keeper58
Пользователи
  • Зарегистрирован
  • Посещение
Весь контент keeper58
  1. Bug head Emperor 2.69 beta - http://oryaaaaa.world.coocan.jp/_userdata/bughead_emperor_beta.zip 32-bit 2.69 (Beta) 2.68 test 64-bit 2.69 (Beta) 2.68 test 2.51 super (test) z Tune is more natural. (268test enable) z Tune???????268test????????? * Normal mode is irrelevant. ????????????? How to z Tune 1st dialog SHIFT+Z , and Display "z Tune" RAM 8GB RAM, 64 bit only ???????SHIFT+Z???? "z Tune"??????? ????GB?64????? * Processing time x4
  2. Bughead.exe Ver2.68 Bughead_test268.exe Ver2.68 http://oryaaaaa.world.coocan.jp/_userdata/bughead_emperor_beta.zip
  3. How to Raw output Bug head output (level over) sound, then Don't suppot WAV or FLAC. RAW only. 1. setup Add Audio files set Sound mode (Black, LPF, Bug LV, Phase, Auto) change self sound optimizer enable RAW ( click ok ) 2. convert run PLAY If D:\ABC.flac , D:\ABC.flac.raw save path output, add ext ".raw" 3. Editor Audacity Audacity RAW Import File > Import > Raw data Encording 32 bit float Byte order Little-edian Channels 2 channel (streo) Start offset 0 byte Amount to import 100% Sample rate 44100 / 88200 / 176400 / 352800 and Project samle rate 176400 select 4.Normalize or etc 5.output audio files
  4. 2.68 test http://oryaaaaa.world.coocan.jp/_userdata/bughead_emperor_beta.zip 32-bit 2.68 (Beta) 2.68 test 64-bit 2.68 (Beta) 2.51 super (test)
  5. 2.68 beta - http://oryaaaaa.worl...mperor_beta.zip Fix raw output and processing
  6. 2.67 beta 2 - http://oryaaaaa.worl...mperor_beta.zip Fix buffer gap (output, raw output) 2.67 beta 3 2.67 beta 4
  7. 2.65 beta 3 - http://oryaaaaa.world.coocan.jp/_userdata/bughead_emperor_beta.zip
  8. 2.64 beta - http://oryaaaaa.world.coocan.jp/_userdata/bughead_emperor_beta.zip free bug lv sound spell add test mode "Magnet x 4"
  9. 2.63 beta - http://oryaaaaa.worl...mperor_beta.zip I'm sorry. coz, 2.62 have one bug. and I call Infinity. He said "You just dump 2.62 beta annouce, and I give you parameter for 'Auto'."
  10. 2.62 beta 4 - http://oryaaaaa.world.coocan.jp/_userdata/bughead_emperor_beta.zip Bug fix "Auto" parameters for new process.
  11. Update 2.62 beta 2 - http://oryaaaaa.world.coocan.jp/_userdata/bughead_emperor_beta.zip Phase-reversal process, auto parameter is down.
  12. 2.62 beta - http://oryaaaaa.world.coocan.jp/_userdata/bughead_emperor_beta.zip Self sound optimizer add [E] double add [W] obelisk add cooktail add [T] rawen Please mix a little [E][W][T] to default presets black, banana or.
  13. Update 2.61 beta (test) http://oryaaaaa.world.coocan.jp/_userdata/bughead_emperor_beta.zip BugHead_Phase.exe (32-bit)
  14. Beta Update 2.61 - http://oryaaaaa.worl...mperor_beta.zip * Phase / Reverse a phase-reversal signal output
  15. Релиз Bug head Emperor 2.60 - http://oryaaaaa.world.coocan.jp/bughead/index.html
  16. Bug head Emperor 2.57 beta 2 - http://oryaaaaa.world.coocan.jp/_userdata/bughead_emperor_beta.zip
  17. 2.56.Beta 2 http://yadi.sk/d/WqN4lV1tDuku6
  18. Bug head 2.51 Super Reverse (Self sound optimizer) - http://oryaaaaa.world.coocan.jp/_userdata/bughead_emperor_beta.zip
  19. 2.56 beta 6 - http://oryaaaaa.worl...mperor_beta.zip UP - пулемёт 2.56 beta 7 (64only, z Tune) 2,56 beta 8 Наверное скоро релиз.
  20. Уточните, какой ссылке? http://oryaaaaa.world.coocan.jp/_userdata/bughead_emperor_beta.zip - Это единственная ссылка на все свежайшие бета версии (т.е. самую крайнею)
  21. http://oryaaaaa.world.coocan.jp/_userdata/bughead_emperor_beta.zip
  22. 2.56 beta 3 - http://oryaaaaa.world.coocan.jp/_userdata/bughead_emperor_beta.zip
  23. @Gleb, Windows 8.1x64,память 16Гб, вывод через JPLAY (https://disk.yandex.ru/public/?hash=/G7xxQyKWli5wiiqoHrAjs1nTQLo62vkgb%2BBca14SHY%3D), хай-резы и винил рипы 24/96 и 24/192 играются без проблем. Ещё бы Вы спросили у Хироюки по поводу DSD файлов.
  24. Update 2.56 beta 2 * z Tune mode, size down alllocate memory http://oryaaaaa.world.coocan.jp/_userdata/bughead_emperor_beta.zip
  25. Beta Update 2.53 - http://oryaaaaa.world.coocan.jp/_userdata/bughead_emperor_beta.zip
