iow 1 809 1 Тракты Опубликовано 30 мая, 2015 (изменено) Aune S18 поступил не так давно в открытую продажу, в том числе на крупнейшем интернет-аукционе по цене $500 с бесплатной международной доставкой. Увы и ах, но фотографий внутренностей железочки сходу найти не смог, так что любимую форумную игру (лечение по фотографии) придётся отложить. Может, в процессе появятся владельцы, как знать? Никто не хочет заказать? Aune S18 32BIT DSD Music Player Asynchronous (CPLD) Dual clock Fidelity Digital Turntable High-quality multi-format mastering-digital turntablePure hardware solution asynchronous clock technology, the use of data reorganization algorithm for audioS18 has the very end of the digital jitter and perfect digital waveform, while near the top in particular the use of analog tuning dial, is a turntable that can besubstitute for high-quality digital CD turntable S18 is an Hi-Fi turntable with the music that alternative to traditional CD turntable S18 is a mastering-HIFI dial multiple audio formatsS18 is an included CD disc formats, but support more digital HIFI turntable mastering formatS18 supports WAV / FLAC / APE / AAC / DSD and other multi-format S18 is a HIFI turntable that support 32BIT and DSD highest formatsS18 can play up to 32BIT music files, and supports DSD file format DSF / DFF / ISO playback, support coaxial output DOP (DSD digital format) S18 uses a purely digital technology hardware solutionS18 uses an ARM chip and a CPLD chips machine hardware frameworkARM is a pure hardware decoding codes, ARM asynchronous clock signal input CPLD chip technology reforming, Asynchronous clock technology allowshardware solution with a high numerical targets S18 S18 uses two ultra-low jitter clock crystalVerification of the entire digital circuit is a clock crystal, S18 using two ultra-low jitter clock crystal clock and asynchronous technology with completely beyond the traditional CD turntable S18 with numerous digital output interfaceS18 with a group of RCA, a group of BNC, a balanced set of numbers, a set of digital optical interface S18 with full balanced output interfaces IISS18 uses ultra high-speed full balance IIS output , the most high-speed transmission of HDMI interface, support for long-distance transmission, with higher speeds and longer distances than other IIS turntable S18 uses 2.8-inch display and full remote control technologyS18 with a full perspective of the large 2.8 display and minimalist UI design, completely empty external remote control technology, is a very good man-machine interface of digital turntable, the machine includes a traditional analog dial operations, with more featuresS18 has excellent indicators and excellent sound calibrationwhen playing 24BIT / 192K signal , the digital output jitter is 3.4NS, THD + N-138DB, reached the limit index S18 supports more comprehensive formats ,support the DSD format and DOP outputS18 supports up to file playback 32BIT / 96, while supporting DSD 64 of DOP coaxial output, with a balance transfer IIS port provides two-way coaxial output interface (RCA + BNC), is a multi- interface multi-format digital turntable Note:32BIT coaxial can not be transferred because the coaxial agreement can not be reached so high, only IIS transmission, DSD can play in the coaxial port transmission, but it needs the DAC that support DOP interface Front Panel View1.1 2.8 Display1.2 Power indicator1.3 remote control receiver window1.4 Power Button1.5 Main Menu button1.6 on the button, the playback mode, previous / rewindWhen the file browser mode, select the previous1.7 keystrokes, playback mode, Next / Fast ForwardWhen the file browser mode, select