Beyerdynamic DT 770 i 16 Ohm
Кто нибудь имел опыт прослушки:
The DT 770 i headphones with 16 Ohms proves its power when connected to mobile devices where the a higher volume is required.
The DT 770 i is a closed dynamic headphone of exceptional quality suitable for the most demanding professional and audiophile applications. The long term comfort and accurate performance make the DT 770 i the perfect mobile monitoring headphone and for recording studios, post production or broadcasting situations. The low mass coil and diaphragm assembly produce a transient performance equalled only by electrostatic earphones, and, in combination with a carefully tailored frequency response offer a natural and balanced sound. Soft earpads and adjustable, sliding, earpieces together with a single sided connecting cable ensure listening comfort during extended periods of use.
Features:
  • Closed diffuse field studio headphone
  • Innovative bass reflex system
  • Robust spring steel headband
  • Single sided cable
  • Soft inner headband
  • Gold plated jack plug (3.5 mm) and adapter (6.35 mm)
Specifications:
  • 16-ohm driver especially for mobile use for max volume
  • Ideal for us with Apple and Android devices
  • Closed design with excellent isolation for undisturbed listening
  • Softskin ear cushions for easy cleaning and better suppression of ambient noise
  • Single-sided 4 foot connection cable
  • Sturdy, comfortably padded headband design with adjustable spring steel construction
  • Sturdy, easy-to-maintain design with parts that can easily be replaced
Indoor: acoustic setup: Apple iMac [Retina 5K 27" Core i5 3,3 ГГц, 8 ГБ, 1 ТБ, AMD R9 M290], Player Audirvana + >>> USB DAC>>SUGDEN A21SE>>> Chord Carnival Silver Screen bi-wiring>>>ProAc Studio 100 (DYNAUDIO Stand 6)
Offfice: Deezer/TuneIn/DSD audio>>>ONKYO DP-S1A>>>Earsonic ES3
Outdoor: ONKYO DP-S1A/Earsonic ES3
Airplan: iPhone/iPadmini>>> BOSE QC 35
Owned in the past: April Music Eximus DAC/Helium balanced Beta 22 amplifier/Audeze LCD 2 fazor/Beyerdynamic TP5 (2-nd edition)/Denon AH-D500/Fostex TH-X00
Заточены под переходник для айфона похоже.
Они еще выпускались задолго до новых айфонов.
  • 5 weeks later...
Эта модель хорошая по звучанию?
Стоит взять как бумаете???
