Весь контент AEinstein
Помогите подобрать ЦАП для Fostex TH900.
Ясно
А пол подметают?
А кроме развлечения, какие цели в этой ветке преследуются....? А что, ЦАП за такую цену еду не готовит?
Оглохшим от Битсов вполне может подойти..... Нуу
.....это ядовитейший саунд с 900. (с)2017 ужас. Яд продают.
И хорошие таблетки от головной боли..... ?
ясно
Ну... Он продается отдельно.
D/A CONVERTER DAC V800 This is what german " hifi & records " magazin No. 3/2010 found out: " The measurements showed world top class " " Put DAC V800 besides a good but not necessarily expensive CD drive and you will receive a combination as good as all the chromed, brushed and polished luxury players - or even better. " FEATURES: - 4 digital inputs switchable: - transformer balanced via XLR (AES 3/11), 24/192 - coaxial via Cinch (S/P-DIF, AES-3id), 24/192 - optical via TOS Link, 24/192 - optional USB-T 24/96 or USB-X 24/192 input - coaxial digital output - LED displays for Active Input and Lock - Mute switchable - resampling/upsampling with selectable modes: x1, x2, x4 and "BEST" - Delta-sigma DAC with outstanding 120 dB dynamic range and never before achieved -112 dB THD !! - perfect analog output stages to not affect this maximum dynamic and minimum THD-N - Analog output level adjustable in the digital domain - Additionally the max. analog level is internally adjustable in 5 steps - Analog outputs electronically balanced via XLR and unbalanced via Cinch - oversized toroidal transformer - extensive internal power conditioning Case and back panel are made of strong aluminium and are Nextel coated. The 8 mm frontpanel is milled, sand-blasted and black anodised. The labeling is laser engraved. DAC V800 Technical Data Technical Data DAC V800 4 digital inputs: - AES/EBU, XLR, transformer balanced according to AES-3, impedance 110 ohms - S/P-DIF, Cinch, unbalanced, according to IEC 958 / AES-3-id, impedance 75 ohms - TOS-Link according to EIAJ RC-5720 - USB 24 bit / 96 kHz Input sensitivity: < 200 mV Input data format: AES, S/P-DIF, 24 bit / 192 kHz Digital output: S/P-DIF, Cinch, unbalanced, according to IEC 958 / AES-3-id, impedance 75 ohms Sample rate: 28 ... 210 kHz (USB 44.1, 48, 96 kHz) Stopband rejection: > 100 dB Dynamic range: > 120 dB Freq. Range: 10 Hz ... 20 kHz (- 0,05 dB) 10 Hz ... 40 kHz (- 0,20 dB) THD: < -112 dB (@ -1 dBFs) max. Output level: (5 steps selectable) Balanced: +24 / +18 / +15 / +12 / +6 dB Unbalanced: +15 / +9 / +6 / +3 / -3 dB Variable Output: adjustable in the digital domain Analog outputs: 2 x XLR, electronically balanced 2 x Cinch, unbalanced Power supply: 230 / 115 V AC, 10 VA Dimensions: 170 x 49 x 225 mm (W x H x D) Case and Back: Nextel coated aluminium Front panel: 8mm aluminium, black anodized, lasered
Ну в Виолектрике прямо написано "DAC". На заборе тоже написано. Удивительно. Странно они сообщают своим покупателям о том, что это ЦАП. В мире вообще много всего странного, например, некоторые цапы, аккаунты. Ну если не ЦАП, то что?
Ну в Виолектрике прямо написано "DAC". На хэдфае рекомендовали их в качестве ЦАП.
значит -1 V800
Это ЦАП.
Violectric V800 подойдет?
Технически интересен, отзывы восторженные, но мало кто слушал. Рискованно такую штуку покупать, послушать-то негде... Действительно.
Действительно, пойду бумажный куплю. И усилитель уже есть....? Нет, планируется дальнейшая покупка. Не верю, что будет лучшим для фостексов. 569$
- Sennheiser HD820
К Asus тоже подходят. И к телефону даже, с переходничком. Wyred 4 Sound DAC 2, как вариант. Можно упомянутую выше надю. Метрум. AudioGD. Fostex HP-A8 не надо.На барахолке такие варианты есть интересные: North Star Design 192 Dac (с дискретным транзисторным выходным буфером) Schiit Audio Gungnir Holo Audio Spring интересный, кстати, хотя все-таки больше для классики. Если бюджет расширить немного, можно взять б/у Lynx Hilo. Atoll DAC 200 se очень хвалили одно время, но, если честно, мало о нем знаю. Если в приоритете метал, то можно на барахолке мультибиты Accuphase подловить, младшие Krell. Ну на Schiit Gungnir мне и без барахолки хватит. Поэтому как вариант его можно спокойно вписывать. Идеально вписывается в бюджет.Метрум как вариант очень подойдет.
Тогда - без вариантов - за 1200 надо Хьюго брать, слушать музыку и не париться на всяких форумах. Говорят, что он не подходит для металла
Теперь осталось понять, о чём же был первоначальный вопрос... О ЦАП, поэтому подходит только Муссет.
Посоветуйте наушники для PS4
Кстати. Надо попробовать подключить ЮСБ ЦАП к ПС4.
Битцы свободно подключал.
ЦАП от усилителя и комбайна отличаем, или пока всё едино...? Ааа...
- Sennheiser HD820