the next1.8 Enter / Play / PauseWhen play mode, play / pause, file browsing mode, it is determined1.9 SD card connector Rear Panel View2.1 IIS outlet2.2AES digital output2.3 coaxial output2.4 optical output2.5 backup WAN port (can not be used now)2.6 AC inputSpecial Note:Press 2 seconds for a long time, turn on the power; press two seconds for a long time,turn off the powerWhen the play mode, enter the main menu, to return to the previous menu Изменено 31 мая, 2015 пользователем iow Oppo bdp-103 / BBP-200 -> Berkeley Audio Design Alpha DAC -> ? -> Fostex TH900, Beyerdynamic DT 911 (EDT 990 VB) / Focal Solo6 Be [в продаже] Было (неделя+): Наушники: Sennheiser HD 555, German Maestro GMP 400, Beyerdynamic DT 990 (1980's edition), Beyerdynamic DT 880 (1980's edition), Sennheiser HD800 s/n 4k, Sennheiser HD800 s/n 12k, Audez'e LCD-2, Sony MDR-CD3000, AKG K812, ТДС-15 Snorry Mod, HiFiMAN HE6, Beyerdynamic DT 660 MK II (EDT 770 V), AKG K1000ЦАПы, комбайны: Audio-GD NFB-5, MS Audio Laboratory DAC 1.0, M2Tech Young, Wadia 121, Hegel HD20, LevZ DAC-S-015f, Metrum Octave DAC MKI, Demograf DAC 4397, Mytek Stereo192-DSD DAC, dCS Debussy, Demograf DAC 1541Усилители: Laconic Night Blues NB-3A (с трансами sowter), SPL Phonitor, Lynx Audio HA61, Energy Audio Beta22, Demograf AMP (ECL82), AMB Beta22 [4-board balanced + 2xSigma22] by HeliumИсточники цифры: E-mu 0404 PCI, Musiland Monitor 01 USD, E-mu 1212m PCI, M2Tech hiFace RCA, RME HDSP 9632, Lynx AES16 PCI, QLS QA-660, SOtM dX-USB HD Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
Pavel.Al 246 2 Тракты Опубликовано 31 мая, 2015 Внутренности на китайской барахолке есть. Сделано внешне (внутренности) очень не плохо. Тоже интересно что получилось. Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
Александр Карелин 3 720 Опубликовано 31 мая, 2015 (изменено) пофотке не сказал-бы что питание сделано по аудиофильски... ну а звук в таких транспортах во многом зависит от софта , а не от железа Изменено 31 мая, 2015 пользователем Александр Карелин "...сочинение магистра Алькофрибаса, извлекателя квинтэссенции " Наушники: Beyerdynamic T1 2nd Generation, Sony MDR-Z1R, Audio-Technica ATH-CKR9Ltd, кастомные Westone ES60 Усилители: только собственного производства транзисторные и ламповые "Ратша" Плеер: Luxury & Precision L3 Pro (!balanced output!) наушники Audio-Technica: ATH-W5000, ATH-ESW9, ES10(было), A2000x(было), W5000, R70x (было), CK100Pro(было), CKR9LTD, IM04(было), кастомные Westone ES60, Sony MDR-Z1R усилители: Sovereign Reference, Sovereign Baby Reference, Ратша плеер: Teclast T51, HiFiMan HM-801 (было), Pono Player SE(было), Aune M2 Pro (было), Cayin i5 (было) телега Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
Alecs102 28 Опубликовано 31 мая, 2015 CD флешка на 32 гб может 400 ма кушать в импульсе, емкости около картридера небольшие, да и около Spdf выхода тоже один кондесатор, радует что стоит тантал.Однако звучание может зависеть от многих слагаемых. Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
PathologSPb 107 Опубликовано 31 мая, 2015 Название получается не совсем верное - это именно твердотельный транспорт, а не плейер. Интересен был бы в связке с тем же аюновским S16. Порт.источники iBasso DX100 SLmod, iBasso DX90 SLmod, MA-9 Balanced (SL Mod), QLS-QA360, Astell&Kern AK100. Наушники порт. Dunu-2000, Fostex TH900, HiFiMAN RE-600, ATH-CK90Pro, Yuin G1/G2A , Yuin PK1. Стац.источники Aune S1, Fostex НР-А8, BBP 101 Plus. ЦАП- Audio Alchemy 3.0. Усилители Luxman P-1, HiFiMan EF-6, Stax SRM-727А. Наушники стац. HiFiMan HE-6, Stax 007 Omega II, Audeze LCD-3, LCD-ХС, Sennheiser HD-800. Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
