Весь контент Wladislav26
Iriver AK100 24/192 плеер
Да, я читал Далее он пишет, что это ему показалось и он еще раз перепроверит Не может там звук измениться Вчера вечером гонял туда-сюда 1.33 и патч. Хотел сегодня спросить всех по изменению громкости звука. Я уже думал, что глюки у меня - больше громкости и изменение средних частот Утром прочитал, что хеадфаеры намерили и изменения в самом деле есть: I just finished doing a quick test between a STOCK AK100 with 1.33 and STOCK AK100 with the Russian SW. Using a 16/44.1 WAV file of a 1kHz test tone (0dBm), setting the volume to max (75), EQ OFF, and measuring the RMS voltage at the output jack with NO load connected, I get: STOCK AK100 with 1.33 = 1.02 Vrms STOCK AK100 with the Russian SW = 1.52 Vrms. So we are looking at a approx. 3.5dB difference output between the two.... which can definitely be heard. I know that the "de-emphasis mode ON" takes away around 3dB of signal in the dac before the d/a conversion takes place - so it is possible that whoever came out with this patch also turned OFF de-emphasis in the software (as the WM8740 dac in the AK100 is ran in "software mode" - not "hardware mode"). I have a prototype modded RWAK100 with a WM8741 dac (dac configured in hardware mode and using a 'minimal phase' digital filter setting that has been hardware configured for the dac. Digital volume control is completely bypassed from the chain - so no digital attenuation used for the data. When I measure the output voltage of the same file above (in the same configuration) with SW 1.33, I get 1.8Vrms. When I load the Russian SW, I still get 1.8Vrms.... so running in HW mode and completely bypassing the digital volume control is proven to give true MAX line-out capability (I believe the 0.2Vrms difference to the datasheet's 2Vrms is because I was still using the headphone output stage, which will be bypassed. The headphone output stage is a voltage follower and topology and seems to drop about 0.2Vrms, but provides the current required to drive headphones). That's it for now... I hope this helps, Vinnie
Помогите сделать выбор Dac для W5000
Я не видел у нас Можете сами разместить объявление Если новый надо , то гуглом поищите. Тысяч за 28 можно найти
iRiver AK120 - уже есть!
серьёзно такая х.... ? Пока да... На плеере есть отзыв владельца из рф и фотки внутренностей Без слез читать невозможно про отваливающиеся кнопки и т. д. У нас тоже ветка есть, почитайте Но.... По разным отзывам играет лучше всех
Тогда сразу два - один на запчасти. И то через год, пока по доработают По отзывам 901 играет лучше всех
Ок
Я так понимаю, у ТС бюджет ограничен- для начала вполне хватит Кстати, отзыв о teac ты так и не написал еще. Думаю, первые эмоции прошли уже. Спокойно все послушал
Поддерживаю
Вы почитайте ветку teac У ваших наушником сопротивление 40 Ом. Встроенный усь их раскачивает легко Усилитель вполне достойный и играет прилично.
Вот тема про teac http://forum.doctorhead.ru/index.php?showtopic=22632 Почитайте Играет хорошо. Звук нейтрален. Как записано, так и играет Родной плеер играет DSD файлы расширения DFF и dsf Образы iso играются фубаром Я доволен
Зато exFat прикрутите ( как listrid доделает) безпроблемно
Кода вы плеер подключили к компьютеру, то у вас отображается 3 диска Надо просто " кинуть" файл" на встроенный диск (не на съемные микро сиди) Далее он на экране скажет, что появилось новое ПО и перезагрузится. Прошивка будет отображаться, как 1.33 Это не новая прошивка, это патч А изменения вы заметите по изменению интерфейса
Ну да Надо самому слушать Тут уж некуда деваться
Я тоже заказал Жду...
Спасибо! Вот теперь понятно Как говорили уже не раз, физику не обманешь, и, невозможно в спичечный коробок засунуть мощный усилитель Значит так и запишем( смайлик) " ак120 переигрывает dx100 c BD T5" Пока мало очень отзывов и сравнений Так что, еще раз спасибо
Да что-то я сомневаюсь Всю работу сразу переделают, тогда чем будут заниматься Что потом в новых обновлениях выкладывать? Можно чуть подождать отзывов тестировщиков с хеадфая, может какие косячки еще вылезут ( в чем я сильно сомневаюсь) Вот лучше бы они cue сделали
Это они фантазируют
Думаешь, что они сейчас быстренько обновят прогу на ак100 и придется exFat еще раз прикручивать?
Спасибо! Напишите еще пожалуйста сравнение в звучании при воспроизведения без внешнего усилителя Я так понял, что внутренний усь ак120 проигрывает dx100 и проигрывает значительно?
Ага listrid Еще раз - респект и уважуха
По вашей подписи я понял, что вы уже приобрели Конечно интересует сравнение с dx100
Нет пока ни у кого Вы по нему можете что-нибудь сказать?
Прикольно http://www.head-fi.org/t/630288/the-new-iriver-ak100-a-high-end-dap/5055 Ставят патч и позорят компанию iriver
COLORFLY COLORFUL C4
Чего? Нормально будет( смайлик) Блин, я вам сочуствую Уроды они, сцумки и резиново- тенические изделия... Поэтому и куча предложений о продаже... Но играет лучше всех до сих пор...
ibasso DX100: аудиоплеер на базе "лучшего в мире ЦАП"
Да ладно Не будем ссориться Вот Вы сейчас уже до заказа "созрели" Я же писал, что выбор у нас, что можно послушать из затычек, крайне мал... к сожалению Топ модели представлены крайне мало .Или вообще не представлены Делайте " снимки" (смайлик) и отправляйте Потом поделитесь впечатлениями
