Черная пятница 2026
помогите выбрать между ATH DWL5500 и MDR-DS7500
может есть предложения что то получше ,бюджет 20000р,base station h1 хороший вариант но дорого.
MDR-DS7500
Specifications
Type: Sealed dynamic type
Driver unit: 50mm
Frequency Response: 5-25,000 Hz
Impedance: 24 ?
Power: Built-in lithium ion battery
Battery life: 18 hours
Mass: About 325g
Processor / Transmitter: Controller DSSS
Effect Mode: OFF / Cinema / Game / Voice (Stereo)
Decoder: Dolby TrueHD, Dolby Digital Plus, Dolby Digital, Dolby Pro Logic IIx, DTS-HD Master Audio, DTS-HD High Resolution Audio, DTS 96/24, DTS-ES, DTS, DTS Neo: 6, MPEG-2 AAC, LPCM 2ch/5.1ch/7.1ch, Dolby Pro Logic IIz
Reach: Up to approximately 30m
Audio output: HDMI ? 1, ? 1 optical
Input terminal: HDMI ? 3, ? 1 rectangular light, stereo pin jack ? 1
Power: DC12V
Mass: About 480g
Dimensions: (width ? height ? depth). Approximately 252 ? 36 ? 159mm
Power: Sony 100-240V AC Adapter
ATH DWL5500
Transmitter
Decoder function: Dolby Digital / Dolby Digital EX / DTS / AAC / Dolby Pro Logic IIx
Virtual Surround function: Dolby Headphone
Modulation scheme: DSSS
Transmission frequency band: 2.4GHz band
Transmission Distance: Up to about 30m
Input: Optical digital input (optical plug hexagonal) system x 2, type LINE (RCA pin jack L / R) x 1 system
Output: Optical digital output (optical plug Rectangular) ?— 2 system
Power: DC5V (using the included AC adapter)
Dimensions: About H43 ?— W151 ?— D127mm
Mass: About 325g
Headphones
Type: Open air dynamic type
Driver: phi 53mm
Playback frequency characteristic: 5 - 35,000Hz
Power source: DC2.4V (x 2 AA-size nickel-metal hydride rechargeable battery accessories)
Continuous duty time: 10 hours
Weight: 370g
Изменено пользователем Cannon Fodder
ЦАП:es9018, xmos ,DSD,(AK4399 ,xmos, DSD)AK4399 dual mono ,xmos ,DSD),(TDA1541 Parallel balanced/unbalanced output).
Динамические головки:(Audio Nirvana Super 8 Neodymium(L Cao alnico matched 8 (Fostex FE 168EZ Sigma) Open Baffle).
Усилитель LME49830+K1530/J201 300W Mono Power Amplfier х2 Total harmonic distortion + noise (f = 1kHz) 0.0006
предуселитель:ALPS IR Remote Control Volume Kit
в пути:PCM63,AD1955, AD1853,two WM8741 mono
НС