iow 1 809 1 Тракты Опубликовано 31 мая, 2015 Название получается не совсем верное - это именно твердотельный транспорт, а не плейер. Интересен был бы в связке с тем же аюновским S16.Исправил. Меня скорее интересует, лучше ли он по сравнению с bbp-200 - этот я совсем не слушаю, уж больно он китайский в плане удобства. Пока мне с транспортами не везёт. Можно, конечно, взять не глядя, благо s18 относительно небольших денег стоит, но неудачный опыт с qls меня останавливает. Oppo bdp-103 / BBP-200 -> Berkeley Audio Design Alpha DAC -> ? -> Fostex TH900, Beyerdynamic DT 911 (EDT 990 VB) / Focal Solo6 Be [в продаже] Было (неделя+): Наушники: Sennheiser HD 555, German Maestro GMP 400, Beyerdynamic DT 990 (1980's edition), Beyerdynamic DT 880 (1980's edition), Sennheiser HD800 s/n 4k, Sennheiser HD800 s/n 12k, Audez'e LCD-2, Sony MDR-CD3000, AKG K812, ТДС-15 Snorry Mod, HiFiMAN HE6, Beyerdynamic DT 660 MK II (EDT 770 V), AKG K1000ЦАПы, комбайны: Audio-GD NFB-5, MS Audio Laboratory DAC 1.0, M2Tech Young, Wadia 121, Hegel HD20, LevZ DAC-S-015f, Metrum Octave DAC MKI, Demograf DAC 4397, Mytek Stereo192-DSD DAC, dCS Debussy, Demograf DAC 1541Усилители: Laconic Night Blues NB-3A (с трансами sowter), SPL Phonitor, Lynx Audio HA61, Energy Audio Beta22, Demograf AMP (ECL82), AMB Beta22 [4-board balanced + 2xSigma22] by HeliumИсточники цифры: E-mu 0404 PCI, Musiland Monitor 01 USD, E-mu 1212m PCI, M2Tech hiFace RCA, RME HDSP 9632, Lynx AES16 PCI, QLS QA-660, SOtM dX-USB HD Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
SV_huMMer 571 6 Тракты Опубликовано 3 июня, 2015 @iow, а вы продукцию Raumfeld не рассматривали? У меня весьма положительный опыт. ДомаКино/музыка Multi-channel: NAS Synology DS-214 Play/HTPC => Onkyo TX-NR579 => Canton Movie 1050 5.1 Музыка стерео (громко): NAS Synology DS-214Play => AudioPC (Work in progress) => Foobar2000/Aplayer => Echo AudioFire 2 => РГ Никитина на бистабильных реле => Genelec 6010B + Genelec 5040 Музыка стерео (тихо): NAS Synology DS-214Play => AudioPC (Work in progress) => Foobar2000/Aplayer => будет что-то типа PPA V2 => M2Tech HiFace DAC / iFi Nano iDSD => Laconic HA-04AF => AKG Q701/AKG K501 Litz Mod/Audio-Technica ATH-A700/Philips Fidelio X2/Sony MDR-7506. С собой: Notebook (foobar)/Xperia Z5 Compact (USB OTG + UAPP) => iFi Nano iDSD => Etymotic ER-4P Customs Для некритичного прослушивания "на ходу" - Xperia Z5 Compact (Neutron Player) => Samsung Level Link (AptX) => Etymotic ER-4P Customs Редко и для души: Audio-Technica ATH-EW9, Sennheiser PX-100У девочки: Samsing A5 -> Sony SBH-20 -> Klipsch X7i Customs, Sony MDR-10RBT Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
iow 1 809 1 Тракты Опубликовано 4 июня, 2015 @SV_huMMer, я не знаю, что это такое. Oppo bdp-103 / BBP-200 -> Berkeley Audio Design Alpha DAC -> ? -> Fostex TH900, Beyerdynamic DT 911 (EDT 990 VB) / Focal Solo6 Be [в продаже] Было (неделя+): Наушники: Sennheiser HD 555, German Maestro GMP 400, Beyerdynamic DT 990 (1980's edition), Beyerdynamic DT 880 (1980's edition), Sennheiser HD800 s/n 4k, Sennheiser HD800 s/n 12k, Audez'e LCD-2, Sony MDR-CD3000, AKG K812, ТДС-15 Snorry Mod, HiFiMAN HE6, Beyerdynamic DT 660 MK II (EDT 770 V), AKG K1000ЦАПы, комбайны: Audio-GD NFB-5, MS Audio Laboratory DAC 1.0, M2Tech Young, Wadia 121, Hegel HD20, LevZ DAC-S-015f, Metrum Octave DAC MKI, Demograf DAC 4397, Mytek Stereo192-DSD DAC, dCS Debussy, Demograf DAC 1541Усилители: Laconic Night Blues NB-3A (с трансами sowter), SPL Phonitor, Lynx Audio HA61, Energy Audio Beta22, Demograf AMP (ECL82), AMB Beta22 [4-board balanced + 2xSigma22] by HeliumИсточники цифры: E-mu 0404 PCI, Musiland Monitor 01 USD, E-mu 1212m PCI, M2Tech hiFace RCA, RME HDSP 9632, Lynx AES16 PCI, QLS QA-660, SOtM dX-USB HD Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
