Публикаций
1 250 -
Баллов
327 -
Зарегистрирован
Посещение
Победитель дней
Тип контента
Профили
Форумы
Пользовательские тракты
Галерея
Колекции
Блоги
Объявления
Магазин
Articles
Весь контент deeone
Никто не слушал? Я так понял они есть в магазине.
SimAudio MOON 380D 32 bit Digital-to-Analog Converter Significant Design Features: True 32-bit Digital-to-Analog converter using ESS Technology SABRE32 Ultra DAC / Digital Filter (ES9016) working in 32-bit Hyperstream™ to achieve unprecedented jitter immunity and low-level linearity via a patented Time Domain Jitter Eliminator Digital Audio Signal Processing using M-AJiC32 (MOON Asynchronous Jitter Control in 32-bit mode) A virtually jitter-free “1 picosecond” digital clocking system Optional MiND (MOON intelligent Network Device) module (9th input) via WiFi or Ethernet input for multi-room streaming Optional variable analog outputs (balanced & single-ended) using M-eVOL volume circuit which was originally developed for the MOON Evolution series. Accessible using the remote control, this volume operates in 0.5dB increments. M-eVOL is based on a resistive array configuration with no sonic degradation of the audio signal regardless of the chosen volume setting The entire analog stage is a fully balanced differential circuit for increased dynamic range and headroom, higher resolution, as well as improved signal-to-noise ratio. A very short signal path using a DC servo circuit and proprietary 12dB/octave analog filter Separate digital & analog power supplies using 2 independant toroidal transformers with 11 stages of voltage regulation Four-layer PCB tracings for a dramatically improved signal-to-noise ratio RS-232 port for (i) full unsolicited bidirectional feedback and (ii) firmware updates 12 Volt trigger outputs for remote operation and IR input for external control SimLink controller port allows for 2-way communications between other compatible MOON components The MOON 380D will be available in April 2012 with an MSRP $3,900.00 USD for the base version; Add $600.00 for variable analog outputs;
007 не слышал
DragonOwen А вы раньше 507 где-нибудь слышали? Впечатления такие-же были? Просто для меня 507 - одни из самых темных наушников, которые я когда-либо слышал. Как они могут ярчить
Так ты обмыть забыл! Еще-бы они заиграли
У decware есть провода из серебрянной ленты, говорят хороши именно для ламповых усилителей. А главное стоят недорого.
Могу еще audiophileo в выводок добавить, приехал наконец-то.
Зачем такие неприятные слова говоришь, дорогой? Кто-то хочет произвести впечатление на соседа, кому-то приятно смотреть на свою полку с техникой, кому-то нравится выбирать и покупать - есть миллион причин для того чтобы иметь дома хорошую технику. Не обязательно для этого быть импотентом или меломаном.
дмитрийssd WTF? Вроде слов много знакомых, но смысл ускользает...
похоже после Хиросимы у японцев особый дизайн получился. кстати такие лампы у них до сих пор в цене. После Хиросимы у них началось преклонение перед Америкой, да и винтаж это американский - Western Electric
vitta77 Если он их действительно в сервисный центр сдавал на обслуживание, то однозначно стоят. По хорошему надо его попросить документы из сервисного центра показать...
Для низкоомных плох будет OTL, а с трансформаторным выходом все в порядке будет. Ну или гибридный, с транзисторами на выходе - будет и "ламповость" и универсальность по отношению к омности.
Если кто уже хочет эту карту, но еще не ришился покупать - думайте скорее. В начале следующей недели в Японию уйдет последний заказ. PS. Я про эту тему.
С таким бюджетом и требованиями лучше заказать ламповый усилитель и слушать пока от встроенной звуковушки.
Никого из перечисленных не слышал и не видел, но чисто интуитивно выбираю Onkyo DAC-1000
Не про наушники, зато про форум:
Axel-FPS ... Не понял, а в чем разочарование-то?
Вообще-то ASIO и WASAPI не являются драйверами, это API - способ общения с драйвером. Если есть возможность, лучше пользоваться именно этими API, или еще KS, если винда старая. При их использовании из виртуального тракта исключается встроенный микшер винды, который может портить звук.
Покупал в прошлом году в Аудиомании, цветом были как у Prospero.
Не то чтобы слушал, но включал и в руках вертел Обычный китайских шлак, причем в том ящике что стоял передо мной были эти плееры с любыми названиями на выбор, и texet и Sony и Hisound, думаю если порыться, то и Adidas можно было найти.
Пустышка, пропускаем.
