Весь контент Victor
Что вы сейчас читаете?
Хенкин Кирилл Викторович "Охотник вверх ногами" От издателя Эту книгу автор посвятил памяти его близкого друга Вилли Фишера (Рудольфа Абеля), она проливает свет на специфику работы НКВД-КГБ среди интеллектуальной элиты Запада и русских эмигрантов. http://www.ozon.ru/context/detail/id/6759621/
Одноплатные компьютеры (SOC)
piCorePlayer = Squeezelite on Microcore linux http://forums.slimdevices.com/showthread.php?97803-piCorePlayer-Squeezelite-on-Microcore-linux-An-embedded-OS-in-RAM-with-Squeezelit Use your RaspberryPi as a Squeezebox Player https://sites.google.com/site/picoreplayer/home piCorePlayer is a dedicated Squeezebox player (like a Duet receiver) for your Raspberry pi board. It is build on a small read-only linux (Microcore) and Triodes excellent Squeezelite player. It is very small about 55 MB in total including the OS (microcore linux). It boots very fast, already 10-15 sec after you power on, then your piCorePlayer will be found in the Logitech Media Server control panel. After booting everything is running from RAM so there is no writing to the SD-card and therefore no risk of corruption of your card - just pull the power if you need to. It is possible to synchronize the piCorePlayer to other Squeezebox devices. Included in piCorePlayer: 1. Microcore linux 2. Squeezelite player 3. WEB-server so the configuration can be managed via your browser 4. Setup script 5. SSH access (using Dropbear) - so you can connect via LAN from another computer (via Putty). 6. Option to use a WiFi dongle 7. Option to use a USB-DAC with up to 24 bit 192 khz 8. Option to use HDMI audio out up to 24 bit 192 khz (out of the box) 9. Option to use the 3.5" audio jack (out of the box) 10. Option to use a analog I2S-DAC (Hifiberry DAC), (IQaudIO) and a I2S DAC based on the Sabre 9023 chip 11. Option to use a Digital I2S-DAC (Hifiberry Digi) You will need: 1. A raspberry pi board and a SD-card (can be very small as the entire piCorePlayer is only 26 MB- (sorry grown to about 60MB)). So the cost for a working system will minimal about 35$ for the raspberry pi board and a then you will need a SD-card which can be found from 5 $. Even the smallest will be fine. If you want better audio experience you will also need a USB-DAC (but actually I think the audio from the 3.5" analog audio out is better than reported). 2. A running Logitech Media Server which you can connect to. Logitech Media Server https://en.wikipedia.org/wiki/Logitech_Media_Server Logitech Media Server http://www.mysqueezebox.com/download http://support.logitech.com/en_us/product/squeezebox Сетевой аудиоплеер Logitech Squeezebox Radio Основой данного решения является специализированное серверное программное обеспечение (Squeezebox Server), предназначенное для потоковой трансляции звука на совместимые плееры. http://www.ixbt.com/multimedia/squeezebox-radio.shtml
ТОР программных аудио продуктов (Software)
OpenELEC 6.0.2 full RaspberryPi 3 support including onboard WLAN and Bluetooth это есть гут OpenELEC is an embedded operating system built specifically to run Kodi (formerly known as XBMC), the open source entertainment media hub. The idea behind OpenELEC is to allow people to use their Home Theatre PC (HTPC) like any other device you might have attached to your TV, like a DVD player or Sky box. для аудио это не есть гут
если автор ветки поддержит(?) и подтолкнет модераторов: то, начиная с поста #1003 http://forum.doctorhead.ru/index.php?showtopic=25252&st=1000#entry829537 все перенести в новую тему: LINUX&SOUND
угу, тогда уж надо добавить в список: VortexBox Voyage Linux AudioPhile Linux и Tiny MPD
- Одноплатные компьютеры (SOC)
Audiophonics RaspDAC Kit DIY Network player for Raspberry Pi 2.0 & DAC 84,90 € http://www.audiophon...ac-p-10511.html http://megavisor.com/view/36cb260e-e1f4-4e61-bc50-dba57660743c Audiophonics RaspDAC Network player Raspberry Pi 2.0 & DAC Sabre 249,00 € http://www.audiophon...re-p-10369.html
J River Media Center
Если желательны удобство, универсальность (аудио и видео-коллекция) и высокое качество звука при невысокой стоимости ПО, то по совокупности характеристик альтернативы особо и нет. Можно на основе Jriver сделать аудиофильский(?) DLNA сервер (аудио+видео), т.е. хранить и конвертировать "на лету" в WAV - пускать PCM аудио-поток (видео-поток) на любое (почти любое) устройство в доме Windows, Linux, Android - комп., микрокомпьютер, планшет... правда, без лицензии - вряд ли получится Media Network http://wiki.jriver.c...p/Media_Network https://www.jriver.com/thenet.html Media Server https://wiki.jriver....of_Media_Server Remote Control and Streaming for JRiver Media Center http://www.jremote.net/
Душевная тема
уточняю для пртокола: просто комментирую эпизод из душевного советского фильма "Похождения графа Невзорова" , где достоверно показан собирательный образ отечественного особиста
Схемотехника усилителей для наушников.