SV_huMMer 571 6 Тракты Опубликовано 5 июня, 2015 (изменено) @iow, https://www.raumfeld.com/ У меня имеется Connector, за свои 200 евро - весьма и весьма заслуживающий внимания вариант. Изменено 5 июня, 2015 пользователем SV_huMMer ДомаКино/музыка Multi-channel: NAS Synology DS-214 Play/HTPC => Onkyo TX-NR579 => Canton Movie 1050 5.1 Музыка стерео (громко): NAS Synology DS-214Play => AudioPC (Work in progress) => Foobar2000/Aplayer => Echo AudioFire 2 => РГ Никитина на бистабильных реле => Genelec 6010B + Genelec 5040 Музыка стерео (тихо): NAS Synology DS-214Play => AudioPC (Work in progress) => Foobar2000/Aplayer => будет что-то типа PPA V2 => M2Tech HiFace DAC / iFi Nano iDSD => Laconic HA-04AF => AKG Q701/AKG K501 Litz Mod/Audio-Technica ATH-A700/Philips Fidelio X2/Sony MDR-7506. С собой: Notebook (foobar)/Xperia Z5 Compact (USB OTG + UAPP) => iFi Nano iDSD => Etymotic ER-4P Customs Для некритичного прослушивания "на ходу" - Xperia Z5 Compact (Neutron Player) => Samsung Level Link (AptX) => Etymotic ER-4P Customs Редко и для души: Audio-Technica ATH-EW9, Sennheiser PX-100У девочки: Samsing A5 -> Sony SBH-20 -> Klipsch X7i Customs, Sony MDR-10RBT Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
iow 1 809 1 Тракты Опубликовано 5 июня, 2015 @iow, https://www.raumfeld.com/ У меня имеется Connector, за свои 200 евро - весьма и весьма заслуживающий внимания вариант.Это концептуально иное устройство. Мне нужен твердотельник без wi-fi. Имеющийся под рукой oppo bdp-103 играет музыку как по сети, так и с флешки, но по качеству уступает тому же bbp-200. Oppo bdp-103 / BBP-200 -> Berkeley Audio Design Alpha DAC -> ? -> Fostex TH900, Beyerdynamic DT 911 (EDT 990 VB) / Focal Solo6 Be [в продаже] Было (неделя+): Наушники: Sennheiser HD 555, German Maestro GMP 400, Beyerdynamic DT 990 (1980's edition), Beyerdynamic DT 880 (1980's edition), Sennheiser HD800 s/n 4k, Sennheiser HD800 s/n 12k, Audez'e LCD-2, Sony MDR-CD3000, AKG K812, ТДС-15 Snorry Mod, HiFiMAN HE6, Beyerdynamic DT 660 MK II (EDT 770 V), AKG K1000ЦАПы, комбайны: Audio-GD NFB-5, MS Audio Laboratory DAC 1.0, M2Tech Young, Wadia 121, Hegel HD20, LevZ DAC-S-015f, Metrum Octave DAC MKI, Demograf DAC 4397, Mytek Stereo192-DSD DAC, dCS Debussy, Demograf DAC 1541Усилители: Laconic Night Blues NB-3A (с трансами sowter), SPL Phonitor, Lynx Audio HA61, Energy Audio Beta22, Demograf AMP (ECL82), AMB Beta22 [4-board balanced + 2xSigma22] by HeliumИсточники цифры: E-mu 0404 PCI, Musiland Monitor 01 USD, E-mu 1212m PCI, M2Tech hiFace RCA, RME HDSP 9632, Lynx AES16 PCI, QLS QA-660, SOtM dX-USB HD Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
derbanner 602 Опубликовано 5 июня, 2015 @iow,так может не размениваться на китайцев, а сразу посмотреть что-то вроде bryston bdp-1/2, если важно именно такое устройство?хотя они стоят конечно прилично я с 101 bbp так и не нашел общего языка - продал.qls550 конечно менее удобен, но такого количества глюков не было. Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
