NIK
Продвинутые
  • Зарегистрирован
  • Посещение
Весь контент NIK
  1. Был iPad и программа splashtop. http://www.splashtop.com/ Плазма, к сожалению, не самый лучший вариант для вывода изображения. Рябит. Может это мак так выводит... не знаю. На PC вроде лучше показывает.
  2. +1 только хардкор, только itunes.
  3. Eddie Current Super 7 Eddie Current - The new Eddie Current Electra is an all-tube electrostatic headphone amplifier " esigned with the objective of producing a lively and dynamic soundstage. It has balanced inputs/outputs, accepts single ended inputs and offers adjustable bias. The Electra comes with 4 x 6SN7 and 4 x 6L6GC." The new Super 7 "is an entry-level headphone amplifier for both balanced and single-ended headphones with a smaller footprint (15.5" x 9.5" x 5.5") than most amps of comparable power. Utilizing 6SN7 tubes, the Super 7 has been designed to provide a superb soundstage. The Super 7 delivers 1 watt into 32 ohms and can be ordered for $1650 plus shipping. A tube package costs an additional $175 and a 120V AC line cord $5." http://www.eddiecurrent.com/Super_7.html
  4. Burson The Soloist New Burson - The Soloist [€940] is the Aussies' new IC-free pure class A reference 3-input pre/headfi amp with up to 4wpc into 16 ohms and 25 watts of power dissipation. It boast a new symmetrical current feedback FET input stage with just 21 parts, "almost 60% less than any IC opamp output stage and 30% less than our own HA-160". A new variable output stage can select from 0.18wpc to 4wpc of headphone power whilst in preamp mode gain factor will morph from 7dB to 18dB in three steps. A new stepped attenuator sports a redesigned gain taper to provide "perfect control" in conjunction with the VSO. The power transformer is rated at 30 watts. S/N ratio is >96dB, input impedance 36.5K and frequency repsonse ±1dB 0-50kHz. Dimensions are 180 x 250 x 80mm, weight is 4.5kg. Release date is July 1, 2012. http://www.bursonaudio.com/Burson_Soloist.html
  5. 7509HD - насчет яркости не знаю... для меня нормальные, но вот 7506 должны быть честнее. 7509 кривые по звуку. Сlubnewmen предложил Баеры 990е... тоже вариант хороший.
  6. Хотелось бы новые. Но я пока только прицениваюсь к ним, сейчас Audeze смакую Планирую в итоге пару из них. Взять б/у. Послушать и понять. Если понравились, то продать и купить новые. А если нет, то продать и искать дальше. И денег много не потеряете на перепродаже.
  7. Вот вот... надо было раньше выложить. Но у меня что-то времени небыло прослушать полностью, а сегодня все альбомы разом прослушал.
  8. Iona Очень рекомендую скачать всю дискографию и сольники! Кельтская музыка. Весьма качественно записаная.
  9. В конце статьи... 21 мая 2012 г. Кузнецов Роман Ну не знаю. Наверное дополненная. Ибо у меня она появилась в новостях.
  10. Обзор, если кому интересно. http://www.ixbt.com/multimedia/asus-one.shtml
  11. ... и не только "людям за 40".
  12. Audio Electronics The Nighthawk headphone amp [$1.195] features top-quality parts mounted on a thick fiberglass board. A power transformer rated at thrice what's required feeds a fully regulated discrete power supply. Operating in class A throughout, the Nighthawk’s front end is a monolithic high-speed FET which meets a fully complementary high-speed buffered output stage for extremely high linearity and low distortion. No global feedback is used and the amp is designed to drive headphones from 20-600 ohms. A five second muting circuit prevents annoying pops and clicks when turning on the Nighthawk. http://www.avguide.com/article/audio-el ... -amplifier http://www.caryaudio.com/
  13. KingRex USB cable The company's new 2m 'power-separated' Unanimous uArt USB cable runs the power and signal lines on physically separated double-shielded legs like Acoustic Revive and applies cryogenic treatment to their silver-plated oxygen-free copper conductors sourced from WireWorld. The plugs sport full aluminum shells and 24K gold-plated copper-alloy contacts. The cable geometry supports 480MBps in full compliance with the High-Speed USB2.0 standard. Pricing is $459 for a 2-meter length. In single form (power and signal lines combined) a 1m cable is $239, a 2m cable $269. A unique application for the double cable is to plug its power lead not into a Mac or PC but the KingRex U Power battery supply. For any DAC's USB transceiver that derives power over the buss this now completely eliminates the computer and delivers pure uncontaminated DC instead. http://www.kingrex.com/home.aspx
  14. WEISS MAN301 VIP Features: External music storage on a NAS (Network Attached Storage) device or USB device multiple NAS units can be added to the library for unlimited storage remote control via an Apple iPad, no keyboard, mouse, monitor required digital inputs for external audio sources: AES/EBU or S/PDIF on XLR, RCA, TOSLINK digital outputs to external D/A Converters: AES/EBU on XLR and RCA, FireWire, USB DAC Version: Analog outputs on XLR and RCA - technical better than our renowned DAC202 unit wordclock input and output on BNC for synchronization Ethernet for connecting to NAS, local network WiFi antenna for connecting to iPad, local network typical setups: 1) MAN301 connected directly to the NAS and iPad, in addition (optionally) to the in-house WiFi for Internet access. 2) MAN301, NAS, iPad connected to a WiFi Router. multiple MAN301 devices can be controlled from within a single iPad multiple users per MAN301 device are supported, each with his/her own music library, playlists, searches etc. all common audio file formats (uncompressed, lossless compressed, lossy compressed) are supported for playback and ripping music library displayed according to album names, artist names, genres, recently played, recently added powerful search facility, allows to store searches which result in dynamic playlists playlists are easily added, edited and can be set safe volume control in 4 coarse analog steps and with a high resolution, dithered digital fader powerful cover art search algorithm which allows the user to select the most appropriate cover art out of an intelligent pre-selection CD metadata fetching from various databases comprehensive user interface on iPad, easily to be handled even by computer novices software upgradeable via Internet internet radio streaming future software upgrades will include various DSP facilities http://www.asiaweiss.com/main/2012/01/25/man301/ http://www.my-hiend.com/vbb/showthread.php?5848-WEISS-MAN301-VIP
  15. Так без проблем) ты у меня 40й отнимешь, а я у тебя 47й.
  16. +1 (Я так же это понял) +1 Многие так поняли)
  17. Вот еще кабелек для 800х... http://6moons.com/audioreviews/entreq4/1.html
  18. Ну почему же? Если б предложили выбрать dcs или бидат, я бы выбрал бидат. Да я же шучу) Пока сам не послушаю бидат ничего плохого и хорошего про него не смогу сказать.
  19. А кому это интересно? Я бидат слышал. И..? Не тяни уже, говори с нами. Этот смайлик " " как бы намекает нам, что бидат не о чем.
  20. +1 это точно! Сейчас как-то не то совсем. Особенно на наших "лицензионных" дисках. Делают копию с пленки и в продажу. Обозвали только лицензией.
  21. Весело! Спасибо всем! Жду продолжения...
  22. У моих есть шипы, плошадка размером (Speaker plate:225 x 225). Так что по требованиям подходит практически. Высоту можно выбрать от 20см до 1 метра. Заказывать выгоднее в европе. У нас дико накручивают цену.
