NIK
Продвинутые
  • Зарегистрирован
  • Посещение
Весь контент NIK
  1. Сегодня... http://www.appleinsider.ru/ipad-mini-2/ ... er-ru.html
  2. Studio Six Ken Ball's ALO Audio bows their new flagship decidely non-portable headphone amp. The Studio Six has 3 inputs, can drive four headphones simultaneously and appears to run 6SN7s with valve regulation and stabilization. Until the teaser page gets expanded, we won't know more however... http://www.studiosixamplifier.com/
  3. Abyss Headphones With the runaway success of the Audeze LCD-2 and HifiMan planarmagnetic headphones, Joe Skubinski of JPS Labs must have decided to get into the act himself. His new company Abyss Headphones just introduced the Model AB-1266. This combines an aluminum exoskeleton with tuned woods and magnetically affixed lambskin ear pads, hookup cabling by JPS and diaphragms of the ultra-thin planar type. http://www.abyss-headphones.com/
  4. Woo Audio WA7 The compact WA7 single-ended triode headphone amplifier from NY-based Woo Audio includes a 32/192 USB DAC and encases its valves in a thick slab of acrylic for another statement in miniature headfi chic. http://www.wooaudio.com/
  5. Ну как?! Была ли сходка?
  6. с затычками все гораздо проще. Так вроде не только затычки хотят послушать. Sansui 100i - принеси в кафе и заткни всех Боюсь не поймут меня.
  7. с затычками все гораздо проще. Так вроде не только затычки хотят послушать.
  8. Лучше у кого-нибудь дома собираться. Тогда еще что-то понятно будет, что слушаешь.
  9. Sennheiser HDVA 600 Sennheiser unveils HDVA 600 analog headphone amp, wallets tremble in fear Along with a few IFA 2012 announcements, Sennheiser peeled back the wraps from its HDVA 600 headphone amp, an analog flavor of the previously unveiled HDVD 800. Like its sibling, the freshly revealed hardware sports a glass panel for peeking at its innards and an anodized aluminum exterior, but leaves the digital inputs behind. While the 800 carries a hefty $2,000 price tag, the 600 will set customers back a smaller -- but still substantial -- sum of $1,600. Both units are tailored for the likes of Senn's flagship HD 800 headphones, so they should easily be able to drive cans that require up to 300-ohms. The pair won't be available in the US until later this fall, but in the meantime, you can breeze past the break for specs and more details in the press release.
  10. ALO Audio The new PanAm portable headphone... The new PanAm portable headphone amp combines a 24/96 Wolfson USB DAC with 1/8" and standard RCA inputs, 3.5/6.3mm headphone sockets and hi-lo gain switch whilst the optional external PassPort battery pack ensures 10 hours of anywhere listening. The tubes are offered as both Russian military and Siemens OEM upgrades. Frequency response is 40 - 30.000Hz ±1dB, max voltage swing is 22V, input impedance is 10K, max input level is 3.5V rms and channel tracking is better than ±0.2dB. http://www.aloaudio.com/
  11. CIAudio Transient MKII Asynchronous USB Converter $699 Features: Audio Circuit The heart of the system is our XMOS based circuit utilizing extremely low-jitter clocks. Multiple digital outputs are available via isolated 75 ohm BNC (with included 75 ohm RCA adapter) and two individually buffered I2S outputs. High Quality DAC In addition to the digital outputs, Transient also provides Digital to Analog conversion. The conversion is done by a Wolfson circuit with a built-in high resolution volume control and 2V RMS output. A microprocessor circuit allows configuration for fixed (line level) output, or variable volume control, and also indicates the sampling frequency of the incoming signal. Chassis and Build Highest quality parts are used throughout: Nichicon Muse & 2% tolerance polypropylene power supply capacitors, Takman resistors and WIMA polypropylene capacitors for signal circuits, and Canare BNC connector. The shielded anti-resonant chassis is 1/8 thick T6061 aluminum with 3/16” thick front panel, and all hardware is non-magnetic stainless steel. Runs off the grid The Transient is powered by the USB cable so you can plug into your computer audio and take it on the go. Our VDC-5 MKII Upgrade Power Supply can be connected to the DC Input port for improved performance. Specifications: Digital Outputs:• S/PDIF via 75 ohm BNC Connector (Galvanic Isolated) • I2S via Mini DIN Connector (Audio Alchemy/Perpetual Tech/Camelot) • Differential I2S via HDMI Connector (PS Audio/Wyred4Sound)Sample Rates Supported44.1k, 48k, 88.2k, 96k, 176.4k, 192k up to 24bitsMaster Clock Jitter:< 1.0psecAnalog Output Level2V RMS Maximum (Single-ended RCA)Frequency Response 20hz to 96kHzTHD + Noise:-89db @ -1dBFSDimensions4.45"W x 2.9"H (including feet) x 5.25" DShipping Weight5 lbsWarranty5 Year Parts & Labor http://www.ciaudio.com/products/TransientMKII
  12. Thom_Yorke Поздравляю еще раз! Рад за тебя!
  13. Thom_Yorke Поздравляю!
  14. Смотри аккуратно там в офисе) Может у него ноуты прям с завода foxconn) А он не сказал, как оплата проходит? предоплата и потом ноут или оплатил и ноут забрал)
  15. Это на какие вещи? Я сходства не увидел. Пожалуйста!