SV_huMMer 571 6 Тракты Опубликовано 5 июня, 2015 Мне нужен твердотельник без wi-fi. Сорри, видимо не понял. Хотя его можно превратить в "твердотельник без Wifi", в том смысле что контент можно воспроизводить с USB-флэшки, а не с сети. Но управление все равно только с телефона/планшета по Wifi. К тому же, по SPDIF он может отдать до 24/192 на любой ЦАП из домашней коллекции. Но по звуку - да, звезд с неба он не хватает. ДомаКино/музыка Multi-channel: NAS Synology DS-214 Play/HTPC => Onkyo TX-NR579 => Canton Movie 1050 5.1 Музыка стерео (громко): NAS Synology DS-214Play => AudioPC (Work in progress) => Foobar2000/Aplayer => Echo AudioFire 2 => РГ Никитина на бистабильных реле => Genelec 6010B + Genelec 5040 Музыка стерео (тихо): NAS Synology DS-214Play => AudioPC (Work in progress) => Foobar2000/Aplayer => будет что-то типа PPA V2 => M2Tech HiFace DAC / iFi Nano iDSD => Laconic HA-04AF => AKG Q701/AKG K501 Litz Mod/Audio-Technica ATH-A700/Philips Fidelio X2/Sony MDR-7506. С собой: Notebook (foobar)/Xperia Z5 Compact (USB OTG + UAPP) => iFi Nano iDSD => Etymotic ER-4P Customs Для некритичного прослушивания "на ходу" - Xperia Z5 Compact (Neutron Player) => Samsung Level Link (AptX) => Etymotic ER-4P Customs Редко и для души: Audio-Technica ATH-EW9, Sennheiser PX-100У девочки: Samsing A5 -> Sony SBH-20 -> Klipsch X7i Customs, Sony MDR-10RBT Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
iow 1 809 1 Тракты Опубликовано 5 июня, 2015 @iow,так может не размениваться на китайцев, а сразу посмотреть что-то вроде bryston bdp-1/2, если важно именно такое устройство?хотя они стоят конечно прилично Не уверен, что он лучше, но знаю, что намного дороже. Посмотреть-то всегда можно, а вот купить - это уже совсем другое дело. http://htpc.jp/hires/index.html Молочный брат?На рынке предостаточно похожих устройств. Просто c aune я уже сталкивался, а тут они выпустили концептуально близкий мне вариант транспорта. Oppo bdp-103 / BBP-200 -> Berkeley Audio Design Alpha DAC -> ? -> Fostex TH900, Beyerdynamic DT 911 (EDT 990 VB) / Focal Solo6 Be [в продаже] Было (неделя+): Наушники: Sennheiser HD 555, German Maestro GMP 400, Beyerdynamic DT 990 (1980's edition), Beyerdynamic DT 880 (1980's edition), Sennheiser HD800 s/n 4k, Sennheiser HD800 s/n 12k, Audez'e LCD-2, Sony MDR-CD3000, AKG K812, ТДС-15 Snorry Mod, HiFiMAN HE6, Beyerdynamic DT 660 MK II (EDT 770 V), AKG K1000ЦАПы, комбайны: Audio-GD NFB-5, MS Audio Laboratory DAC 1.0, M2Tech Young, Wadia 121, Hegel HD20, LevZ DAC-S-015f, Metrum Octave DAC MKI, Demograf DAC 4397, Mytek Stereo192-DSD DAC, dCS Debussy, Demograf DAC 1541Усилители: Laconic Night Blues NB-3A (с трансами sowter), SPL Phonitor, Lynx Audio HA61, Energy Audio Beta22, Demograf AMP (ECL82), AMB Beta22 [4-board balanced + 2xSigma22] by HeliumИсточники цифры: E-mu 0404 PCI, Musiland Monitor 01 USD, E-mu 1212m PCI, M2Tech hiFace RCA, RME HDSP 9632, Lynx AES16 PCI, QLS QA-660, SOtM dX-USB HD Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
Records 805 Опубликовано 28 июня, 2015 Он только с SD флешки музыку играет, т.е. жёсткий диск к нему не подключишь? Я вам покажу, где Shigaraki зимуют!!!11 Essence ST (coax) -> Muse TDA1543x4 -> Objective2 -> DT990Vtg, AKG K612 Болтун - находка для шпиона, а бестолковый и наивный гуманитарий - находка для местных барыг дом: Muse TDA1543x4 -> Behringer B2030A Truth Trio KP-7070 (Empire 880P, Pioneer PC-330, AT140e) -> SanderZ -> Lehmann BCL (клон) -> Баеры, AKG вне дома: Fiio X5 II -> Zero Audio ZH-DX200 Carbo Tenore, TDK IE800 upgrade было: Hidizs AP100, IHiFi-960PRO, FiiO X3-II, Sony NWZ E-583, Sony NWZ-A15, ATH IM02, ATH M-50, ATH AD900X, ATH AD2000X, Fostex T50RP mod, FA Dubliz (ДНО), HiFiMAN RE-400, DUNU DN-2000J, DT770 PRO 32 LE, JVC HA-FXZ100, ODAC XL Rev.B, Brainwavz HM5, Flare audio R2Pro (best of the best) Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
