AlexV
Пользователи
  • Зарегистрирован
  • Посещение
Весь контент AlexV
  1. Сам пользуюсь связкой Yulong DA8 и Fostex 600. Встроенный усилитель раскачивает их прекрасно. Перечисленные стили также отлично воспроизводятся. Если возьмете фостекс, будет отличный вариант!
  2. AlexV ответил none тема в Denon
    Искренние поздравления! Значит всё-же определенный "окрас" звучания Лоутону удалось жестко привязать к породе (и наверное к определенным особенностям внутренней формы и толщины стенки). Ну а как выглядят-то? Фотку бы... Выглядят просто потрясающе!!! :appl:
  3. Очень чувственная акустическая музыка. Просто рвет душу.
  4. На хеадфай следил за веткой о Gustard H10, много лестных отзывов в сравнений с "оригиналом", кто-то считает, что Густард даже лучше: "To my ears.. it sounds better than the V200 (which I owned for quite some time.. albeit, awhile back). The H10 possesses a larger soundstage than the V200.. the V200's mids (and really, the presentation in general) sounded more dry, comparatively speaking.. the H10 is better balanced in terms of tone (it's not dry.. but not lush, either).. and the H10 possesses better treble clarity (I found the V200's treble ever so slightly (but audibly) rolled off in the upper treble). The H10 certainly doesn't spotlight the highs, though.. it's very smooth through the treble.. but seems better extended (or I perceive better extension) than the V200. The H10 also seems to possess a wider (and deeper) soundstage." (с) FlySweep он же "I don't know how many H10 owners here have owned (or heard) the V200 (besides me).. so I'll just speak to my experience. I had the V200 quite some time ago.. so my memory about its particulars are a little hazy. Looking back at my notes on it (and comparing it to the H10).. the H10 possesses a larger soundstage, better bandwidth, better tonal purity, and better clarity/instrument separation than the V200. At the very least, it's every bit as good as the V200 (IME).. so it obviously offers much better value since it's nearly a third of the price of the V200. I've owned a few pieces of Vio/LP gear in my time at HF (LP G109, Vio V800, Vio V200).. I enjoyed it all (especially the build quality.. wonderful!).. but if you're after that type of sound, technical ability, I think the Gustard gear offers better bang for the buck." Это как раз и есть разброс параметров: одному мед в уши, а другому жесткий и грубый звук. Могут быть лучше, а могут быть хуже. Это уж как кому повезет )))))
  5. , Однако, как я понял из Вашего сообщения, Вы не торопитесь менять поставщика, если покупаете двигатели с 2000г. )) Брак есть везде и у всех. Думаю, что немцы исправно выполняют свои гарантийные обязательства. Не нужно распространять выводы на всю немецкую технику, если качество электродвигателей упало в поставках на Вашей работе. Хотя пример хороший)). Я по крайней мере еще не встречал отзывов, о том что виолектрик сгорел из-за забытой в корпусе детальки. То что китайцы развиваются и семимильными шагами - это факт. Против китайской техники я ничего не имею. Но клоны и плагиат не приветствую в любом виде. Это лично мое мнение.
  6. , Для того, чтобы собрать усилитель одной схемы мало, если мы говорим о промышленных масштабах. Нужно еще организовать рабочие места, обучить персонал, разработать инструкции, внедрить систему контроля, систему качества и т.д. И здесь уже не играет роли кто участвует в процессе производства: немцы, русские или эмигранты со всего мира. На выходе должен быть качественный продукт.
  7. @Vict07R, Разброс характеристик от номинала у радиокомпонентов может быть очень большим. Это несомненно окажет влияние на выходной звук. Вопрос в том, насколько у китайцев налажен процесс сборки усилителей. Насколько он стабилен, как и кем контролируется. Здесь на форуме уже приводился очень удачный пример иллюстрирующий разницу между китайскими и брендовыми машинами. На какой ездить - дело сугубо личное. Я лично склонен доверять немецкой технике. Хотя и китайская техника имеет право на существование. Вот только о максимальном качестве клонов здесь говорить не приходится.
  8. считаю, что смысла в сравнении нет, т.к. разброс между параметрами клонов может быть очень значительным.
  9. Подскажите у grado rs1e и grado rs1i сильная разница в звуке? Вроде рекомендуют брать rs1i , в новом выпуске звук уже не тот. У кого была возможность сравнить эти две модели поделитесь мнением..
  10. Многие усилители очень чувствительны к внешним наводкам, в том числе и к wi fi, почитайте к примеру ветку по Icon Audio. Хотя звуком все очень довольны.. Подтверждаю, что фоновый шум можно устранить заклеиванием земли на вилке Юлонга. Фон между треками становится абсолютно "черным".
  11. Draconian - A Rose For The Apocalypse (2011)
  12. http://www.youtube.com/watch?v=RsjHvaU5Aik
  13. Rebellion - Arise From Ginnungagap To Ragnarok - History Of The Vikings, Vol. III (2009)
  14. Eternal Tears of Sorrow - Children of the Dark Waters-2009
  15. Если будете использовать юлонг с усилителем все ваши проблемы с шумами точно отпадут. Рассмотрите этот вариант в перспективе..
  16. По поводу шумов однозначно компьютер. Попробуйте подключить юлонг на другом компьютере, посмотрите пропадут шумы или нет. А вот по функции Pure DAC Amplifier не понятно - не должны играть наушники в этом режиме.
  17. Карданный Вал. Ржачный отечественный Deathgrind Metal
  18. Сам подключал низкоомные Fostex ТН600 к Yulong, он их хорошо прокачивал, но фоновые шумы имели место быть в паузах между треками. В процессе прослушивания музыки шумов не слышно, никакого дискомфорта не было. По причине шумов пришлось купил усилитель Violectric V200. Он отлично справился со своей задачей. Теперь между треками гробовая тишина. Скорее всего шумы возникают из-за наводок железа компьютера. Попробуйте понаблюдать, что меняется при появлении шумов: скорость вращения кулера, работа жесткого диска и т.д. По Вашему описанию проблемы Вам достался производственный брак, как это печально не звучит - не должны наушники играть в "чистом" цапе. Где покупали Юлонг? Может написать письмо продавцу для замены по гарантии?
  19. Bolt Thrower- Those Once Loyal- 2005
  20. Estatic Fear-A Sombre Dance-1999
  21. My Dying Bride - Symphonaire Infernus Et Spera Empyrium
  22. ага, а с песни "рашен водка" началось увлечение крепкими алкогольными напитками ))
  23. Katatonia - Dance Of December Souls-1993
  24. Tiamat - Wildhoney - 1994
