udac-2, который намного меньше в размерах и построен на цапе sabre ess 9012, стоит на спам ~130$
Теперь засомневался :think:
Было:
AKG K550
Audio-Technica SJ3
Pioneer SE A-1000
Sennheiser HD595
AKG K-701
Brainwavz M3
Cowon iaudio7
Dr.Dac2
Musiland 02US
Дизайн классный (оушки видимо сменные-гуд).
Ждемс знатаков
Ждемс знатаков
Оперов сменных я не увидел, усилитель для наушников на транзисторах, наверное и к лучшему. Емкости на вид качественные, хотя кто китайцев раберет, у них подделки есть под все на свете. CS4398 это гуд :) Вот только еще бы фото блока питания глянуть, но то что можно увидеть на 150$ однозначно тянет)
Shadow39
А что Вы можете сказать о возможностях usb-приёмника pcm2704?
Было:
AKG K550
Audio-Technica SJ3
Pioneer SE A-1000
Sennheiser HD595
AKG K-701
Brainwavz M3
Cowon iaudio7
Dr.Dac2
Musiland 02US
Shadow39
Стандартная бюджетная реализация. Вас возможно звук устроит. Но по s/pdif наверняка будет лучше.
А я себе вот такой девайс вчера на ебэе прикупил http://ebaytoday.ru/catalog/120781074153-item.html что скажите? Теперь подбираю ушки что-то из Beyerdynamic,не знаю на каких остановиться? :think:
Shadow39
На этом сайте есть недорогой usb-coax конвертер, стоит 30$. Будет ли его покупка к этому комбику оправданной?
Было:
AKG K550
Audio-Technica SJ3
Pioneer SE A-1000
Sennheiser HD595
AKG K-701
Brainwavz M3
Cowon iaudio7
Dr.Dac2
Musiland 02US
Вот киты их нашлёпали! Один лучше другого!
urbano
Нет, скорее всего разницы не будет совсем. Я считаю что единственно возможная нормальная реализация usb это асинхронный usb - s/pdif(toslink) конвертер с качественным генератором. Самый минимум - M2TECH Hiface, но даже он стоит дороже девайса для которого он будет предназначен ;)
Shadow39
В принципе это и ожидал услышать.
Будем ждать буржуйских обзоров и мнений, хотя уже понятно, что будует море ласковых и нежных слов. Редко они ругают почему-то :notknow:
Было:
AKG K550
Audio-Technica SJ3
Pioneer SE A-1000
Sennheiser HD595
AKG K-701
Brainwavz M3
Cowon iaudio7
Dr.Dac2
Musiland 02US
urbano
Думаешь себе такой преобрести или советовать будешь новичкам?
  • 2 weeks later...
urbano
Он выглядит неплохим решением в этом ценовом. Если бы послушать ещё ;)
Но советовать можно только для тех, кто может рискнуть. Хотя я уверен, что с аналогичными китайцами в этом ценовом он как минимум будет на одном уровне :think:
Было:
AKG K550
Audio-Technica SJ3
Pioneer SE A-1000
Sennheiser HD595
AKG K-701
Brainwavz M3
Cowon iaudio7
Dr.Dac2
Musiland 02US
а аудио-гд это тоже "аналогичный китаец"?
На этом форуме любят советовать продукцию аудио-жидов, и действительно 3-4 года назад у них не было конкурентов цена/качество(может нет и сейчас). Например я очень бы хотел купить audio-gd compass, который стоил 2-3 года назад около 300$ и был на микросхеме цапа AD, но увы уже не выпускают.
Когда а-гд перешли на микросхемы цапов wolfson, к ним интерес поубавился.
А nfb-12 не очень хвалят на head-fi, хотя возможно он и не плох, я его не слушал.
Но уж точно какой-то "БОМБЫ" по-звуку в ценовом до 300$ у них сейчас нет, если бы был, то я бы давно купил.
У цапов а-гд(в принципе как и у многих других без асинхронного юсб) хреново реализован вход юсб, по-этому владельцам ноутбуков остаётся либо мириться с тем, что цап/комбик может играть лучше, либо покупать usb/spdif конвертер.
Было:
AKG K550
Audio-Technica SJ3
Pioneer SE A-1000
Sennheiser HD595
AKG K-701
Brainwavz M3
Cowon iaudio7
Dr.Dac2
Musiland 02US
а с чего (какие модели, какие цены) начинается стОящий асинхронный USB?
насколько велика разница на наушниках класса: AT ATH-A900, Denon D2000 моделей с асинхронным USB?
или для них как раз и достаточно лучшего в бюджете до 150?
denny77
По божеским ценам в РФ можно купить(и самое главное послушать) Asus Essense One, у нас она стоит столько же сколько и на спам. Сам очень хочу её послушать в ДХ.
Цены в РФ от 15000. usb- асинхронный, курите профильную ветку.
Было:
AKG K550
Audio-Technica SJ3
Pioneer SE A-1000
Sennheiser HD595
AKG K-701
Brainwavz M3
Cowon iaudio7
Dr.Dac2
Musiland 02US
ЕМНИП c Schiit Bifrost
  • 2 years later...
Уважаемые, 2 дня назад пришли ко мне ушки Denon AH-D600, задумался о приобретении к ним комбайна, сейчас в связи с привлекательностью по цене присматриваюсь к
NEW Yulong U100 DAC & USB DAC & Head AMP & sound card или Audinst HUD-mx1 Hi-Fi USB Audio DAC,
При практически одинаковой цене около 160 долл США с доставкой, последний на 10 долл. США дороже, что не принципиально.
Посоветуйте пожалуйста что лучше в подобном ценовом диапазоне для Denon AH-D600.
Сейчас слушаю разную музыку сборники попсы, немного классику, джаз и планирую пробовать другие направления,
очень буду признателен за подробные с комментариями советы.
  • 3 weeks later...
Наушники более высокого класса чем комбайны за 500$ Имейте ввиду.
Спасибо, понял что Denon AH-D600 хорошие наушники (при том что обошлись мне в 250 долл. США),
и сейчас я не готов тратить 500 долл. на комбайн, мой бюджет на это дело тоже порядка 250 долл. США.
сейчас присматриваюсь к Audinst HUD-mx2, он с доставкой обойдется в 230 долл. США.
Прошу Вашего мнения по поводу Audinst HUD-mx2, или что бы Вы посоветовали в моем бюджете по ценам спам.
Слушаю понемногу поп, классику, джаз.
Не слушаю рок и метал.
Спасибо.