RuAlex 9 647 Опубликовано 1 июля, 2015 Имеющийся под рукой oppo bdp-103 играет музыку как по сети, так и с флешки, но по качеству уступает тому же bbp-200.В чем 103 хуже? Вопрос не праздный - нахожусь в процессе поиска нового транспорта, и было намерение взять 103. Продаю (цена договорная) Усилители для наушников:LehmannAudio Rhinelander (новый в упаковке) Burson HA-160 (редкий - первого выпуска)(https://market.yande...90554&nid=56162) Наушники: PHILIPS X1 (новые, полный комплект) Mb Quart QP400 (Made in W.Germany) и др. )) ЦАПы:Cambridge Audio dacMagic plus (идеальное состояние, полный комплект)Линейный блок питания для Cambridge Audio dacmagic plus(заказной) SMSL M8 (новый, полный комплект)(https://doctorhead.r...description=yes) Да вообще все распродам... Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
PXC 450 410 Опубликовано 1 июля, 2015 В целом, интересное устройство. Характеристики, на первый взгляд, впечатляют. Даже I2S выход есть.Однако, как и на примере того же Auralic Aries (тоже китаец), слабо верится в чудо. Aries сравнивают по качеству звука с MacMini. В лучшем случае и этот транспорт будет играть на уровне MacMini. Т. е. потенциал ЦАПа уровня Berkeley этот транспорт не раскроет. Источник и пред: Linn Klimax DSM, АС: Linn Klimax 320A, Саб: Linn Klimax 345, Кабели: Bertram Cuprio Flow. Питание: PS Audio P3, Isotek Evo3 Aquarius. Виброизоляция: Finite Elemente Cerapuc, Symposium Rollerblock Series 2+ (G3) Double Stack, Jr. HDSE. Акустическая обработка: Vicoustic Wavewood + Wavewood Basstrap.Было: Luxman P-1u, Sennheiser HD800, Luxman P-200, Linn Majik CD, Audio-Technica ATH-W5000, Schiit Lyr, Sennheiser PXC450 Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
PathologSPb 107 Опубликовано 1 июля, 2015 (изменено) Aune S1, к примеру, играет (в том числе, и как твердотельный транспорт) несравнимо лучше, чем MacMini. Так что как минимум S18 должен быть не хуже S1, поскольку это транспорт, а не плейер. Так что если нужен именно транспорт - попробовать стоит, да и цена вопроса вполне приемлема. Изменено 1 июля, 2015 пользователем PathologSPb Порт.источники iBasso DX100 SLmod, iBasso DX90 SLmod, MA-9 Balanced (SL Mod), QLS-QA360, Astell&Kern AK100. Наушники порт. Dunu-2000, Fostex TH900, HiFiMAN RE-600, ATH-CK90Pro, Yuin G1/G2A , Yuin PK1. Стац.источники Aune S1, Fostex НР-А8, BBP 101 Plus. ЦАП- Audio Alchemy 3.0. Усилители Luxman P-1, HiFiMan EF-6, Stax SRM-727А. Наушники стац. HiFiMan HE-6, Stax 007 Omega II, Audeze LCD-3, LCD-ХС, Sennheiser HD-800. 1 Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
iow 1 809 1 Тракты Опубликовано 2 июля, 2015 Имеющийся под рукой oppo bdp-103 играет музыку как по сети, так и с флешки, но по качеству уступает тому же bbp-200.В чем 103 хуже? Вопрос не праздный - нахожусь в процессе поиска нового транспорта, и было намерение взять 103.Ну, в 103-м много воздуха, но он притемнённый, не шибко детальный. Звуковые образы в bbp более рельефные. Когда у меня месяц стоял dCS Debussy, то в качестве транспорта с огромным отрывом лидировал mac mini с выносным блоком питания (+Jriver), bbp и oppo при таком конкуренте по уровню звука казались одноклассниками. Однако, при переходе на mytek такой разницы между маком и другими транспортами не было. Тут они уже болтались в одной лиге. Впрочем, все кому удалось лично послушать и сравнить, были разочарованы и bbp, и тем более oppo. Ещё я сравнивал bbp200 с заточенным под музыку компьютером с Lynx AES16 на двух ЦАПах (или трёх? уже не помню...) - компьютер тоже оказался немного предпочтительнее. Допускаю, что при подключении какого-нибудь другого ЦАПа тот же bbp будет не хуже или даже лучше mac mini. Это же от многих факторов зависит. От качества реализации usb (в dCS с этим всё отлично) или от уровня конвертера (при связке mac mini -> sotm / berkeley alpha usb -> DAC). Например, Debussy, если верить отзывам, добавление прокладки в виде беркли или сотма ничего особо не дают. Всей этой суммой