Sony MDR-10RBT
  • Driver Unit:40 mm, dome type (CCAW adopted) diaphragm
  • Frequency Response:Effective range via Bluetooth/NFC mode: 20 - 20,000 Hz
    Effective range via wired/passive mode: 4 - 40,000 Hz
  • Noise Level:ON/OFF switch on ear-cup
  • Power Handling Capacity:1000 mW
  • Selectivity:One-touch Listening with NFC
    Manual Bluetoothpairing
  • Sensitivity (db):100 dB/mW (Passive use)
  • Volume Control:Yes
  • Case Type:Carrying Pouch
  • Design:Circum Aural, Bluetooth Wireless
  • Headband:Metallic Band
  • Magnet:High-energy Neodymium
  • Plug:One L-shaped mini plug supplied: Gold-plated, stereo
  • Type of Use:Portable and Home
  • Cord:One single-sided, tangle-free cord: Stereo, detachable
  • Headphone Type:Closed supra-aural, Dynamic
  • Microphone:Omni directional, electret condenser (100 - 4 kHz frequency range
    -40 dB (0 dB = 1 V/Pa)
  • Remote Control:Via AVRCP: Play, Stop, Pause, FF, FR
  • Battery Charging (Approx):Appox. 2.5 hours from empty to full
  • Battery Indicator:LED (Red/Blue)
  • Battery Life (Approx):Up to 17 hours continuous music playback or communication time, up to 450 hours standby time (approx.)1
  • Battery Type:Built-in Lithium ion rechargeable battery
  • Power Source:DC 3.6 V Built-in Lithium-Ion rechargeable battery
  • Impedance:40 ohms at 1 kHz (Passive mode)
  • Sound Enhancer:SBC, AAC, and Apt-X codec support
  • Cord Length (Approx.):Stereo Connecting Cable-47 1/4 in. (1.2 m)
  • Weight (Approx.):Approx. 7.41 oz. (210 g) - included rechargeable battery
  • Bluetooth Technology:Bluetooth specification Version 3.01
    2.4 GHz band (2.4000 GHz-2.4835 GHz
    FHSS
  • NFC:One-touch Listening with NFC (Near Field Communications)
  • Network Transport Protocol:A2DP (Sampling frequency 44.1 kHz)
    Transmission Range: 20-20,000 Hz
    Line of sight approx.30 ft (10 m)
Имею сею интересную универсальную гарнитурку
Уже полгода юзаю.
Вот сейчас читаю инструкцию и там написано.
Смотрим чёрную книжечку-вкладку
Раздел - Прослушивание музыки - Bluetooth
Примечание
Перед отгрузкой изделия настроено стандартноек качество звука (режим высокого качества SBC).
При подключении устройства Bluetooth, поддерживающего AAC или aptX, можно изменить настройку как описано в справочном руководстве - это позволит прослушивать музыку в более высоком качестве.
Что это за AAC или aptX
И как это самое изменить качество и где, в ни какой инструкции и в никаком вкладише это не описано.
И ещё один вопрос
Как их правильно разбирать, может кто то уже подобные разбирал?
Просто не вижу в них зацепок как это сделать не повредив.
Какие то хитрые они.
Всяких наразбирался не ради разобрать.
Изменено пользователем m.ix
Ремонтирую всё, что работает на и от электричества.
  • 2 months later...
Ни кто их не юзал под Vistoй семёрой восьмёрой или иной виндой?
В хрюнделе ни как они не видны под устротройствами.
Хотя как видно из выше приложенного скрина они наблюдаются.
  • 4 weeks later...