"В СВЧ диапазоне используются также многоструктурные транзисторы, которые состоят из нескольких многоэмиттерных транзисторов, размещенных на одной полупроводниковой пластине и объединены в единую систему. Отдельные элементы такой структуры размещены достаточно далеко один от другого, так что их тепловые потоки не перекрываются и рассеиваемая мощность возрастает. В конструкциях корпусов мощных СВЧ-транзисторов предусматривают не только малое тепловое сопротивление, эффективный теплоотвод, но и малые индуктивности выводов, а также малые емкости между выводами и корпусом. 13 случае необходимости корпусу СВЧ-транзистора придают форму, удобную для установки в волноводные тракты. http://mirznanii.com...tranzistorov-bt " 1.не все 2.УНЧ японца с параллельным включением маломощных НЧ-СЧ транзисторов возможно неплох, кроме того маломощные легче подобрать в пары по параметрам - они дешевле
" Современные биполярные транзисторы изготавливаются на основе монокристаллического кремния по диффузионной технологии с использованием планарного процесса. Базовая ячейка транзистора n-p-n типа представлена на рис. Такую структуру имеет большинство современных типов силовых биполярных транзисторов. Для p-n-p транзисторов будут справедливы практически все выводы, полученные при анализе процессов в рассматриваемой базовой ячейке. Для создания структуры ячейки в качестве исходного материала или подложки используется низкоомный n+-слой, на обратной стороне которого создается омический контакт коллектора. На подложке эпитаксиально выращивается высокоомный коллекторный n--слой, в котором методом диффузии формируется слой p-базы. Таким образом, в структуре образуется асимметричный коллекторный p-n- переход. Далее на поверхности p-базы проводят планарный процесс. Он заключается в создании пленки диоксида кремния и проведении через специально вытравленные окна имплантации донорной примеси для формирования эмиттерных n+-областей. После этого на верхней поверхности кристалла создают металлизированные слои для выводов базы и эмиттера, разделенные изолирующими участками диоксида кремния. Таким образом создается вертикальная структура силового биполярного транзистора." т.е. это не "толпа транзисторов", а особенности эпитаксиально-планарной технологии Каждый кристалл IGBT биполярного транзистора представляет собой параллельное соединение огромного количества отдельных транзисторных IGBT структур (ячеек). Плотность размещения отдельных ячеек добивается нескольких сотен тыс на 1 квадратный сантиметр. Устойчивая совместная работа настолько огромного количества простых IGBT структур обеспечивается за счет положительного температурного коэффициента сопротивления и вытекающего из этого факта самовыравнивания по току, что и является основой сотворения IGBT полупроводниковых устройств на огромные токи. http://regulyator.com/?p=1123
Душевная тема
господин полковник, особист из царской охранки (кого он там мочил?), находится на кораблике с русскими эмигрантами, плывущими в Турцию год создания фильма 1982
Душевная тема
Юрьев день Похождения графа Невзорова
.... и поэтому Госдеп обеспокоен активностью провокаторов
наверное это имелось ввиду: LDMOS, биполярный СВЧ транзистор http://www.arms-expo...ples/891/62366/ http://www.gaw.ru/ht...igbt/nxp_tr.htm мне бы почитать статейку по НЧ-транзисторам с фото "толпы на кристалле", а так, да - "толпа" согласованных СВЧ транзисторов на одном кристалле (см.фото), а также мощные IGBT транзисторы в параллель на кристалле - в силовой (импульсной) электронике
@kleymor.metal, сущности плодятся и размножаются - не поливать, само засохнет
угу, ваше начальство торопит... а нам не к спеху) подключат еще пару таких "помогал" производителю ПО и скАчки сорваны
вообще-то у японца Шиклаи на маломощных транзисторах, какой смысл в них на кристалле городить параллельные структуры в ущерб, видимо, частотным свойствам? зайчики, говорите? https://www.youtube.com/watch?v=LKsNH1w24H0
понятно - провокатор
дык я и есть агент Госдепа, а вы-то кто?
а производитель ПО знает о вашем щедром предложении?
EDUCATIONAL TOYS AND KITS http://schmartboard....featured&page=1 техническое образование ребятишек, Максим, это, конечно, вопрос денег (кроме энтузиазма преподавателя)
алаверды - метод макетирования двухканального УНЧ актуально для тех, кто в стесненных жилищных условиях
Максим, ладно, пусть "аудио-клиент" сам решает надо ли "куфейзы городить..." ну, или вы похвалите )
ну, хорошо, а этот какие задачи решает? The Sapphire Desktop Headphone Amplifier http://phonoclone.com/diy-sapp.html