уточнений и обусловлена разница мнений. Oppo bdp-103 / BBP-200 -> Berkeley Audio Design Alpha DAC -> ? -> Fostex TH900, Beyerdynamic DT 911 (EDT 990 VB) / Focal Solo6 Be [в продаже] Было (неделя+): Наушники: Sennheiser HD 555, German Maestro GMP 400, Beyerdynamic DT 990 (1980's edition), Beyerdynamic DT 880 (1980's edition), Sennheiser HD800 s/n 4k, Sennheiser HD800 s/n 12k, Audez'e LCD-2, Sony MDR-CD3000, AKG K812, ТДС-15 Snorry Mod, HiFiMAN HE6, Beyerdynamic DT 660 MK II (EDT 770 V), AKG K1000ЦАПы, комбайны: Audio-GD NFB-5, MS Audio Laboratory DAC 1.0, M2Tech Young, Wadia 121, Hegel HD20, LevZ DAC-S-015f, Metrum Octave DAC MKI, Demograf DAC 4397, Mytek Stereo192-DSD DAC, dCS Debussy, Demograf DAC 1541Усилители: Laconic Night Blues NB-3A (с трансами sowter), SPL Phonitor, Lynx Audio HA61, Energy Audio Beta22, Demograf AMP (ECL82), AMB Beta22 [4-board balanced + 2xSigma22] by HeliumИсточники цифры: E-mu 0404 PCI, Musiland Monitor 01 USD, E-mu 1212m PCI, M2Tech hiFace RCA, RME HDSP 9632, Lynx AES16 PCI, QLS QA-660, SOtM dX-USB HD Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
Александр Карелин 3 720 Опубликовано 2 июля, 2015 bbp200 в оригинальном состоянии, без твиков и модоинга? "...сочинение магистра Алькофрибаса, извлекателя квинтэссенции " Наушники: Beyerdynamic T1 2nd Generation, Sony MDR-Z1R, Audio-Technica ATH-CKR9Ltd, кастомные Westone ES60 Усилители: только собственного производства транзисторные и ламповые "Ратша" Плеер: Luxury & Precision L3 Pro (!balanced output!) наушники Audio-Technica: ATH-W5000, ATH-ESW9, ES10(было), A2000x(было), W5000, R70x (было), CK100Pro(было), CKR9LTD, IM04(было), кастомные Westone ES60, Sony MDR-Z1R усилители: Sovereign Reference, Sovereign Baby Reference, Ратша плеер: Teclast T51, HiFiMan HM-801 (было), Pono Player SE(было), Aune M2 Pro (было), Cayin i5 (было) телега Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
iow 1 809 1 Тракты Опубликовано 2 июля, 2015 bbp200в оригинальном состоянии, без твиков и модоинга?Всё верно, без твиков. Oppo bdp-103 / BBP-200 -> Berkeley Audio Design Alpha DAC -> ? -> Fostex TH900, Beyerdynamic DT 911 (EDT 990 VB) / Focal Solo6 Be [в продаже] Было (неделя+): Наушники: Sennheiser HD 555, German Maestro GMP 400, Beyerdynamic DT 990 (1980's edition), Beyerdynamic DT 880 (1980's edition), Sennheiser HD800 s/n 4k, Sennheiser HD800 s/n 12k, Audez'e LCD-2, Sony MDR-CD3000, AKG K812, ТДС-15 Snorry Mod, HiFiMAN HE6, Beyerdynamic DT 660 MK II (EDT 770 V), AKG K1000ЦАПы, комбайны: Audio-GD NFB-5, MS Audio Laboratory DAC 1.0, M2Tech Young, Wadia 121, Hegel HD20, LevZ DAC-S-015f, Metrum Octave DAC MKI, Demograf DAC 4397, Mytek Stereo192-DSD DAC, dCS Debussy, Demograf DAC 1541Усилители: Laconic Night Blues NB-3A (с трансами sowter), SPL Phonitor, Lynx Audio HA61, Energy Audio Beta22, Demograf AMP (ECL82), AMB Beta22 [4-board balanced + 2xSigma22] by HeliumИсточники цифры: E-mu 0404 PCI, Musiland Monitor 01 USD, E-mu 1212m PCI, M2Tech hiFace RCA, RME HDSP 9632, Lynx AES16 PCI, QLS QA-660, SOtM dX-USB HD 1 Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
RuAlex 9 647 Опубликовано 2 июля, 2015 Имеющийся под рукой oppo bdp-103 играет музыку как по сети, так и с флешки, но по качеству уступает тому же bbp-200.В чем 103 хуже? Вопрос не праздный - нахожусь в процессе поиска нового транспорта, и было намерение взять 103.Ну, в 103-м много воздуха, но он притемнённый, не шибко детальный. Звуковые образы в bbp более рельефные. Когда у меня месяц стоял dCS Debussy, то в качестве транспорта с огромным отрывом лидировал mac mini с выносным блоком питания (+Jriver), bbp и oppo при таком конкуренте по уровню звука казались одноклассниками.