Дома
Кино/музыка Multi-channel: NAS Synology DS-214 Play/HTPC => Onkyo TX-NR579 => Canton Movie 1050 5.1
Музыка стерео (громко): NAS Synology DS-214Play => AudioPC (Work in progress) => Foobar2000/Aplayer => Echo AudioFire 2 => РГ Никитина на бистабильных реле => Genelec 6010B + Genelec 5040
Музыка стерео (тихо): NAS Synology DS-214Play => AudioPC (Work in progress) => Foobar2000/Aplayer => будет что-то типа PPA V2 => M2Tech HiFace DAC / iFi Nano iDSD => Laconic HA-04AF => AKG Q701/AKG K501 Litz Mod/Audio-Technica ATH-A700/Philips Fidelio X2/Sony MDR-7506.
С собой: Notebook (foobar)/Xperia Z5 Compact (USB OTG + UAPP) => iFi Nano iDSD => Etymotic ER-4P Customs
Для некритичного прослушивания "на ходу" - Xperia Z5 Compact (Neutron Player) => Samsung Level Link (AptX) => Etymotic ER-4P Customs
Редко и для души: Audio-Technica ATH-EW9, Sennheiser PX-100
У девочки: Samsing A5 -> Sony SBH-20 -> Klipsch X7i Customs, Sony MDR-10RBT
Чтото service manual не заметил
так же пытался найти в басурманском слово windows
Про разборку не скажу, я имел ввиду ответы на вопросы что такое AAC/AptX, как включить и тп.
А что конкретно вы хотите от них получить при сопряжении с компьютером? BT-гарнитуру для VoiP/Skype или просто музыку послушать?
Что за компьютер у вас? Как подключаете?
Это читали: http://smallbusiness.chron.com/make-bluetooth-headset-work-windows-xp-44804.html
Дома
Для разобрать - посмотреть как правильно не навредив сменить в будущем аккумулятор.
Комп обычный простой стационарный.
Гарнитура всего раз по USB как то видится и всё.
Думал может как звуковая карта будет работать - как гарнитура по скайпу и вообще как звуковое устройство.
Недавно нашёл какую то USB гарнитуру, думал работает только для скайпа, оказалось поковыряться в настройках и будет как целая звуковая карта.
Вот и эту 10 хотел на авось как гарнитуру использовать.
Для гарнитуры есть мелкий дэвайсик (RD-45008), звук через него просто отвратный, это ещё мягко сказано.
http://market.yandex.ru/product/11633714/reviews?hid=723087&track=tabs
Это мой отзыв
По USB эта гарнитура не работает и работать не будет. Через USB ее можно только заряжать и (теоретически) менять прошивку.
Bluetooth-адаптеры за 3 копейки и работают на 3 копейки. Купите нормальный на бродкомовском чипсете, и поставьте бродкомовские же дрова c нормальным стэком, а не плоды воспаленного китайского воображения. http://www.asus.com/...uetooth_Dongle/ - хороший, проверенный вариант.
Про разобрать не подскажу, подобным вандализмом не увлекаюсь. Мне кажется, что будущее, когда умрет ваш аккумулятор, настанет так не скоро, что уже BT перестанет быть актуальным :)
PS Дрова хорошие - тут http://www.broadcom.com/support/bluetooth/update.php
Изменено пользователем SV_huMMer
Дома
Думал, что нужен специфический соневский софт, для работы через USB если она видится в системе должным образом, по крайней мере она хоть как то определяется.
блютуз покупал не только для звука
есть ещё TBW-104UB
Мне приходится подобные дэвайсы иногда ремонтировать.
У всех какие то где то винтики спрятаны, а у этого не понятно, где и что.
Специфический софт наверное нужен для обновления прошивок. Для ремонта - да, нужен сервисный мануал. Не знаю, где взять...
Дома
  • 1 year later...
Катаясь на самокате и объезжая одного перехожего, задел своими ушами ветку шшницеля или ёлки, в опщем упали эти палки, точнее уши и расколотились.
К счастью не совсем, всё там на защёлках и винтиках.
А вот амбюшуры изрядно поизносились как и акк, уже время работы стало треть от заявленной, то есть не 22 часа как ранее отработали а уже 5-6 часов максимум.
Амбюшуры зашиваю аккуратно нитками.
Рвутся по внутреннему шву.
