Romario1976
Пользователи
  • Зарегистрирован
  • Посещение
Весь контент Romario1976
  1. QP1: standard version QP1R: reference version As a Reference piece, the QP1R uses higher quality components, as well as, a more critical approach to the audio circuit, producing lower distortion (QP1R THD+N=0.0006%, QP1 THD+N=0.0015%) and superior sound quality. The QP1R also employs a different PCBA, a larger internal storage chip (32GB), and a different version of software. _ueditor_page_break_tag_ Patented "Current Mode Amplification" in headphone AMP, all discrete components, Pure Class A circuit. File Format Support:WAV, FLAC, ALAC, APE, AIFF, ADPCM, LPCM, MP3, WMA,WMA Lossless, OGG, AAC, DFF, DSF Sample Rate: PCM Native: 44.1 kHz - 192 kHz(16bit/24bit) DSD Native: DSD64(1bit 2.8MHz)/DSD128(1bit 5.6MHz) DAC:Cirrus Logic CS4398 Output:3.5MM headphone output, 3.5MM line out & optical output Frequency Response: 20Hz-20 kHz(±0.1dB) QP1 THD+N= 0.0015% QP1 R THD+N = 0.0006% Output Impedance : QP1: 0.19Ω QP1R: 0.15Ω Memory: Internal: 16GB(QP1)/32GB(QP1R), External: supports Micro SD card 2*128GB Battery:3300mAh Li-polymer, 8-10 hours Charge Current: Via PC USB connection @ 450mA, Charging Time: 8 hours Via Charger @ 2A, Charging Time: 4 hours Body :CNC cutting aluminum case, Available in Space Gray/ Gold Headphone AMP Output Power Gain = High Max Output Amplitude: Vout=1.9V rms Output Power: Pout=40mW @32Ω Pout=12mW @300Ω Gain=Middle Max Output Amplitude : Vout=1V rms Output Power: Pout=31mW @32Ω Pout=3.5mW @300Ω Gain=Low Max Output Amplitude : Vout=0.53V rms @32Ω Vout=0.51V rms @16Ω Output Power: Pout=8.8mW @32Ω Pout=16.3mW @16Ω Manufactured by Foxconn Сейчас жду игрушку QP1R, думаю через недельку другую должен приехать. Технологии должны быть объединены в чистый Hi-Fidelity Архитектура корпуса QP1 и QP1R не просто элегантна, легкий и прочный корпус спереди и сзади покрыты прочнейшим Gorilla Glass, что положителлно сказалось на массе устройства и стало прекрасным решением с эстетической и практической точки зрения. В рамках непрерывного внедрения инновационных технологий и постоянных изменений понятия стиля корпус QP1 и QP1R полностью отвечает поставленным инженерами, дизайнерами и аудиофилами задачам. QP1 и QP1R поддерживает такие форматы как ALAC, APE,FLAC,AIFF,WAV, WMA Lossless to 24/192KHz и Hi-Rez аудио форматов DSD64 и DSD128, раскрывая намного больше деталей, ньюансов и позволяя записям буквально дышать реалистичностью. В качестве Hi-End портативного ЦАПа данное устройство позволит Вам наслаждаться записями студийного качества при весьма низком энергопотреблении(время автономной работы около 10 часов). В течении трех последних лет компания Questyle занималась созданием данного плеера - от идеи до реализации. Многочисленные доводки и оптимизация операционной системы, алгоритмов плеера, цифрового и аналоговых контуров был найден и воплощен самый лучший вариант. Качество звука как основной приоритет QP1 и QP1R построены на 3X кварцах, позаимствованных из стационарного "брата" CAS192D, что позволило более точно работать USB тракту. Так же трехкварцевая схема с асинхронной архитектурой FIFO и отдельным стабилизированным питанием для каждого кварца способствукт более точной звукопередаче. Сам ЦАП построен на референтном CS4398 позволяет более детально раскрыться Вашей музыке. Технология токового усиления Технология токового усиления компании эже стала легендарной. Позаимствованная из CMA800R и оптимизированная для работы в портативном сегменте она позволила шагнуть далеко вперед обеспечивая поддержку практически любых наушников. В режиме низкого усиления плеер с легкостью справляется с такими специфическими наушниками как К3003, импеданс которых 8 ом, а при переходе в режим high gain ему становяться "по зубам" такие тяжелосесы, как HD800 с импедансом 300 Ом. В QP1R использована другая операционная система, печатная плата, и компоненты премиум класса, что сказалось на характеристиках плеера и его стоимости. ТТХ: Поддержка:WAV, FLAC, ALAC, APE, AIFF, ADPCM, LPCM, MP3, WMA,WMA Lossless, OGG, AAC, DFF, DSF Битрейт:FLAC,WAV,ALAC,AIFF: 44.1 k Hz - 192 k Hz(16bit/24bit)per Sample) DSD Native: DSD64(1bit 2.8MHz)/DSD128(1bit 5.6MHz) ЦАП:Cirrus Logic CS4398 Выходы: 3,5 мм наушниковый, 3,5 мм линейный и оптический выходы Спецификации аудио: Частотный диапазон: 20Hz-20 kHz(±0.1dB) QP1R THD+N : 0.0006% Исходящийимпеданс : <0.19Ω Память:32 GB встроенной, поддержка Micro SD 2*128 GB Питание:3300mAh Lion (10 часов автономной работы) Подзарядка:через PC USB около 8 часов, через зарядное устройства 2 Амп около 3х часов Корпус :алюминий (доступны в серебрянном и золотом корпусах) Производится на Foxconn
  2. На хедфае есть отзывы и практически все хорошие. Тоже думал взять. Пока был в Москве, заказал, но не привезли. Сослались на то, что первая партия была сырая и были проблемы с колесом и регулятором громкости. Хотел заказать в Украине, но опаздал на один день. Теперь жду вторую партию.
  3. Я думаю если заблокируют, сразу появится альтернатива. Не победить у нас в России такие ресурсы!!!