Спасибо за ответ. Хотел использовать 103-й только в качестве транспорта с коаксиальным выходом на Цап.Встроенный цап 103-го, да - не особо.Имхо - 105-й на Сабре - предпочтительней. Продаю (цена договорная) Усилители для наушников:LehmannAudio Rhinelander (новый в упаковке) Burson HA-160 (редкий - первого выпуска)(https://market.yande...90554&nid=56162) Наушники: PHILIPS X1 (новые, полный комплект) Mb Quart QP400 (Made in W.Germany) и др. )) ЦАПы:Cambridge Audio dacMagic plus (идеальное состояние, полный комплект)Линейный блок питания для Cambridge Audio dacmagic plus(заказной) SMSL M8 (новый, полный комплект)(https://doctorhead.r...description=yes) Да вообще все распродам... Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
iow 1 809 1 Тракты Опубликовано 2 июля, 2015 Спасибо за ответ.Хотел использовать 103-й только в качестве транспорта с коаксиальным выходом на Цап.Встроенный цап 103-го, да - не особо.Имхо - 105-й на Сабре - предпочтительней.В 103-м ЦАП уровня встроенной звуковухи, естественно его следует рассматривать только как транспорт. Переплата за столь посредственную реализацию сабре в 105-м того не стоит. Любой середняк на 9018 будет лучше. Сравнивал цаповую часть в 105-м с mytek 192 dsd (там 9016), разница пугающе велика в пользу майтека. Oppo bdp-103 / BBP-200 -> Berkeley Audio Design Alpha DAC -> ? -> Fostex TH900, Beyerdynamic DT 911 (EDT 990 VB) / Focal Solo6 Be [в продаже] Было (неделя+): Наушники: Sennheiser HD 555, German Maestro GMP 400, Beyerdynamic DT 990 (1980's edition), Beyerdynamic DT 880 (1980's edition), Sennheiser HD800 s/n 4k, Sennheiser HD800 s/n 12k, Audez'e LCD-2, Sony MDR-CD3000, AKG K812, ТДС-15 Snorry Mod, HiFiMAN HE6, Beyerdynamic DT 660 MK II (EDT 770 V), AKG K1000ЦАПы, комбайны: Audio-GD NFB-5, MS Audio Laboratory DAC 1.0, M2Tech Young, Wadia 121, Hegel HD20, LevZ DAC-S-015f, Metrum Octave DAC MKI, Demograf DAC 4397, Mytek Stereo192-DSD DAC, dCS Debussy, Demograf DAC 1541Усилители: Laconic Night Blues NB-3A (с трансами sowter), SPL Phonitor, Lynx Audio HA61, Energy Audio Beta22, Demograf AMP (ECL82), AMB Beta22 [4-board balanced + 2xSigma22] by HeliumИсточники цифры: E-mu 0404 PCI, Musiland Monitor 01 USD, E-mu 1212m PCI, M2Tech hiFace RCA, RME HDSP 9632, Lynx AES16 PCI, QLS QA-660, SOtM dX-USB HD 1 Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
dj000001 4 Опубликовано 2 июля, 2015 Очень интересный плеер с отличным звучанием http://hi-fidelity-forum.com/forum/thread-141544.html . Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
Александр Карелин 3 720 Опубликовано 2 июля, 2015 @dj000001, где вы там плеер увидели? по ссылке сплошное сделай сам, найди из чего сделать сам, настрой сам, слушай тоже сам и ни с чем не сравнивай "...сочинение магистра Алькофрибаса, извлекателя квинтэссенции " Наушники: Beyerdynamic T1 2nd Generation, Sony MDR-Z1R, Audio-Technica ATH-CKR9Ltd, кастомные Westone ES60 Усилители: только собственного производства транзисторные и ламповые "Ратша" Плеер: Luxury & Precision L3 Pro (!balanced output!) наушники Audio-Technica: ATH-W5000, ATH-ESW9, ES10(было), A2000x(было), W5000, R70x (было), CK100Pro(было), CKR9LTD, IM04(было), кастомные Westone ES60, Sony MDR-Z1R усилители: Sovereign Reference, Sovereign Baby Reference, Ратша плеер: Teclast T51, HiFiMan HM-801 (было), Pono Player SE(было), Aune M2 Pro (было), Cayin i5 (было) телега Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
MasterLin 26 Опубликовано 3 июля, 2015 @dj000001,штука интересная, если создатель поставит на поток или будет точная инфа по созданию, то можно заказать умельцу. Ответ с цитатой Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты
