Весь контент NIK
Album Player (Aplayer)
Это в полную версию входит. What you get. - full version of JPLAY* - free updates - personalized player with your name - custom builds to address your needs - unique support Я сам ничего еще не читал и не смотрел. И не сразу заметил что прога платная.
Попробовать можно. Полная версия платная.
На hi-end.com и 6moons в новостях нашел. Сам еще не проверял. Full memory-based playback no disk activity during playback Most other memory-based players dynamically load tracks into memory during playback. In contrast, jplay pre-loads complete playlist into RAM guaranteeing zero disk I/O during music reproduction. Maximal Priority Scheduling ultra low latency capabilities Ensure uninterrupted flow of music data by running music playback at highest possible priority. Hibernation Mode multicore audio playback Cancel OS ‘noise’ by eliminating dozens of OS jitter-inducing processes & hundreds of threads! Features - support both 32 and 64-bit OS** - support for WAV, AIFF and FLAC files (16-bit and hi-rez) - bit-perfect WASAPI or KS streaming - two unique playback engines - full memory playback (zero disk I/O)* - large-page memory support* - maximum system timer* - maximal priority scheduling* - hibernation mode* http://jplay.eu/
Система KingFiercer.
KingFiercer Pioneer у знакомого когда возьмешь?
Юмор в наушниках
Неа... там стоят Harbeth The Monitor 20.
Юмор в наушниках
Супер наушники... Sennheiser HD800 The Ultrasone Edition 10 L34S4Tt1EuQ
порекомендуйте ЦАП(ы) часть 3
Burson DAC - Following up the HA-160D headphone/preamp/DAC with a dedicated converter has netted the DA-160 [$950] with 2 x 24/96 USB inputs with a 10ppm low-jitter clock, 1 x each 24/192 coax and Toslink inputs, 2 x fixed analog RCA outputs (parallel, both live at all times) and a hi/lo gain switch. Once again all voltage regulators and opamps are built up from discrete components, the output stage operates in class A and "although the DA-160 is based on the DAC section of the HA-160D, being a standalone DAC we had more freedom to further optimise its performance. We decided to tweak the power supply network into a constant current source power supply and use two power transformers to lower the noise. The result is a more matured sound with even richer micro dynamics and substance." Input impedance is 52 Kohms, S/N ratio is >101dB at 0dB gain, THD is <0.001% at 6mW/300 ohms, channel separation is >95dB/10kHz , output impedance is 25/45 ohms selectable, power dissipation is <25W from the internal regulated power supply, dimensions are 180 x 250 x 80mm, weight is 5kg and color is silver-anodized aluminium. http://www.bursonaudio.com/
Комплект для командировки
дмитрийssd Пользуюсь WD (Western Digital)... более надежные они.
Кто что сейчас слушает?
IOU Babe by Mondo Vanilli http://mondovanilli.bandcamp.com/ - Free Download
Немного не в тему, но интересно. bhQntkY1Ank
Megaherz | 2002 | Herzwerk II
Stas Спасибо за группу DOWN.
Нашел? - поделись!
Он про размер говорил) Т.е. качественно звучащее и большое (кирпичи) или маленькое и не звучащее (ipod, cowon). Приблизительно так)
Lynx Studio Technology: Hilo Reference A/D D/A Converter System http://www.lynxstudio.com/product_detail.asp?i=59# http://www.lynxstudio.com/nav/getFile.asp?i=82&t=productfile - PDF Available in the second half of 2011, the US suggested retail price is expected to be $2495. j71-34TFexM
Beyerdynamic DT8x1/9x1, или любимый винтаж !
Амбушки на 990х. Поэтому их слушаю. Сравню их и отпишусь тебе в ЛС.
Лучше не убирать) она приклеена. И лучше не будет. Все же это демпфер, а он всегда нужен. Звук от чашек глушить и расширяет пространство. Вроде так.
911 931
Да. Так и было. Я просто амбушки с них снял и одел на 990е. Саундтреки мне в них нравится слушать.
Я может и чаще слушал бы 931е, но пока амбушек нет лишних. А в прижатых не хочется.
Скорее всего из-за амбушек. У меня 931 с прижатыми амбушками так звучали вроде бы, но утверждать не буду. Не сравнивал.
Нашел? - поделись!
Похожая тема есть на форуме. Привет!
Кроме меня 931е никто и не слушает.
Слушаю 931е. Включил на пять минут, а выключить не могу. Том... я похоже не скоро сравню 990е. Хотел снять амбушки с 911х, но решил перед этим поставить их на 931е (крепления одинаковые) и что-то меня зацепило звучание 931х опять. Я все же постараюсь сейчас переобуть 990е.
Я ж про то, что новые разве греть не надо? По поводу амбушек: это -да, я две темных взял, для 990-х и 880-х, так что будем с тобой надеяться, что они прибудут к нам поскорее Надо греть 990 конечно же, но пока грею 911.
Новые 990е. Но разницу между старыми (80') и новыми (80') 990ми... в нюансах. Завтра постараюсь сравнить. Амбушки мы вместе с тобой заказали) и 2 пары взял. Светлые и темные. На 911е и на 990е старые. 990е (новые) переобули перед продажей... даже оригинальные в хорошем состоянии. 931е тоже с новыми.
