Debian + mpd + DSD
Коллеги, возможно кто-то сможет подсказать?
Сделал из старого ноута сервер mpd. Информация об ос:
[ 0.000000] Linux version 4.6.0-0.bpo.1-rt-686-pae (debian-kernel@lists.debian.org) (gcc version 4.9.2 (Debian 4.9.2-10) ) #1 SMP PREEMPT RT Debian 4.6.4-1~bpo8+1 (2016-08-11)
Вывод mpd --version:
Music Player Daemon 0.19.12
Copyright © 2003-2007 Warren Dukes <warren.dukes@gmail.com>
Copyright © 2008-2014 Max Kellermann <max@duempel.org>
This is free software; see the source for copying conditions. There is NO
warranty; not even MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Database plugins:
simple proxy upnp
Storage plugins:
local smbclient nfs
Neighbor plugins:
smbclient upnp
Decoders plugins:
[mad] mp3 mp2
[mpg123] mp3
[vorbis] ogg oga
[oggflac] ogg oga
[flac] flac
[opus] opus ogg oga
[sndfile] wav aiff aif au snd paf iff svx sf voc w64 pvf xi htk caf sd2
[audiofile] wav au aiff aif
[dsdiff] dff
[dsf] dsf
[faad] aac
[mpcdec] mpc
[wavpack] wv
[modplug] 669 amf ams dbm dfm dsm far it med mdl mod mtm mt2 okt s3m stm ult umx xm
[mikmod] amf dsm far gdm imf it med mod mtm s3m stm stx ult uni xm
[sidplay] sid mus str prg P00
[wildmidi] mid
[fluidsynth] mid
[adplug] amd d00 hsc laa rad raw sa2
[ffmpeg] 16sv 3g2 3gp 4xm 8svx aa3 aac ac3 afc aif aifc aiff al alaw amr anim apc ape asf atrac au aud avi avm2 avs bap bfi c93 cak cin cmv cpk daud dct divx dts dv dvd dxa eac3 film flac flc fli fll flx flv g726 gsm gxf iss m1v m2v m2t m2ts m4a m4b m4v mad mj2 mjpeg mjpg mka mkv mlp mm mmf mov mp+ mp1 mp2 mp3 mp4 mpc mpeg mpg mpga mpp mpu mve mvi mxf nc nsv nut nuv oga ogm ogv ogx oma ogg omg opus psp pva qcp qt r3d ra ram rl2 rm rmvb roq rpl rvc shn smk snd sol son spx str swf tgi tgq tgv thp ts tsp tta xa xvid uv uv2 vb vid vob voc vp6 vmd wav webm wma wmv wsaud wsvga wv wve
[gme] ay gbs gym hes kss nsf nsfe sap spc vgm vgz
[pcm]
Output plugins:
shout null fifo pipe alsa roar ao oss openal pulse jack httpd recorder
Encoder plugins:
null vorbis opus lame wave flac
Archive plugins:
[bz2] bz2
[zzip] zip
[iso] iso
Input plugins:
file alsa archive curl ffmpeg smbclient nfs mms cdio_paranoia
Playlist plugins:
extm3u m3u pls xspf asx rss soundcloud cue embcue
Protocols:
file:// http:// https:// mms:// mmsh:// mmst:// mmsu:// gopher:// rtp:// rtsp:// rtmp:// rtmpt:// rtmps:// smb:// nfs:// cdda:// alsa://
Проблема в том, что не воспроизводится DSD. Т.е. вроде как воспроизводится, ни на что ни ругается, ошибку не выдает, ползунок прогресса воспроизведения ползет, но звука нет.
В чем может быть засада?
mpd.conf прикрепил.
mpd_conf.txt
Изменено пользователем mebius
дом: Demograf DAC 1547/4397 > Demograf Amp EL8/6B4G > HD 800, Kennerton Odin
работа: Burson DA-160 > Burson HA-160 > ATH W1000X
то есть все играет кроме 1 формата?
а сам з-сервер какой?
Топчик на продажу
1. KOSS ESP-6
2. Beyerdynamic DT220 (аналог 150х)
3. Те самые Биги на 400-600 Ом
4. Тдс-5 с любым сопротивлением
5. Корпуса и запчасти винтаж
Секты: PRO/4 и Ovation
@Sam5248, Да, все остальное играет.
Не очень понял, что такое "з-сервер"?
@PA3BPAT, ЦАП умеет играть DSD, с винды через фубар играет. ЦАП Cirrus 4397, usb-приемник Amanero.
комп на котором установлен сервер mpd соединен по usb с цапом.
управляется все это дело по локальной сети с другого компа, на котором стоит клиент mpd (cantata).
@mebius,
Может частотка дискретизации великовата (у файла разумеется)
@End, По идее не должно. Тестировал на записи t=5212641, DSD64, по даташиту поддерживается.
В винде через фубар играет.
