Новости (Усилители, наушники, цапы, кабели и прочее...)
ALO Audio The new PanAm portable headphone...
The new PanAm portable headphone amp combines a 24/96 Wolfson USB DAC with 1/8" and standard RCA inputs, 3.5/6.3mm headphone sockets and hi-lo gain switch whilst the optional external PassPort battery pack ensures 10 hours of anywhere listening. The tubes are offered as both Russian military and Siemens OEM upgrades. Frequency response is 40 - 30.000Hz ±1dB, max voltage swing is 22V, input impedance is 10K, max input level is 3.5V rms and channel tracking is better than ±0.2dB.
http://www.aloaudio.com/
Башкирия (Уфа) - [ Doctorhead Club ] - Народ с форума.
Сейчас:
CDp: Sony CDP-XA5ES; Sony PCM-D50
DAC: Demograf DAC (1540D & 1541A) (Upgrade - Valvo EL8)
AMP: WooAudio WA3+; Accuphase E-303x; NuForce uDAC 2SE
Cables: Accuphase AL-15, Klotz ADR-51; KLOTZ 13RA Reference Line; GRADO Extension Cable; Canare
Headphones: Beyerdynamic DT931, DT990 80', DT660 Mk II, DT911, DT801; Sony MDR-7509HD, DALI IO 4/6
Acoustics: Sansui SP-100i
Было:
CDp: Marantz CD94
DAC: Demograf DAC 1547 (+USB); Markan LegenDA Audio DAC Special Edition; Arkhipov's Laboratory DAC 56; W4S DAC-1; Энергетик ЦАП; NuForce uDAC 2
AMP: Lehmann Audio Black Cube Linear USB; Flux Lab HA-04 (mod)
USB: Audio-GD Digital Interface; Musiland Monitor 01 US
Cables: Audioquest Optolink-5; Oyaide Cox, USB
Headphones: Koss UR-40; Sennheiser HD 650; Grado RS-1i; Sennheiser HD 800; Beyerdynamic T1; Audio-Technica ATH- W5000; Beyerdynamic DT880
На прослушке:
В гостях у друзей:
  • Ответов 80
  • Просмотры 37k
Sennheiser HDVA 600
Sennheiser unveils HDVA 600 analog headphone amp, wallets tremble in fear
Along with a few IFA 2012 announcements, Sennheiser peeled back the wraps from its HDVA 600 headphone amp, an analog flavor of the previously unveiled HDVD 800. Like its sibling, the freshly revealed hardware sports a glass panel for peeking at its innards and an anodized aluminum exterior, but leaves the digital inputs behind. While the 800 carries a hefty $2,000 price tag, the 600 will set customers back a smaller -- but still substantial -- sum of $1,600. Both units are tailored for the likes of Senn's flagship HD 800 headphones, so they should easily be able to drive cans that require up to 300-ohms. The pair won't be available in the US until later this fall, but in the meantime, you can breeze past the break for specs and more details in the press release.
Сейчас:
Было:
CDp: Marantz CD94
На прослушке:
В гостях у друзей:
  • 1 month later...
Woo Audio WA7
The compact WA7 single-ended triode headphone amplifier from NY-based Woo Audio includes a 32/192 USB DAC and encases its valves in a thick slab of acrylic for another statement in miniature headfi chic.
http://www.wooaudio.com/
Сейчас:
Было:
CDp: Marantz CD94
На прослушке:
В гостях у друзей:
Abyss Headphones
With the runaway success of the Audeze LCD-2 and HifiMan planarmagnetic headphones, Joe Skubinski of JPS Labs must have decided to get into the act himself. His new company Abyss Headphones just introduced the Model AB-1266. This combines an aluminum exoskeleton with tuned woods and magnetically affixed lambskin ear pads, hookup cabling by JPS and diaphragms of the ultra-thin planar type.
http://www.abyss-headphones.com/
Сейчас:
Было:
CDp: Marantz CD94
На прослушке:
В гостях у друзей:
Studio Six
Ken Ball's ALO Audio bows their new flagship decidely non-portable headphone amp. The Studio Six has 3 inputs, can drive four headphones simultaneously and appears to run 6SN7s with valve regulation and stabilization. Until the teaser page gets expanded, we won't know more however...
http://www.studiosixamplifier.com/
Сейчас:
Было:
CDp: Marantz CD94
На прослушке:
В гостях у друзей:
Aqua La Voce/La Scala
Итальянский производитель высококачественных ЦАПов обрёл в России эксклюзивного дистрибьютора — им стала компания Concert Ltd.
Модель La Voce — модульный конвертор, работающий в чистом классе А и оснащённый асинхронным USB-интерфейсом, способным
принимать сигналы до 24 бит/192 кГц, а также коаксиальным (RCA или BNC), I2S PCM (RJ45) и оптическим входами. В качестве опции —
AES/EBU. Уникальной особенностью La Voce является возможность индивидуального выбора платы с разными чипами: Burr-Brown PCM1704,
Philips TDA1541A, Analog Devices AD1865 или Wolfson WM8740. Топовая модель La Scala имеет схожую коммутацию, но построена на четырёх
конверторах Burr-Brown PCM1704-K и оснащена выходным каскадом без обратной связи на лампах Telefunken ECC82. В обоих устройствах
используется эксклюзивная цепь DFD, которая исключает манипуляции в цифровом тракте (upsampling, oversampling, цифровые фильтры и т.д.),
способные пагубно сказаться на естественности звучания. Вся продукция изготавливается вручную в Италии.
http://www.salonav.com/arch/2012/11/012.htm
http://www.hi-fi.ru/news/dom/detail/915104
Цифра: PC+SOtM tX-USB exp+SOtM dX-USB HD; Oppo BDP-93 -> DAC: Demograf DAC CS4397(+Amanero USB)/TDA1547|EL8; LevZ DAC-S-015КВ -> AMP: Demograf AMP ML6+AL4; LevZ HA-S-033; Shoker AMP V3 -> Уши: ТДС-15 Snorry mod; ТДС-7 Snorry mod ("ХС"); Sennheiser HD 580 ("ХС" + литцендрат); AKG K712 Pro; Beyerdynamic DT 911 (экз-р Demograf'а) АС: Demograf Speakers 4А-32-2 У4 (speaker cable "ХС")
Есть еще разное, но редко используется))
Было:
Много чего))
"А теперь, ребята, надо обязательно дунуть! Потому что, если не дунуть, чуда не произойдет!" (А.Акопян)
