FIRE PHOENIX DAC-02 - БЕЗДЕЛУШКА или BEST<100$ ???
http://www.спам.com/itm/FIRE-PHOENIX-DA ... 3012wt_732
Description
Using industry-recognized best decoder chip, the creative will be built in a small box inside the transformer, a unique anti-tampering measures, good circuit design, circuit board layout design excellent, good timber, small size makes this machine circumstances to achieve good listening results, ideal for desktop, room application.
Optical & Coaxial using CIRRUS LOGIC program, compatible with the current market of high-end digital audio, USB part is independent of external 24bit DAC USB receiver and decoder, when the connected computer using a USB DAC functions as a high-end sound card with external amp . Machine control part of the boot delay, no signal or failure automatically cut out. Volume sampling industry-recognized Japanese ALPS potentiometer control, the overall sound quality comparable to high-class CD
? Digital Receiver: CS8416 IC up 192K/24BIT SPI & I2S signal output (the max sampling frequency of using on this product is 96K/24BIT)
? USB digital receiver: CM102 , SPDIF signal output is adopted for this product.( CM102 part of the digital output , JITTER is superior than PCM chips)
? D / A converter: CS4398 dynamic response is 127dB with 24bit/192K sampling rate.
? Balance filter: LM4562, switching rate(S/R) is 20V/us
? Volume Control : Japan ALPS potentiometer
? Headphone amplifier: JRC4556 extremely low distortion, high-current, high slew rate of a professional amp IC.
? With built-in transformer mode, signal processing using ± 12V voltage regulator, digital processing part is separate +5 V power supply TL431 control to ensure maximum performance, stability and pristine sound quality. External power supply box than a lot of good.
? Frequency response: 20H -30KHz (0dBV OUT ± 0.5dB)
? Signal output (0dBV 1KHz/48KHz 16bit): THD + N <0.002%, the noise floor <105dBV, V> 2V (1FFS)
? SNR:> 110dB
? Channel separation:> 100dB
? Headphone output: MAX 14dBV (5V) THD + N <0.003% (1KHZ/50 ohm load & 2V)
? Input-digital input: COA, OPT and USB, each for a group. Note: the ports are gold palted.
? Multiple Sample rates: 32K-MAX192K/24BIT(for USB input: only support 16bit/44.1K and 48K)
Output
RCA(single end): It’s convenient for matching with universal audio equipments.
Headphone output: support 32-300Ohm impedance headphone.
Panel feature
volume adjustment.
Signal indication: LED
Headphone output
Weight: 0.7KG
Есть мнения?
дома = hifiman hm-602(16Gb+SD128Gb) => A-Th AD700 vs FA-003 махагони+литцрекабелинг(огромная благодарность Диме Губченко - Demograf)+neutrik) vs Sony MA-900
на улице = Samsung Wave S8500 => hifiman re-0 rev.№4+кабель nobody+neutrik
Было:
AKG K550
Audio-Technica SJ3
Pioneer SE A-1000
Sennheiser HD595
AKG K-701
Brainwavz M3
Creative X-Fi HD USB
Cowon iaudio7
Dr.Dac2
Musiland 02US
Alt Audio Element №1
НА САМОДЕЛКИНО ПОХОЖЕ ! ЦЕНА ХОРОШАЯ :)
наверняка вся внутренность сделана из клонов , а там качество :think: . да и с доставкой не понятки .
этих "BEST<100$" у китайцев просто дофига :stopit:
portable: jaybird x2, x3
