Черная пятница 2026
Новинка 2017-го года. В отличие от предшественника, сменил чип на Ak4497eq.
Характеристики:
- DAC: Ak4497eq DAC
-24bit/192kHz,Native TX DSD
- Zhī Chí Dxd / DSD (Dff, dsf) / FLAC / WAV / Aiff / Alac / APE / Mp3 / WMA / OGG / WV / TTA / DCF
- 3.7-Inch AMOLED touch screen
-3.5 SE output
- 2.5 mm balanced output
-SoundPlus
- Jeteffect 7 & Bbe+, 66 default
- Super Precision Dual Tcxo crystal
-VELVET SOUND Digital Filter
- 123 DB SNR THD+N, 0.0005 vrms %, 2
- Double Knob Operation Key design
- Solid & void full metal machine design, carved glass back shell
- built in 128 GB
- support for outside card (up to 256 GB)
- Optical Fiber Output
Приблизительная стоимость: 1300 у.е
Очень понравился обзорщику Twister6:
Preliminary Sound analysis.
Turned out that the dual Wheel wasn’t the only surprise change. Stepping away from Burr-Brown PCM series DACs, where in the past PCM1792A was used in P1/PS and PCM1795 was used in PM/PM2, the new P2 design now features AKM DAC where Cowon leapfrogged over other DAP manufacturers who still use AK4490 and introduced the latest AK4497EQ. As I already mentioned, I didn’t hear the original P1 and only familiar with PM2, but certainly can draw a conclusion that a sound change is in the air because I’m hearing a more neutral revealing signature with a natural reference quality tonality. And I don’t mean “reference” as in thinner, harsher, or analytical, but rather a more revealing, detailed, layered, and dynamic type of sound with a fast-transient response of notes, black background, and a natural timbre of instruments and vocals.
For example, I consider DX200 to have more reference type of sound quality. In comparison, P2 is a little smoother, with a little fuller body and more low end impact. While testing P2 with W900 hybrid IEMs, I hear the bass punch coming through stronger, with more articulation and authority. In comparison to P2, PM2 is smoother and warmer, not as layered or revealing, and I consider P2 as an upgrade to PM2 where I need to use JefEffect to bring PM2 to P2 level. Based on my early impressions, P2 with its AK4497EQ DAC doesn’t have your typical AK4490 smooth/musical sound, but rather has a smooth reference sound, like a crossover between DX200 and Opus#2. And surprisingly, it sounds very close to LPG, though PAW Gold still uses PCM1792A. I do hear a slightly better layering in sound with LPG, but overall tonality and bass impact are very close. Based on my impressions after 100hrs+ of standalone burn in, I can summarize P2 as being like a crossover of the reference quality DX200 with a fuller body smoothness of Opus#2 and layering and low end impact of LPG.
Another thing I’m very pleased to inform about is that in comparison to other flagship DAPs I have on rotation (LPG, Opus#2, and DX200), I found P2 to have the least amount of hissing with sensitive Zeus XRA. For me it became almost like a requirement to test Zeus w/1960 cable and different DAPs to determine which one will yield the best synergy with the least amount of hissing (when idling).
Изменено пользователем Kraig
Есть:
DAP QP1R-> Ultrasone Signature Pro
Было:
всякое....
@boberlich,
Цена на старте продаж 1290 баксов. А вот как звучит надо послушать. Может выйти неплохой "всеядный" середнячек.
Есть:
Было:
всякое....
@boberlich,
Так они не флагман выпустили, получается? т.е. S остается флагманом...
Изменено пользователем qsk
ROCK > Felix Audio Nothing v 2.1 > Felix Audio Optical Switch mod.3 > Sonnet Hermes > Sonnet Morpheus > Soloist Voyager > Heddphone Two
@qsk, судя по тому, что я понял из восхвалений твистера. По звуку это улучшенная версия Опуса 2. Так, что околофлагман.
Есть:
Было:
всякое....
Ну S хвалят. Надо послушать как-нибудь.
Ты видел сколько он стоит? Ну уж нет. Луту проще взять.
У лоту нет баланса и Tidal на него не поставишь. Хотя, не уверен, что на S можно, если там не андроид ил под стриминг не заточен.
Если вот эта вот конкретная штука и правда играет лучше второго Опуса при одинаковой стоимости, да еще с замашками Лоту, то мы имеем однозначный вин. Но скорее всего нет- не играет. Портативное аудио не сказачное место и сказки сдесь не рассказывают. В любом случае, прежде чем ставить крест на очередном корейском детище, необходимо прежде с ним разобраться.
Есть:
Было:
всякое....
Причем тут мощность. Баланс - это раздельная земля, с лучшим разделением каналов и инструментов. Баланс не всегда мощнее обычного выхода. LPG бестолковый прибор в этом плане. 500 мВт мне не нужно. К тому же мне нужен транспорт для цапоуся, транспортом он будет 60% времени, и тут опять LPG бестолковый прибор. Цапоусь останется основным источником, ибо он интереснее. Да и куда сейчас без Tidal, хайрез тут тоже ни при чем, смысл тайдал в экономии денег и удобстве. Плеер мне нужен для выхода на улицу на короткие дистанции.
Моей музыки практически выше 16/44 не существует, на халявном рутрэкере и половины нет того, что нужно.
Немного впечатлений людей по сабжу, с московской выставки:
Стаська:
А вот cowon plenue 2 меня удивил, играет просто потрясающе, бас лучше чем в онке, ширина такая же, что и в онкё или даже шире, но шире она не только вправо или влево, он еще по высоте расставляет чуть выше и ниже инструменты если вы понимаете о чем я) Это единственное устройство на выставке, которое действительно заслуживает внимания и на которое я бы поменялся)
ценник около 80-90 из Японии
Stixis:
А по моему типичный звук АКМ, приятный, "бархатный". Слушал его недели 3 назад, мне понравился. Но по детальности и нейтральности ему далеко до пионкио. Его бы как второй девайс здорово иметь.
chsas75:
Да послушал в одном букете с поли и канном, достойное устройство, такое чуть бархатное звучание, интеллигентное, без всплесков.
Отзыв владельца ЛПГ:
kirbyDoc84:
Вчера заценил на выставке. Отличный плеер ! Звук чем-то похож на Голд. Звучание энергичное, плотное, детальное. Мне он больше по звуку понравился, чем plenue S. Управление для меня не очень. представители сказали, что это не топ, но звук-топовый.
Есть:
Было:
всякое....
  • 8 months later...
интересно, хоть один плеер был продан в МСК?
  • 4 weeks later...
А тем временем COWON анносировал второе поколение плеера PLENUE 2 MK II .
Основные изменения:
+Встроенная память 256Gb.
+3.24 Vrms на балансном выходе.
+10 часов на FLAC 24/96.
+премиальный чехол!
Цена в районе 1 700 usd.
Уже становится интересно :music:
Изменено пользователем yurix67
Портатив: Cowon Plenue S - Effect Audio Eros II - Rhapsodio Solar;
На столе: iMac (Audirvana+) + Forza Audioworks Twin USB Cable + TEAC UD-503 + JVC HA-DX2000; Denon AH-A100;
В комнате: Sony HAP-S1 + Monitor Audio Silver RS6.
Главное изменение - премиальный чехол.
Отправлено с моего LG-D855 через Tapatalk
Аудиотракт (Hi-End)
Портатив:
Похожий контент