  16. Самый лучший продавец - это AppleJesus. http://vk.com/applejesus Покупали у него много раз. Цены отличные. Может и скидку сделать. А http://vk.com/id177234064 явно кидок какой-то очередной. Apple MacBook Pro 15 Retina display Quad i7 2.7GHz/16Gb/768SSD Евротест mid 2012 Максимальный цена 36 000руб. - это можно сказать подарок с его стороны. При реальной цене в $3,749.00 за этот ноут.
  17. KingFiercer Ооо... дождался! Поздравляю!!!
  18. ADL ESPRIT DAC and ADC Digital Preamplifier / Recording Interface http://www.my-hiend.com/vbb/showthread. ... ADL-ESPRIT
  19. NuForce DAC-100 | MSRP $1095 Specifications: http://www.nuforce.com/hp/products/dac100/index.php
  20. NuForce DAC-100 | MSRP $1095 NuForce DAC-100 is a class-leading digital-to-analog converter (supporting USB and S/PDIF) and headphone amplifier designed for consumers seeking a level of performance typically found in the finest audiophile equipment. The DAC-100 accepts up to four digital input sources and features a precision digital volume control, a high-power headphone amplifier section with extremely low distortion, a high-resolution analog RCA output stage, and a convenient wireless remote. The DAC-100 incorporates several NuForce innovations: Low Jitter The DAC-100’s digital input stage operates in an asynchronous mode independent of any timing errors associated with the incoming digital audio stream. The input stage synchronizes the data to an internally referenced timing signal generated by an exceptionally stable circuit. The re-clocking circuit’s accuracy is such that any negative timing errors (jitter) are reduced to near theoretical limits. Read about Jitter FAQ Powerful Headphone Amp The DAC-100's headphone amp delivers enough power to drive most headphones with absolute authority. It provides a full 500-milliwatts Single-Ended Class "A" power, held by many audiophiles to be a headphone amp’s purest form of circuit topology. Precision Volume Control A digital 32-bit volume control offers precise channel tracking. Unlike more common digital volume controls operating at 24 or 16-bits, the 32-bit dynamic range of the DAC-100's volume control avoids any loss of low-level resolution. Transparent Preamp The analog preamp stage is a minimalist design offering a signal path that approaches a straight-wire-with-gain level of performance. Combined with top quality parts and a full 2.0Vrms signal level at the RCA outputs, the preamp section of the DAC-100 ensures that only the purest of analog music signals will ever be presented to your preamplifier. No Up-sampling A 24-bit, 192kHz DAC stage accurately converts digital audio data back to an analog signal at its native sampling rate. No up-sampling or other questionable data manipulation is ever employed. Note: For Async USB Audio, please refer to the Async USB Audio FAQ and Setup Guide. The following plots showed exceptionl performance of DAC-100. Please refer to larger images of the measurement plot in the image gallery above. Specifications: Digital: (4) Digital inputs: USB, Toslink, RCA x 2, transformer or optical isolated, AC coupled. Maximum bit depth: 24 bit Maximum sample rate: 192kHz USB: Asynchronous up to 192kHz/24-bit. Please refer to the Async USB Audio FAQ and Setup Guide. Sample rate indicator Volume control: 32-bit digital attenuator Analog: THD+N: 0.005, 0dB, 1kHz SNR: 96dB, 1kHz, A-weighted Frequency Response: 20-25kHz +/- 0.25dB Outputs: RCA, 6.3mm headphone output Output voltage 0dB, 1kHz: RCA 2.0Vrms Output Impedance: RCA, 100-Ohm Headphone Specifications: Recommended Headphone Impedance: 120-600 Ohm Output: 10.4 Vpp, 3.7 Vrms @ 300-600 Ohm Single-ended, constant current 80mA Remote Control Functions: Volume, Input Select, Mute, Stand-by AC voltage: 100V/110V/220V/230V Power consumption: 12-Watts. Dimensions: Height: 2 inches ( 5.1cm ) Width: 8.5 inces ( 21.6 cm ) Depth: 9 inches ( 22.9 cm ) Weight: 2.64 pounds ( 1.2 kg ) Available in black and silver color. Included Accessories: USB cable (1 meter) http://www.nuforce.com/hp/products/dac100/index.php
  21. Похоже, что это весь репертуар для 800х. ... больше в них слушать нечего.
